08-07-2014, 05:10 PM | #1 |
One mod leads to another ...
415
Rep 2,900
Do you really need an Alignment after replacing Springs?
To the suspension experts out there ... if you lower the car with a set of springs, with a mild drop, do you really need an alignment? Shouldn't all that really changes is the camber? More negative camber that is generally beneficial anyway?
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
08-07-2014, 05:35 PM | #2 |
Rep 1,190
Yes, you need an alignment. Camber and toe both change, and often not by the same amount on both sides. Even if the car doesn't seem to pull or drift, the alignment will be off, your steering response will not be right, and your tire wear will increase.
/thread
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
08-08-2014, 11:45 AM | #4 |
Croatian
884
Rep 3,613
Drives: PORSCHE
Yes you do. I also always check and adjust the alignment after 100 miles or so once the springs settle to the permanent ride height.
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
08-19-2014, 05:51 PM | #6 |
Supreme Allied Commander
3816
Rep 54,319
Drives: F80 M3
Yes, you should align the car after springs. Not only you have changed the ride height, you may have potentially moved things around enough to throw off the alignment settings.
