Drag racing against my friends Evo 9, needs tips.
08-17-2014, 03:11 PM | #1 |
62
Rep 317
A few questions to the experts.
Drag racing against my friends evo 9 (FBO, no tune) Wednesday. I am FBO with JB4 (no meth) 1) What would be the ideal map for dragging? 2) Ideal rpm to launch at? 3) Should I turn traction completely off? We are just racing for fun, to see our times. But it would be nice to have the better time Also, it is a possibility I might put 100 oct in the car. |
08-17-2014, 03:27 PM | #2 |
4486
Rep 10,473
Yea turn traction off so it doesnt intervene, in terms of best launch, you should know your car better than any of us, but about 2k RPM sounds about right depending on tires and surface, just go out and do some test runs and see which method works better.
08-17-2014, 03:48 PM | #3 |
Rep 2,839
Drives: e92 335i, e34 525i & e60 530i
Another factor is your transmission. Methods would vary. 2-2.5k like igor ki stated is idea for m/t. I know a few auto guys that launch from 2nd gear at a higher RPM, but be careful not to hit the kick down.
Either way, take a few practice runs. Tires are also another factor. Lower you PSI a bit and heat them up before running to help you hook. Not sure what tires you're running, so around 36 PSI should be good. Can't recommend which map to run since I'm not familar with JB4. I know it have shift lights, might want to set it at your happy point.
08-17-2014, 03:53 PM | #5 | |
62
Rep 317
From what I understand, autotune map is probably the most ideal for dragging?
It has lower PSI in 1st and 2nd gear, and goes up to 16-18 in the rest. Quote:
08-17-2014, 04:15 PM | #6 |
Rep 2,839
When I mentioned PSI, I was referring to tire pressure, not boost. Someone with JB4 experience would have to help you out as far as the JB4 go.
08-17-2014, 04:34 PM | #7 |
Rep 451
Since he's not tuned you will pull him after 1st gear easily regardless if you are auto/manual. Quick slip if you are manual and 2nd gear light rev launch and you are fine without killing your transmission
08-18-2014, 11:31 AM | #8 |
Rep 650
What are you calling FBO on the EVO? And you can mod the EVO ECU code with no visible evidence. He might run 10s for all you know. Or you might crush him if he's actually close to stock and doesn't launch it hard.
02-28-2015, 04:06 PM | #10 |
BimECU
193
Rep 759
depends on the length of the race,
if it is short, start with 1 gear if it is longer, start with 2 gear, if you dont have kickdown blocker, if you start with 2 gear, dont push down to the kickdown, start with 2000-2300 RPM, shift at 6200, if you add some e85, do some 3rd gear pulls on map5, or go with map2 *practice starts before the race* |
03-02-2015, 05:26 PM | #11 |
241
Rep 2,781
Drives: E90 335i Racecar
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
03-02-2015, 06:55 PM | #12 | |
Rep 441
Drives: 2008 335xi sedan
03-11-2015, 02:56 PM | #13 | |
BimECU
193
Rep 759
on WOT both D or S revs up to 7000, but you should be shifting at 6000-6200 |
03-11-2015, 03:07 PM | #14 |
Midlife Crises Racing Silent but Deadly Class
1820
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
So? Did you win?
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
