09-23-2014, 10:56 PM | #1 |
Rep 47
Switched power inside the passenger compartment
Searching out ideas/options for switched power inside the passenger compartment for the F82 M4 to run a radar detector, laser jammer and maybe dash cam.
The fuse box is now under the hood, which makes using the favourite method of an "add a fuse" difficult. (Actually the fuse box access in general is difficult with the alum bracing.) I think one could route into the cab from the fuse box if you could get access to the underside of the fuse board. Which I could not. It wiggles like you could remove it, but I couldn't get it out. Not sure if it can even come out. V1 has a cute "Savvy" device that uses the OBD port. Not sure if there is a switched source from the truck. I have figured out how to get to the 12V power plug at the front of the centre console but it doesn't seem "switched" in the usual sense. Seems to stay on for a bit after I leave the car, and switches on soon as the door is open. Right now I have a "mirror tap" supplying the radar detector which is mounted high. For the jammer I would want power buy the glove box/console. I guess I could run a line allllll the way down from mirror via the A pillar, but would have to see if the load of the detector and jammer would be to much. Advice? Ideas? Tx Odd Jobs |
10-06-2014, 01:11 PM | #2 |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
i used the 12v outlet underneath the passenger side dashboard in my F30 to wire up my V1. The F8x has one in the same spot. Just drop the panel and then you can splice into the wires.
It will stay on for a moment after you get out of the car and will turn on when you unlock the car but that didnt bother me. |
10-06-2014, 01:15 PM | #3 |
Rep 741
Drives: F80 M3 in Sakhir Orange
My installer ran a separate fused switched wire from the fuse box in the boot. He said that's the best way as it completely avoids any can bus problems.
BTW, my Valentine 1 is on it, and despite deactivating the rear K band sensor, I'm still detecting rear K band as I drive.
F80 M3 Sakhir Orange with DCT and TV collected 21 June 2014.
10-06-2014, 01:18 PM | #4 |
Rep 1,309
Drives: YMB M3
i killed my kband and well on both the front and the back and dont get any warnings for K at all.. I think there was 2 areas on the V1 programming i changed.
10-08-2014, 09:42 PM | #5 | |
Rep 47
Im gonna work on it this weekend. Odd |
10-08-2014, 09:44 PM | #6 |
Rep 1,309
Drives: YMB M3
weird..sometimes i dont understand the differences between cars in different markets. there is no way the Canadian Government gives a shit if there is a power outlet there.. why BMW chose to remove it is beyond me.. You can always buy the V1 Savy...its applicable on any car.
10-12-2014, 01:53 PM | #7 |
Rep 47
In the end I piggy backed onto the truck 12v power outlet with an "add-a-fuse" via the trunk fuse box.
Ran a lenght of wire under the rear seat, and door sill to the kick panel then finally the consol. I didn't want to splice into the front consol 12V power supply because the car is a lease. There is a connector there, and if I could source the connectors, I could have made a short jump cable to splice into....but in the end I went trunk. Maybe I will post some pics of the install. Odd |
