Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      09-27-2014, 06:43 PM   #1
yamamoto
Drives: 2015 F80 YMB/SO
Drunk driving
The electic steering in the m3 feels fine when I'm carving turns, but just going straight down the road requires constant inputs, that it makes me feel like I'm drunk driving.
I have over 2000 miles on the f80, I love the car, but the e90 m3 I just returned today sure has a much better "connected" steering feel.
      09-27-2014, 06:46 PM   #2
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
For me, Sport mode for the steering is much better than Comfort mode.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      09-27-2014, 06:51 PM   #3
SOM3
43
Drives: SO F80
I think there might be something wrong with your car, I have not experienced anything close to what you described.
Take it to the dealer.
      09-27-2014, 06:55 PM   #4
kitesurfer
kitesurfer's Avatar
543
Drives: Round n' Round
Do you have 18's? I thought I saw posts where guys who had 18's were experiencing similar issues
      09-27-2014, 06:58 PM   #5
jeff4598
Drives: 2019 M2C HS, DCT, much Dinan
Wheel size is not an issue as outside diameter of tire is essentially the same either way.
      09-27-2014, 07:00 PM   #6
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
That is likely an alignment issue, or something funky - that is not a measure of steering feel.
DSC_3369 by Kit W, on Flickr
      09-27-2014, 07:02 PM   #7
solstice
Drives: 2015 M3 6MT
Is it in comfort mode you feel like this? For my preferences the steering comfort mode is sh*t. It brings out all the bad aspects of EPS. Thank you BMW for making the best mode "sport" default so I never need to drive in comfort again, ever. I'll pretend it's not there. In sport it's the best EPS I've driven after maybe the 991. It's still fairly numb but the rest ( weight, accuracy, stability etc. ) is so good that overall it's acceptable.
If however your car isn't rock stable in sport mode you have an issue as others have said. It should track like an arrow and be relaxing hour after hour through any conditions at high speed. Mine is even if it's torrential downpour. Switch to comfort and it's complete rubbish.
      09-27-2014, 07:05 PM   #8
chiplee
chiplee's Avatar
307
Drives: 2015 M3
I feel the same way about the electric steering in our F15 X5. At highway speeds it's a handful if conditions aren't perfect. I'm considering having toe in added.
      09-27-2014, 07:08 PM   #9
yamamoto
My car has 19"s. Regardless of what steering mode I'm in, it has a very numb feeling for the first 5 degrees of rotation on the wheel. Beyond about 5 degrees, resistance on the steering wheel builds and feel normal.
I do think there is something wrong with my adaptive suspension. There is no difference in ride quality between comfort, sport, or sport plus. In my E90 m3, I could definitely feel a difference. Can somebody with adaptive suspension comment on what I should expect.
Thanks
      09-27-2014, 07:10 PM   #10
solstice
Drives: 2015 M3 6MT
I've got passive suspension so I can't help you there.
      09-27-2014, 07:11 PM   #11
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Does it want to pull right a little bit when going down a straight road? It's possible your alignment is slightly off. Mines was off a little and the dealer did an alignment under warranty.
      09-27-2014, 09:44 PM   #12
KASM3
Drives: 2015 M4
I'm not experiencing this. Tracks straight as an arrow!
      09-27-2014, 10:00 PM   #13
SakhirM4
SakhirM4's Avatar
2015 BMW M4  [8.76]
Do you have an F8X?
      09-27-2014, 10:04 PM   #14
Andrew115
Andrew115's Avatar
328
Drives: Silver Bullet
I would check the alignment.
Today I got my 19s. I had put 600mi on the 18s before they arrived. They definitely drive and feel different. I didn't think I would notice anything and wasn't looking for any change but after about 30miles I started questioning what was different and realized it had to be the wheels.
      09-27-2014, 11:31 PM   #15
myzmak
Advocatus Douchebagus. Sex Marxist.
myzmak's Avatar
2415
Drives: Lucy.
2015 F80 M3  [10.00]
2013 MB E350 Wagon  [10.00]
Is it because you are drunk when you are driving? That would explain it......
Drivin' Lucy
      09-28-2014, 08:26 AM   #16
Want2BS8ed
Drives: 2006 330xi/2015 M4 Convertibl
Andrew, can you describe the difference?
No issues with tracking on my 18's. Sport and Sport+ certainly felt stiffer and progressively more responsive than comfort mode. The tell tale sign was the occasional manhole cover - hardly felt in comfort, but most definitely there in Sport+.
M
      09-28-2014, 08:33 AM   #17
Kief
Kief's Avatar
4433
Drives: '24 iX50; '23 i4 M50
That's not encouraging Chip.
Not to jack the OPs thread, but with the X5, does the steering tighten up in Sport?
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
      09-28-2014, 11:14 AM   #18
chiplee
chiplee's Avatar
307
Drives: 2015 M3
I don't think it's a thread jack since it goes to the general electric steering quality. I'm starting to think I can actually feel that I have a front wheel out of balance. If I hit a bump just so there's a noticeable wobble from the front end that feels rotational, like one of the wheels is out of balance.
I feel it tighten up progressively as speed increases. I'll have to experiment with other modes.
      09-28-2014, 11:30 AM   #19
KASM3
Drives: 2015 M4
Do you have an F8X?
Yes f82 with active susp and 19's
      09-28-2014, 11:40 AM   #20
Keto
Keto's Avatar
Drives: F80 M3
2015 BMW M3  [10.00]
Update your "drives:" brah
2015 SO/SO MT M3 :: Exec : Lighting : Adaptive : HK : CF trim : Full leather : DAP : Black 19's : sunshade
Crystalline tint 40%/70% on windshield : M performance mirrors, spoiler, splitters : Status Gruppe CF lip : RKP diffuser : Fully dechromed
Bavsound Stage 1 : V1 Savvy hardwired : Self-coded
      10-01-2014, 07:47 AM   #21
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
The wheels size could very much make a difference. The tires will perform closely, but not identical, because they are not the exact same tire. Even in the same size, tires have quite a bit of variation from one to another, especially for things like steering pull/wander and vibrations.
Anyway, get your alignment checked at a BMW dealer first.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
f80post
