2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning 220i with M135i OEM Exhaust
      09-08-2014, 09:50 AM   #1
Icy J
im a car
Icy J's Avatar
Hong Kong
736
Drives: 220i M Sport | 520i M Sport
2014 BMW 220i  [10.00]
Bought a M235 diffuser so had to change my exhaust as well. Can't afford a proper aftermarket M235 exhaust at the moment so I found a used M135 exhaust and had it installed + the tailpipes adapted, as they were way too short. Not a huge difference but I get a nice crackle when upshifting now I do plan to eventually change to a proper louder exhaust, but in the short term I might just get a resonator delete done.
BMW 220i | Exotics Tuning M235i Kit by - Icy J -, on Flickr
BMW 220i | Exotics Tuning M235i Kitby - Icy J -, on Flickr
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB]
Instagram: @icyj95 | FB
      09-08-2014, 01:28 PM   #2
VMRWheels
VMRWheels's Avatar
2040
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Wow, never thought about that. Very nice!
      01-14-2015, 02:48 PM   #3
jcsaka
Drives: 220i
hey! i have a 220i too! can you help me with the mods you made? thank you!
      01-20-2015, 10:18 AM   #4
Icy J
im a car
Icy J's Avatar
Hong Kong
736
It's just a stock M135 exhaust which had to be adapted (most significantly with the tips) to fit an aftermarket M235 diffuser. Would probably have been easier with a stock M235 exhaust but there weren't any available used and I needed one urgently. While I'm waiting for used M235 aftermarket exhausts to start appearing on the market, I got a resonator delete done...
cold start
      03-09-2015, 11:19 AM   #5
Silvermike
Silvermike's Avatar
Trinidad_and_tobago
143
Drives: 2015 AW M220i 6MT
2015 M220  [9.50]
Needs more grunt
      03-09-2015, 12:06 PM   #6
Icy J
im a car
Icy J's Avatar
Hong Kong
736
Originally Posted by Silvermike View Post
Needs more grunt
Are you kidding me, this is a rather temporary solution
Saw an A45 flying around London the other day, that sound omfg
      03-09-2015, 12:16 PM   #7
Silvermike
Silvermike's Avatar
Trinidad_and_tobago
143
2015 M220  [9.50]
My gf likes those. For me i dont care what it sounds like. its a merc and handles like a brick.
      03-18-2015, 05:04 PM   #8
tencazzo
Drives: BMW 220i M Sport
Hi Icy J, I got now one from 235i and want to install it. Assume that pipe is 80mm on 235i but not sure what is the pipe on 220i? 60mm? Do I need to get a connection pipe or kind of adapter?
      03-18-2015, 05:21 PM   #9
Icy J
im a car
Icy J's Avatar
Hong Kong
736
I'm not sure about the 220's pipe diameter but it's definitely smaller and you'll need some kind of adapter for the 235 exhaust to fit the tips might need some adjusting too
      05-01-2015, 10:21 AM   #10
dani220iM
Saudi Arabia
Drives: BMW 220i
hello may i ask if i can change my 220i exhaust to M235 exhaust ? and what parts i have to change it ? then what about the sound after i change it ? cuz we know the 220i has 4cylinder and 2.0 liter while the M235 it has 6cylinder and 3.5 liter !
Regards,
Dani
      05-01-2015, 11:06 AM   #11
Icy J
im a car
Icy J's Avatar
Hong Kong
736
Regards,
Dani
You have to change the rear muffler and it technically isn't a direct fit, as the pipe diameters are off (235 is 80mm or something, 220 less) so you'll need to get it welded. You'll also have to change the rear diffuser (assuming you have an M Sport model) as the 235 exhaust has an additional tip (and the existing one on the left side is in the wrong position anyway). The muffler itself will obviously fit.
It's a tiny bit louder, but not by much. Unless you're only doing it for the looks, I'd buy a 235 M Performance exhaust or an aftermarket one, not worth the slight increase in sound IMO. But then I always had an aftermarket exhaust in mind and my solution was only meant to be temporary as I was quite time-limited. If you're adamant on a stock 235 muffler, then I suggest cutting out the resonator as well, as it adds a tiny bit of noise.
The 220 won't sound anything like a 235, apart from an engine swap.
      05-13-2015, 07:51 AM   #12
tencazzo
Regards,
Dani
See my post #5 here
http://www.2addicts.com/forums/showt...5#post17903185
      05-23-2015, 11:17 PM   #13
Icy J
im a car
Icy J's Avatar
Hong Kong
736
Video clips with resonator deleted.
      05-26-2015, 10:55 AM   #14
xtlwulf
Drives: 2013 335xi | 2015 228xi
if the M135 exhaust was able to fit, then technically wouldn't the 1M quad exhaust be able fit too?
      05-26-2015, 08:09 PM   #15
Icy J
im a car
Icy J's Avatar
Hong Kong
736
M135 as in F20, not E82.
      06-13-2015, 03:37 PM   #16
verheizer
9
Drives: 435i
Could a M235i diffuser (and therefore a twin pipe exhaust) be installed onto a 220i Sportline as well?
I like the sound, its subtle but more than stock.
      06-13-2015, 05:36 PM   #17
Icy J
im a car
Icy J's Avatar
Hong Kong
736
No since the sportline models don't have changeable diffusers (not ones compatible with the M235, anyway)
2addicts
