BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > So who's going to get the Dinan oil cooler?
      12-12-2007, 08:48 PM   #1
RMRC
RMRC's Avatar
19
Drives: 2011 E90 335d
I'm giving this some serious thought but at $2k plus labor I'm still hoping another tuner will release something similar at a lower price.
      12-12-2007, 10:23 PM   #2
leftcoastman
52
Drives: 335i
My thoughts precisely. I cannot imagine that many people would pay that amount, but I've been surprised before.
The cooler is a cheap $150 Derale cooler but then they add the neat hoses and the all-important fender liner vent.
      12-13-2007, 08:26 AM   #3
RiXst3r
RiXst3r's Avatar
271
Drives: M235i
ooh... its black with blue anodized screw on thingies
actually looks like a good product... still overpriced... but not too shabby
Specifications
Total Volume: Stock = 9.5 oz. / Dinan = 19 oz.
Surface Area: Stock = 45 sq./in. / Dinan = 67.5 sq./in.
Cooling Tubes: Stock = 10 / Dinan = 23
Tube Lengths: Stock = 90 in. / Dinan = 207 in.
Tube Area: Stock = 112.5 sq./in. / Dinan = 414 sq./in.
      12-13-2007, 08:33 AM   #4
ToddPhilly
ToddPhilly's Avatar
Drives: BMW 335i Coupe
Is this supposed to be better than the stock oil cooler, or it for cars that BMW so kindly decided not to include it on?
335i Coupe: Crimson Red / Black
X3 3.0si: Alpine White / Sand Beige
      12-13-2007, 08:36 AM   #5
RiXst3r
RiXst3r's Avatar
271
Drives: M235i
Both
They sell 2 kits... one for cars looking to upgrade cooling capacity of the existing cooler, and one for cars that have no cooler.
The latter being a tad more expensive because the oil filter housing doesnt contain the thermastate and hose hookups if you didnt have a factory cooler.
Here, read for yourself:
http://www.dinancars.com/Series.asp?...s=44&Model=117
      12-13-2007, 09:56 AM   #6
DrewKo
DrewKo's Avatar
44
Drives: 335i Montego Blue Saddle Brown
2007 335i  [0.00]
So if we have the factory cooler, could we hook up this other cooler assuming it fits (not the Dinan cooler)?
      12-13-2007, 11:26 AM   #7
S4to335
Drives: 2014 Audi A4 / 91 Track Miata
Originally Posted by RiXst3r View Post
Both
Interesting...just wish it wasnt so friggin expensive.
Car is now gone .... :-(
      12-13-2007, 02:33 PM   #8
OC Guy
OC Guy's Avatar
Drives: AW 335D E90
2007 335i  [0.00]
They are called fittings bro.
Yeah, looks good, pricey but looks good.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics
      12-13-2007, 02:37 PM   #9
leftcoastman
52
Drives: 335i
Come spring, I might switch to 90% distilled, 9.5% coolant to protect the metals and 0.5% water wetter.
My hope is that the coolant will takeover some more cooling duty - alleviating the load on the oil.
      12-13-2007, 02:46 PM   #10
Hegemony
Fast Like Tiger
Hegemony's Avatar
Drives: 07 M Coupe
Seems like you could get a custom oil cooler made for that.
-Hegemony
Pics
      12-13-2007, 02:50 PM   #11
2e9x's
2e9x's's Avatar
Drives: 335i ED 7/07
I'm very tempted. This is a nice complete solution!
2010 Evo X - silver with a big, stupid wing on the back
2009 VW CC - Black/Black - with a 2011 328i on order to replace it - ED 8/1/11
      12-13-2007, 03:36 PM   #12
RMRC
RMRC's Avatar
19
I can't help but wonder if a Dinan flashed car - even with all the additional power - will actually produce lower, or more stable, temps on track because of the higher water pump flow rates written into the flash? If it does the Dinan flash would seem to be a bargain.
Any thoughts on this? Am I dreaming?
      12-13-2007, 04:18 PM   #13
Chowbow
pew pew
166
Drives: 三三五i
Well at least somebody did the R&D and it looks like you can definitely put in a cooler that will cause a lot more back pressure (many turns and longer tubing) without a problem. I would think it'd be easy to get a custom fab mount with a similar cooler and lines for around $500. Anybody know by chance which cooler that is and what diameter the tubes are? If so, it wouldn't be too hard to figure out how much head pressure it takes to pump oil through that cooler, and find something similar...
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
      12-13-2007, 05:14 PM   #14
Hegemony
Fast Like Tiger
Hegemony's Avatar
Drives: 07 M Coupe
Did they write that into the flash? Is that known?
-Hegemony
Pics
      12-13-2007, 05:20 PM   #15
Chowbow
pew pew
166
Drives: 三三五i
There's a link in this thread and here's the excerpt from the Dinan page:
"Remapped Water Pump Speeds. In an effort to more effectively control oil and water temperatures, which have been notably excessive even at stock boost pressures, the Dinan software actually increases water pump speeds as boost pressure increases. A much larger, more efficiently ducted oil cooler has also been developed, further improving heat exchange for lower and more consistent operating temperatures, even with the added boost pressure. "
So it looks like the oil pump is going at the same speeds but electric water pump has been remapped to flow more when boost goes up.
      12-13-2007, 05:23 PM   #16
RMRC
RMRC's Avatar
19
Yes it's confirmed. I took the following directly from the Dinan website:
"Remapped Water Pump Speeds. In an effort to more effectively control oil and water temperatures, which have been notably excessive even at stock boost pressures, the Dinan software actually increases water pump speeds as boost pressure increases. A much larger, more efficiently ducted oil cooler has also been developed, further improving heat exchange for lower and more consistent operating temperatures, even with the added boost pressure."
      12-13-2007, 05:24 PM   #17
RMRC
RMRC's Avatar
19
Ah Chowbow beat me to it.
      12-13-2007, 06:45 PM   #18
2e9x's
2e9x's's Avatar
That Dinan cooler also adds a revised scoop and larger exhaust vent. It appears to be a nice piece!
Here's a question...is either unit alone sufficient? Let's say you have a step car with the factory oil cooler. Would the Dinan flash allow you to run safe temps without also getting the larger cooler?
      12-13-2007, 07:47 PM   #19
RMRC
RMRC's Avatar
19
Exactly what I was asking in my post #12 above. My thinking (perhaps wishful thinking) was that if the flash reprograms the water pump for a higher flow rate at higher boost maybe this would be enough to stabilize temps on track even though the Dinan car is putting out a lot more power over stock.
      12-17-2007, 09:04 AM   #20
judec
born to be turbocharged
judec's Avatar
Slovakia
24
Drives: Not a bimmer yet
http://www.e90post.com/forums/showpo...3&postcount=15
Disclaimer: All this message was written with recycled electrons.
      12-17-2007, 10:26 AM   #21
RMRC
RMRC's Avatar
19
Originally Posted by judec View Post
Really appreciate that link to Shiv's comments. So it looks like this was just wishful thinking since under high load on track the water pump is going 100% anyway. So back to thinking about a more reasonably priced larger oil cooler made by someone other than Dinan.
      12-17-2007, 03:57 PM   #22
judec
judec's Avatar
Slovakia
24
that's the point, dude
