08-21-2014, 08:01 AM | #1 |
Rep 265
Clay Bar Questions
Anyone familiar with Clay bars?
Am going to start claying my m4, but have never used one before. Can anyone make a recommendation? Thanks |
08-21-2014, 11:28 AM | #2 | |
Rep 2,633
08-21-2014, 12:07 PM | #3 | |
Rep 1,450
Good luck. |
08-21-2014, 01:10 PM | #4 | ||
Rep 2,633
08-21-2014, 02:56 PM | #5 |
Rep 570
My only clay bar tips are as follows (beyond the above tips, which are good):
1) You can tell whether your car needs to be clayed, or not, by just feeling your paint texture after you wash/dry your car. I just washed my M4 for the first time yesterday and the paint is so clean/contaminant-free, I went right ahead and used some spray polish. No clay needed! I'll wax it shortly 2) After driving the car through the winter, or through a rain storm where road contaminants splash onto the paint...you can literally "feel" the surface of your paint and the bumpiness (w/no visible evidence) of the contaminants. Spray liberally w/Speed Shine (I use Griot's Garage) and lightly glide the clay over the paint. You'll see the yellow clay begin to turn brown/black w/the contaminants and feel the resistance as you glide the clay over the paint 3) Careful of letting any dirt get on the clay or of not using enough spray lube. The clay will get hung-up if you don't have enough spray on the paint, so do a small section (one door, for instance) at a time I don't do my whole car...I only use clay where I feel the contaminants after washing. Good luck! |
11-03-2014, 08:22 PM | #6 |
Rep 3,341
i just clayed my wife's car over the weekend. had a question-
assuming using enough quick detail is being used to keep it slippery, is it possible to push too hard on the claybar to the paint? wife's car had a lot of sap stains, and had push it pretty hard to make the bar effective. it was great on everywhere else.
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
01-29-2015, 05:17 PM | #7 |
Rep 25
No...you really can't hurt anything by pushing too hard with clay, but I wouldn't try getting sap off with clay. Get a good bug and tar removing solution on it first. You're just contaminating the clay that much faster with all that sap.
I really like this product: http://www.detailersdomain.com/searc...x=0&search.y=0 NanoSkin Autoscrub. Works exactly like clay, but you use it on a DA polisher. They have a hand version too, but so much faster on a DA, especially compared to using clay. Also, clay eventually needs to be tossed and if you drop it you pretty much have to toss it. While the NanoSkin you just rinse off the pad. Check out all the YouTube videos on it too. And if you don't have a DA you can get one at Harbor Freight tools for under $100. Not the best quality one...not one a pro would use...but good enough for someone just using it for their own car here and there. |
cehrl7825.50 |
01-29-2015, 06:16 PM | #8 |
Rep 205
^ +1, haven't tried it with my DA yet but did a couple areas with a NanoSkin sponge by hand and it worked pretty well, plus the "rinsability" vs replacement is definitely nice
01-31-2015, 11:57 AM | #9 |
Rep 146
I like griots clay bar and griots speed shine as lube. The clay is nice and soft to work with and doesn't mar the paint unlike a different brand clay I tried a while ago that completely necessitated polishing afterwards. I tried using optimum no rinse wash as lube recently and that worked well and is very cost effective, however I already got a gallon of speed shine.
02-15-2015, 11:12 AM | #10 |
Rep 700
Librocation is your friend when claying, keep both the clay and the surface well lubed. I'd advise a medium clay. Some are even now suitable with soapy water. Clay cloths are handy for just the odd bits and bobs, but tend to only be a fine clay.
02-15-2015, 11:32 AM | #12 |
Rep 700
Yeah same deal as a clay cloth, fine clay so good for inbetween full decontamination sessions. I'm a traditionalist with this and would stick to a clay bar, at least you can throw away chunks of it once your done.
