Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Southwest > Tire pressure sensor error..especially when temp drops in Dallas
      12-10-2007, 10:33 AM   #1
C-Dub7
C-Dub7's Avatar
Drives: E92
For those in DFW area, did you tire pressure sensor light on? Mine was turned on when the temperature drop significantly yesterday...... i checked the pressure and it seems to be ok....
      12-10-2007, 10:42 AM   #2
Terrance28
Terrance28's Avatar
Drives: Crimson Red E92
I don't have a 335i yet. But when it got cold here in killeen I know my wifes acadia tps came on. But after a couple minutes of driving it went out.
      12-10-2007, 11:48 AM   #3
kptaylor
kptaylor's Avatar
Drives: '07 335i Coupe
When it's cooler outside the pressure in your tires drop. Our TPMS will come on with (I think) a 3 psi drop. If you check your tire's pressure, I guarantee it's lower than before and beyond the max drop point, which will set it off.
      12-10-2007, 12:03 PM   #4
penny31
Drives: 2016 m4 - Austin Yellow
i have the same problem in l.a. after a cold nite my tpms sensors go off so i took it to the dealer. it wasnt even that cold for it to drop
e92 m3 Melbourne Red 6 speed
      12-10-2007, 12:24 PM   #5
kptaylor
kptaylor's Avatar
True, but keep in mind when the TPMS is calibrated, that's the "normal" pressure the sensor is looking for and calculating the low tire warning from. If the tires were filled high at the factory, the sensor may trigger a warning even if the pressure is normal when you check it. Fill the tires to factory settings and then reset your TPMS to be sure. (Instructions in the manual.)
Mine were set off when I went on a vacation and hit a cool night, so I had to fill and reset mine. No issues since.
      12-11-2007, 12:29 AM   #6
BMW_TT
Drives: E92 335i
It shouldn't be a problem. Mine went on for a couple of minutes, but after the tires heat up, you'll have no problems at all.
      12-11-2007, 10:47 AM   #7
C-Dub7
C-Dub7's Avatar
Drives: E92
I ended up spending $0.75 to fill up the pressure to recommended setting.
      12-16-2007, 03:41 PM   #8
DFW_E90
Drives: 2007 Titanium Silver 328i E90
I work as a porter at BMW and have had a lot of cars coming in with the TPM light on when we are going from hot to cold, its completely normal. Fill your tires to the recommended psi, reset the light and go on your merry way.
