2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Advice on MP Front Spliter Install
      09-22-2014, 09:05 PM   #1
jmr0311
jmr0311's Avatar
248
Drives: 22' G82Cx Velvet Blue
I'm getting my M Performance Front Spoiler at the end of this week. I want to see if some of the forum members that have done the installation themselves can help me get prepare to do the installation. I was thinking like a DIY posed in the forum perhaps.
      09-22-2014, 10:51 PM   #2
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
There's actually an installation instruction manual from BMW. I think you should ask your seller to provide it. I bought mine on ebay (Kelly BMW from Ohio) and those guys were so great to send me the instructions, which I just printed and hand them to the shop that did the installation.
      09-23-2014, 05:04 AM   #3
Spieltag
Drives: 2015 BMW m235 AW/KR-B
2015 BMW m235  [0.00]
It's super simple, just make sure to unscrew all of the screws that line up with the piece before you remove the tape. Note which screws are long and which are shorter, you may have to reuse one or two washers as well.
Next begin to peel all the double stick tape back about a centimeter then tape the tails to the front of the mpsplitter with painters tape, this will allow you to place it and peel the tape.
Wipe down the entire front splitters with the provided alcohol pads. Push the entire splitter on until it kinda clicks into place, you can be pretty firm in your application. Then starting with the tops and working out wards from the center, peel off your tapes trying to keep the angle as sharp as possible in the direction you are peeling (don't pull at 90 degrees or you risk snapping the tape). Do the large bottom corner panels last.
Finish by screwing everything in.
      09-23-2014, 11:03 PM   #4
2fast4utoo!
Drives: M4
Hey man, could you those instruction here please? Thanks in advance!
      09-24-2014, 09:23 AM   #5
AlexGT
AlexGT's Avatar
Guatemala
420
Sure thing man, you can follow this thread I posted on the DIY section:
http://www.2addicts.com/forums/showthread.php?t=1039167
      09-25-2014, 06:09 PM   #6
jmr0311
jmr0311's Avatar
248
I just receive my M-Performance Front Splitter. Do you guys have any idea how to use what is on this picture?
      09-25-2014, 09:29 PM   #7
Spieltag
The only thing my friend who does body work said those might be used for is to black out the seam lines if you say had a WHITE body car and then kept the MP splitter black. They would line the "splitters" where they attatch to the front fender, and then the fender would be taped on top. It would black out the seam so you don't have a weird trim line from the cars color and the MP part.
      09-26-2014, 06:01 AM   #8
jmr0311
jmr0311's Avatar
248
I have an AW M235i and I'm planning on leaving the front splitter unpainted, just as it comes from the manufacturer. You suggest I should use the items in the picture then. Can you give me a little bit more details on how to use them, if your friend was kind enough to share that with you.
      09-27-2014, 11:15 AM   #9
2fast4utoo!
Drives: M4
Thank you! You are the man!
      09-29-2014, 08:46 AM   #10
AlexGT
AlexGT's Avatar
Guatemala
420
Anytime bro!
      10-02-2014, 06:12 AM   #11
Piper666
15
Drives: 2014 218D (sold) 2015 M235i
I did mine myself. took less than 10 mins. Abit of soapy water on the lower bumper will allow for the tape to slide without sticking instantly as you push it into place.
Left mine unpainted against the red
      10-05-2014, 10:00 AM   #12
jmr0311
jmr0311's Avatar
248
Results of the MP Front Splitter installation I did a week ago on my M235i.
2addicts
