09-07-2022, 09:55 AM | #45 |
Rep 242
09-07-2022, 10:49 AM | #46 | |
Rep 47
sure I don't touch anything . Priam I read alternatively I ask those who can do even remotely pc. Thank you |
09-07-2022, 10:51 AM | #47 |
Rep 47
I can't find messages in my profile .is disabled
09-07-2022, 11:26 AM | #48 | |
Rep 47
09-07-2022, 11:37 AM | #49 |
Rep 47
Should this be correct?
09-08-2022, 01:58 AM | #50 |
Rep 23
09-08-2022, 04:03 PM | #51 | |
Rep 19
Also is it possible to code flashing brake lights/Euro Anti Dazzle on 2021 G05 with Bimmercode? I’m new user so I can’t PM you. 05.brains_magnum@icloud.com Thanks. |
09-09-2022, 03:25 PM | #52 | |
Rep 451
Drives: 2017 X5 & 2020 X5
I have a Euro spec X5 so not familiar with anti dazzle coding for US spec models. I would think you will need BimmerUtility or ESysPlus/Ultra. Bimmercode does not give access to all ECU's in the vehicle but not 100% certain perhaps some US owners that have done the coding can confirm my assumption.
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
09-16-2022, 06:40 AM | #53 | |
Rep 242
BU is update ! Now they fix ucc problems!!! Also update to 4.37.20 map |
Bambazonke210.00 |
10-13-2022, 09:06 AM | #54 | |
Rep 2
Can you share the cheat? I can't play pm because I'm a new member e-sys hotaek0604@naver.com thanks |
12-29-2022, 09:45 PM | #55 |
Rep 16
Can you please send me the cheat sheet as well my friend ? powerfulpc1@gmail.com
12-30-2022, 02:39 AM | #56 |
Rep 70
Hi all, hope you all had/are having a great festive period!
UK owner here. I’m interested in getting the most out of my G05 and naturally Bimmer Code and Bimmer Utility has peaked my interest, however… I don’t have DAP so I fear a lot of the best features are just impossible for me to code. I do have ACC with stop & go so I have some of the kit just not the cameras I believe? Could anyone point me in the direction of what would be available for me to code please? I’m most interested in the aTLA, aSLA and any other autonomy that may be available but a full list of what would be amazing also. Thank you in advance for any help |
12-30-2022, 07:09 PM | #57 | |
Rep 451
Is "anticipation" activated in your cruise control options? I think that can be activated without DAP as it uses the speed sign data in the map database. There are few other cosmetic changes you can make to the instrument panel and head unit. If you are keen to proceed to the next level I would suggest purchasing a cable and Bimmer Utility software. Bimmercode which is a smartphone App is very good for basic cosmetic coding has limitations as it does not have access to all the car's ECU's for safety reasons. It's backup system is not great and requires in my opinion the user to make notes on changes he or she does. Either way get a std OBD enet cable for Bimmer Utility and a smart phone/pad cable adapter if you opt for Bimmercode. It is a lot quicker and more reliable than using Wifi or Bluetooth Adapters
weinerbarn734.00 BillyShakes39.00 |
01-01-2023, 06:28 AM | #58 | |
Rep 70
I’m not sure about the anticipation setting for cruise control, what does that do? Is it where you just need to hit the “set” button for the cruise control to change to the upcoming speed limit? If so, I do have that turned on! I always thought the real estate on the cockpit screen was a bit wasted with very limited views available so would be good if I Callum’s add some further options to that. Sounds like Bimmer Utility is the way to go with an OBD cable then. Thanks for your help, appreciate it. |
01-26-2023, 07:19 AM | #59 | |
Rep 1
aamri111@gmail.com |
04-29-2023, 06:48 PM | #60 |
Rep 75
Drives: 2022 X5 4.5e
I would really appreciate your G05 cheatsheet as well. temoore48@gmail. Thanks in advance!
TE Moore
05-03-2023, 09:31 PM | #62 |
170
Rep 300
I would love the chest sheet. Kevin_d_shaw@mac.com Thanks!!
Shawzy44
2024 BMW X1 28i 2023 BMW X3 M40i 2019 BMW 440iX M Performance Cabriolet |
05-26-2023, 08:27 AM | #63 |
Rep 5
Hi Expert, I'm new user and have Bimmer utility. I tried open feature for a TLA on my G01 '2022 like post pic. However, I can't find the check box for enable traffic light. Any suggedtion? G05 Table is compatible with G01? If yes,could you please pm to me? Much thanks
06-04-2023, 01:03 PM | #66 |
Rep 133
I would also like the cheat sheet if anyone can provide it. mandomedic122@att.net
