User Map changes seem ineffective
12-26-2007, 06:51 AM | #1 |
Rep 833
This seems odd.
After filling my car with higher octane fuel (100 RON / 94.5 AKI), I decided to lift my boost from 90% through the User Map. First I tried 92% then 94%. The funny thing is, my boost level on the data log did not change during my test. It continued to hover around 14.5 psi be it 90% or 94%. My boost maximums are very flat and consistent. My method: Change the torque map values throughout the rev range, hit Apply and then OK. (The settings are retained the next time I view the torque settings). I am currently running 2.02 12/19. Otherwise car is a stock Steptronic. Am I doing something wrong here? Cheers, CaptOz |
12-26-2007, 11:17 AM | #3 |
Rep 4,484
"load map" is for uploading a new version of a map, if I'm not mistaken.
What CaptOz did sounds right to me as that's what I've done and like him, it retains those settings if I close the User Software down and then reopen it back up and click on "user adjustable torque settings". Maybe a couple other people or Shiv can chime in here, but your boost levels should go up with the % increase changed. |
12-26-2007, 11:23 AM | #4 |
Rep 2,573
Drives: AW DCT M3
Yea, if ypou were to hit load map, you would reload the map with it's default tq values...
+1 on Driver72 instruction...
12-26-2007, 11:40 AM | #5 |
Rep 179
Set the new torque ratings then save the map under a new name then select that file when you "load map". Works great for me then you can name new torque setting maps and make adjustments as needed between maps.
12-26-2007, 12:28 PM | #7 |
Rep 153
After changing the torque values and hitting the "ok" button, the software doesn't seem to write/update to the Procede even though it's connected.
I use load map after I'm done with changing the torque values. Hope I'm doing the right thing here.. |
12-26-2007, 12:53 PM | #8 | |
Rep 4,484
You may be, and we may be doing it wrong. Like LuckyD said, I just hit "apply" and then "ok". But as you stated, it doesn't go through the Uploading % values or anything at the bottom of the screen. I just close the window and then re-open it to see if the changes were made, sure enough, it shows the new values in the window, but they very well might NOT have uploaded or changed the map. |
12-26-2007, 12:55 PM | #9 | |
Rep 4,484
For us slower fellows, can you explain the step by step as to what you do to save the new map with a new name AFTER changing the torque settings? And then how we "upload" that newly named, newly saved map? Thanks |
12-26-2007, 01:01 PM | #10 |
21
Rep 384
Haven't done this yet but I would think you just click on the "Save As" option under File. Saves as a PCD so I would think it's the same.. Maybe I'll try it this afternoon to see if that's it.
12-26-2007, 01:04 PM | #11 |
Rep 153
Another way to go about it:
1) Use "File" & "Open" on the map you wish to load to procede. 2) Open the User Torque Tables and change values as desired. 3) Click "Save as" and save the altered torque values as a map with a new name.. example "v2.0.2-94.pcd" 4) Use "File" & "Open" on the newly saved map. The map should load / software should show the loading process (0-100%) at the bottom. |
12-26-2007, 01:05 PM | #12 |
441
Rep 18,331
after setting the values, goto file on the left hand side and it "save as" When you press that it will prompt u that the file already exist, either you save the new setting to the original file or you type your own file name example "V2.02 updated" then hit save and you will have it saved...To check if the setting are right just go offline with the procede and hit the file again and load the new file you just created or overwrited and check the settings
12-26-2007, 01:08 PM | #13 | |
Moderator
270
Rep 4,481
- press / click "apply" - press / click "ok" Test whether the change has been successful by exiting the program, starting it again, connecting to the PROcede and have a look at the user torque values. They have to be changed now. File-Load is used for loading new map's. |
12-26-2007, 01:12 PM | #15 | |
Rep 4,484
That's what I thought too. But to be honest with you, it's really hard to tell the difference between the power settings. However, on the dyno the other week, when I'd just change the settings, hit apply and then ok and then redyno, it showed a bit more power each time after doing this. But it would be nice to have the software "upload" it by showing a 0-100% completion at the bottom of the screen after you hit apply. |
12-26-2007, 01:13 PM | #16 |
Moderator
270
Rep 4,481
12-26-2007, 01:14 PM | #18 | |
Moderator
270
Rep 4,481
12-26-2007, 01:26 PM | #19 |
Rep 4,484
I'm at 91% till 2000, then low 92% till 3500, then mid 92% till 4000, then 93% from 4000-6000, then back to mid 92% at 6500, then low 92% at 7000.
Even though I'm on 91 Octane now, I'm going to dyno at 92 octane tomorrow so I can compare with my dynos on 92 Octane from 2-3 weeks ago. |
12-26-2007, 01:29 PM | #20 | |
441
Rep 18,331
12-26-2007, 01:48 PM | #21 | |
Rep 4,484
I spoke to him personally on the phone about it, since I told him I didn't want as much torque in the low rpm range but wanted about 14.5 psi in the upper range (I know he said we can do up to 15 psi, but I want to play it a bit safe, for me, I say 14.4 psi on just over 93% settings). I also wanted to taper it off a bit in the last 500 rpms...again to play it a bit safe. He gave me the ok after speaking to him personally. Car runs great with that set up. Allows for good launches without too much torque below 3500 rpms. Power comes on smooth and really rips in that 4000-6500 rpm range. I'll see how it does on the dyno, and might make some small corrections based on that. Again, a bit less torque than v1.47 gave below 3500 rpms, but the mid and upper range advantage of v2, all the while being a smooth gradual climb in power. Again, with MY car, those settings feel good, now I'll see how it does on the dyno and datalog it too if I can. |
12-26-2007, 02:18 PM | #22 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Regarding User TQ setting. All you have to do is make sure you are online with the PROcede, change the numbers in the table and hit "apply". The update is instantaneous (no 0-100% status bar). No need to load anything or press any other button. Very simple.
Shiv |
