BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > "Unable to open COM4"
      12-24-2007, 12:03 PM   #1
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
There are no conflicts (although I didnt restart my laptop after freeing up that port). Connect it to my PROcede and try to go online (power is on in my car) and it says unable to open COM4. I was also able to get the drivers for the cable installed via the CD. Suggestions?
      12-24-2007, 12:19 PM   #2
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Drives: '07 335i Sedan
Are you using the right COM port? Also, if you switch to a different USB port it will have a different COM port than the other USB ports you used. Your COM port isn't necessarily going to be the same one in Vishnu's instructions. Try selecting a different COM port in the PROcede software.
To determine your COM port: on your computer go to your desktop and right-click the "My Computer" icon. Select "Properties" then from the "Hardware" tab select "Device Manager." Next go down the list till you find "Ports" and expand that (click on the +) to see the ports you have (one of them might name the cable and be obvious off the bat)... look at the COM ports listed. Chances are one of these are the ones you'll need to be using... so go back to the PROcede software and try one of the ones you just found listed under Ports in the Device Manager... keep changing them based on the ones you found and with each change try connecting to the PROcede.
Hopefully your issue is simply using the wrong port...
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods:
PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar
Installing soon: Rear Power Outlets (Happy Robot mod!)
      12-24-2007, 12:36 PM   #3
ontopofm
76
Drives: stock
select COM first b4 plug in the usb cable
      12-24-2007, 02:26 PM   #4
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
That fixed it...thanks!.
No issues with Radio Shack cable here...
      12-24-2007, 04:36 PM   #5
cn555ic
cn555ic's Avatar
Drives: 335i
I am glad u got it working!!
      12-24-2007, 05:05 PM   #6
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
Thanks, "buddy"..
Nice edit.
      12-24-2007, 06:23 PM   #7
Driver72
Drives: 335i - to new owners now.
When I went online, I couldn't get Comm 4 either, but went to Comm 3 and had no issues with that.
I think I saw someone else use Comm 3 too.
Does it matter which Comm you use to connect with?
      12-24-2007, 06:30 PM   #8
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Doesn't matter which, just as long as the one you select corresponds with the one your USB cable is plugged into.
Mods:
