2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Weird Noise
      07-24-2014, 09:30 AM   #1
m1cism
Drives: BMW 228i
Weird Noise
Hi all,
I got a new 228i a few weeks ago, and it has been great so far!
However, I have 2 issues with the car that I am getting checked out hopefully today. Just wanted to see if anyone here had some insight about the issues, because it is very possible that I am being paranoid.
Issue 1. I am hearing an odd noise from the rear of the car when going in reverse. It sounds almost like an electronic switch turning on and off constantly. I do not know how else to explain it really but its loud and bizarre.
Issue 2. Not really mechanical but the voice recognition button on the steering wheel does not work at all.
Thanks for all the help,
Chris
      07-24-2014, 10:26 AM   #2
overcoil
Drives: M235i 6spd
Just my guess; the reverse issue may be a type of diagnostic of the ABS system - but I have no experience with the car.
Voice recognition is often sketchy.
      07-24-2014, 10:44 AM   #3
m1cism
Drives: BMW 228i
That would make sense in regards to the ABS diagnostic. I'm hoping that is the case. I did notice that it only seems to happen after I go on a drive and come back home and back into my driveway.
      07-24-2014, 01:05 PM   #4
bimmerbuff
Slightly Less Obsessed
bimmerbuff's Avatar
Drives: Between BMWs
Did you get the Technology Package (ZTP)? I believe the voice command function is part of that package. Without it, the button will do nothing.
      07-24-2014, 02:19 PM   #5
m1cism
Drives: BMW 228i
Wow, haha that can be it actually. I kind of find it silly to install a voice recognition button without the functionality. But yes, I do not have the technology package so that can be the reason why it does not work.
Is there a way to enable this with coding?
      07-24-2014, 03:36 PM   #6
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Trust me u will never use it
I used it on the e90 like10 times out of 9 years...2 were accidental
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-24-2014, 03:39 PM   #7
m1cism
Drives: BMW 228i
Yeah I agree, but it just seems silly to have a blank button to me.
      07-24-2014, 04:43 PM   #8
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
it's cause it's probably more expensive to design 2 steering wheels than just having the button not do anything...
      07-25-2014, 08:15 AM   #9
m1cism
Drives: BMW 228i
So I brought my car in to pick up my plates and had them take a look at the car for the noises.
They told me that it is the exhaust valves turning on and off electronically. Hopefully someone can give me insight to as if this makes any sense or not.
And for the voice recognition control, I just do not have the feature.
Thanks for all your advice!
      07-25-2014, 08:56 AM   #10
Killramos
Killramos's Avatar
312
Drives: '19 M2 '21 X5
Yea all mkv vw GTI's had a phone Button even though not a single car on NA came with Bluetooth lol. Just taunting us with what we don't have XD
      07-25-2014, 08:57 AM   #11
bimmerbuff
bimmerbuff's Avatar
I don't think you can just code it in without also retrofitting some parts, but I'm not 100% sure.
      01-31-2015, 07:17 PM   #12
SteveSFO
15
Drives: '18 M2 Long Beach Blue
I have the same thing happening to me. After a drive and the car in the garage, a few minutes of something that sounds like small pressure relief valves opening. Could be the exhaust valves. Wonder why they need to cycle through...unless it's to help prevent build up on the valves?
      05-20-2015, 01:32 AM   #13
Stiggy
Drives: 2016 M235i
I have the same issue and thought it was odd to still have the button. However, it actually does do something depending on the phone that is paired and connected. With a Samsung Galaxy s4 it enables the phone's voice recognition.
2addicts
