proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs)
      09-02-2014, 04:22 PM   #1
Dasm3nd
Dasm3nd's Avatar
29
Drives: 2015 YMB F80
Beware when washing your car...
I found out yesterday that garden hose + key in pocket while rinsing back of car can lead to auto trunk release. Hose fooled sensor into opening trunk. Thank goodness for warning lights...
      09-02-2014, 04:31 PM   #2
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
lol this has been an issue since this feature was released.. I have not personally done it but i always leave my keys out of range of the car so it doesnt happen.
      09-02-2014, 04:51 PM   #3
04RC51
Large Member
04RC51's Avatar
951
Drives: E92 M3, F82 M4
You should also irrigate the LSD wiper wells as they will just pool up water. The correct side drive wells are irrigated so they don't hold water but the wrong side drive wells that aren't used just pool up with alot of water. Not sure why they didn't put holes in there for us since they aren't being used.
2008 E92 M3 (Engine swap completed), 2015 F82 M4
      09-02-2014, 05:10 PM   #4
Definitive
definitivecars.com
Definitive's Avatar
Drives: Elsa - 2015 F80 M3 - YMB/SS
Oh and by the way, how do you lift the wipers without scratching the edge of the hood??? I ripped my clearbra during my first wash. So pissed. The e90 didnt have this issue.
D
      09-02-2014, 05:15 PM   #5
Oakleyguy
Resident Engineer
Oakleyguy's Avatar
Drives: Land Cruiser
2014 Toyota URJ200  [0.00]
2017 BMW M2  [0.00]
2015 BMW M4  [10.00]
2005 Toyota UZJ100  [0.00]
I remember hearing that if you press the stalk in a certain pattern, it will stop the blades in the vertical position allowing you to flip them up.
Sadly can't remember the pattern. I vaguely remember the 5 series having a similar feature?
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD
2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air
European Delivery Journal & F8X Door Rattle Fix
Machine Shop Directory - www.mfgcenter.com
      09-02-2014, 05:26 PM   #6
04RC51
Large Member
04RC51's Avatar
951
D
It's covered on the forum somewhere. Just put some time in and search around.
      09-02-2014, 05:26 PM   #7
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
23 Bmw M3  [10.00]
In my f10, shut off car. Before you open the door press and hold the wiper stalk up until it moves to vertical.
      09-02-2014, 05:31 PM   #8
Vectors2final
Vectors2final's Avatar
Drives: 2018 F80 YMB/SS ZCP
Nothing a small Dremel hole wouldn't fix, no?
      09-02-2014, 05:40 PM   #9
coolmody
365
Drives: AW/SO F80 M3
I did this while wand washing my car during ED! The trunk opened while I was washing the back of the car, and every time the water went over the front door handles, the Comfort Access would constantly lock/unlock the doors. What is everyone else doing to prevent this? I can't see myself throwing the key away as far as possible in a public wash bay....
D
This puzzles me as well and I haven't found an answer. I'm driving a 528i loaner right now and it has the same issue
      09-02-2014, 05:55 PM   #10
Vectors2final
I can't use a public wash.
I have all the detailing tools I need, and I prefer it that way.
      09-02-2014, 05:56 PM   #11
SOM3
43
Drives: SO F80
Press the wiper stalk up past the resistance point and hold for three seconds so the wipers stop in the center (service position). It's all in the manual.
      09-02-2014, 06:50 PM   #12
Hobbination
Hobbination's Avatar
Drives: 2015 M4
This likely holds true on DIY oil changes as well, found out the hard way on my 335i w CA that when the key is local, the engine primes itself to start and the oil is under pressure, loosened the drain plug and 50psi hot Mobil 1 everywhere. So awesome.
      09-02-2014, 07:02 PM   #13
Andrew115
Andrew115's Avatar
328
Drives: Silver Bullet
Leave the key in the cup holder. CA should be disabled.
      09-03-2014, 02:50 AM   #14
///REWO
///REWO's Avatar
Drives: 05' 116i high executive
How about the trunk lock feature in the glovebox, maybe if you lock it CA would be disabled?
f80post
