09-23-2014, 11:54 PM | #1 |
Rep 2,028
Drives: INDIVIDUAL F90 M5C LCI
Valentine One Hardwire
Just received my Valentine One hardwire kit in the mail. Has anyone else hardwired their V1 into their car? Is there anything special I should be letting the tech know about the install? Is it just like any other car when installing?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
09-24-2014, 12:32 AM | #2 |
Rep 47
I just did the "Mirror Tap" cable method for my Escort 9500.
Other option would be "invisicord" Seems to be working ok. In my E92 M3 I ran the hardwire kit to the glove box fuse box using an add-a-fuse. But now the fuse box is under the hood. Odd |
09-24-2014, 08:22 AM | #3 | |
Rep 1,162
Bish |
09-24-2014, 01:39 PM | #4 |
Rep 607
I hardwired mine with the supplied kit. Unfortunately there was not screw I could tap into for the ground connection so I bought another wire tap at radio shack to tap into the ground wire. Everything else I did per the DIY posted on here.
09-29-2014, 08:41 PM | #5 |
132
Rep 370
Valentine Savvy is the way to go. You can shut off those annoying false alarms at a grocery store by setting the Savvy to ignore them. The thumbwheel has eight settings from 15 to 65 mph. Choose one, or select the AUTO setting to mute all alerts, or the NONE setting to switch off automatic muting. It's [retty cool and plugs into your OBD port.
http://f80.bimmerpost.com/forums/sho...=Valentine+DIY |
09-29-2014, 11:36 PM | #6 | |||||
Rep 2,028
UPDATE: So I went to my local Sound Advice to have my Valentine one hardwired into the ignition. Ive had this same procedure done on my last 2 cars at the same place. Long story short, the tech came out into the waiting room and told me he did not want to start messing with the car and its fuse box simply because there was absolutely no guide available online for the 4 seris/M4. He said the only thing he could find was that the car had "low currency" and he didn't know which color wire to hook in to?? Anyone else experience this issue? For those of you who have your V1 hardwired into your ignition switch, which wire did you hook into?? BROCHOP
09-30-2014, 03:36 PM | #7 | |
Rep 504
FSHNGRY2336.50 |
09-30-2014, 09:06 PM | #9 |
132
Rep 370
Brochop...follow what I said. If you dont want to do it like yourself then have the BMW mechanic wire it up via the same method I provided a link to. very easy and it took him less than 20 minutes. He did pop off the a-pillar though rather than stuff it.
Call Craig (don't know hiw last name but he is my mechanic) at Performance BMW in Chapel Hill NC and he can talk you through. He is pre-med and very enthusiastic to help. Just mention that I am the guy with the MW M4 he did the MPE and CF options for last weekend. |
09-30-2014, 09:41 PM | #10 | |
BimmerPost Supporting Vendor
8115
Rep 18,808
Drives: BMW
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
10-01-2014, 07:30 PM | #11 |
Facetious
109
Rep 530
Just get the Savvy and the problem is solved. Why pay a technician if you can do it yourself in 5 minutes.
Current: '15 BMW M4 (6MT), '08 HD Dyna Street Bob
Previous: '06 BMW 330Ci; '06 Mercedes CLK-350; '04 Acura TL A-Spec; '95 BMW 318ti; '92 Mercury Cougar; '94 Honda Accord |
10-03-2014, 10:27 PM | #12 | |
Rep 47
So right now I have my 9500 tapped into my mirror plug, and my Laser Interceptor plugged into 12V console outlet. I am thinking of running a power cable to the second fuse box in the trunk. Tomorrow I will see if I can find a switched circuit in the trunk, then do a "add a circuit". I could use the accessory plug but it comes on whenever the door is opened, and stays on for a bit after the door is closed/locked. BUT you would think that using the power outlet would not interfere with apparently very sensitive electronics. Odd. |
