TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > uninstalled procede and got half engine and code 238
      12-27-2007, 11:17 PM   #1
mattnagano
Drives: m2
I tried installing procede didnt go well...now i uninstalled the procede and i get half engine light and code 238... any help would be nice i checked wire 10 like it says 10times and its in the correct place
thanks
matt
      12-27-2007, 11:23 PM   #2
cn555ic
cn555ic's Avatar
Drives: 335i
are u sure you placed wire 10 back into that slot because 12 i think it open also, where u might have put it in the wrong place...
      12-27-2007, 11:46 PM   #3
mattnagano
Drives: m2
yes i thought that also so i did it like 5 times....my friend is here with me trying to figure it out and he checking my work... i dont kno wats wrong according to chart thats the only thing it could be....
sigh.....
      12-28-2007, 01:09 AM   #4
Soni
Soni's Avatar
219
Drives: Just a car
2007 335i Coupe  [9.00]
try to disconnect the battery
      12-28-2007, 02:48 AM   #5
mattnagano
Drives: m2
i disconnected the battery codes go away but car still feels like its in limp mode...then i drive a bit(feels slower then my civic) and half engine comes on and service soon...
just drove around the block and car has almost no power at all... i have to almost floor it to make it move(hickups)...stalled a few time cause of it...
could it be a fuel pump?
any info would be appreciated!
      12-28-2007, 03:05 AM   #6
LACA335i
LACA335i's Avatar
Drives: E92 335i coupe Black AUTO
2007 335I SEDAN  [0.00]
thanks
matt
According to my BMW manual, DTC 242 (P0305) is "Misfire, cylinder 5". There are two things that can cause a misfire in a particular cylinder, bad secondary ignition component or a clogged or bad injector. DTC 242 does not, specifically, point to a bad coil or injector. It just says there is a misfire in cylinder #5 and it's up to us to determine the cause.
By swapping ignition coil #5 with ignition coil #1, and coming up with the same code, you have proved the ignition coil is not the problem. If it were the ignition coil you are correct in that you would now get a DTC 238 (P0301).
      12-28-2007, 03:08 AM   #7
335vince
Drives: You Crazy
P0238 Turbocharger Boost Sensor A Circuit High
      12-28-2007, 03:09 AM   #8
mattnagano
Drives: m2
??? im lost here i dont kno alot about cars...
      12-28-2007, 03:10 AM   #9
mattnagano
Drives: m2
yes po238 is the code i got with code reader...
      12-28-2007, 03:11 AM   #10
LACA335i
LACA335i's Avatar
thanks
matt
here is another link
https://evalue.internationaldelivers...ges1751_FC.xml
      12-28-2007, 03:12 AM   #11
mattnagano
Drives: m2
what does boost sensor a high mean?
      12-28-2007, 03:16 AM   #12
335vince
Drives: You Crazy
i wish i could help you more, but all i have are the error codes list! try the vishnu tuning fourm or wait until the morning. someone with more expeirience will help you.
      12-28-2007, 03:18 AM   #13
mattnagano
Drives: m2
i been going on both forums back and forth still cant figure it out on vishnu site it says if i get the code 238 its slot 10 and i checked that many times already..
      12-28-2007, 03:20 AM   #14
LACA335i
LACA335i's Avatar
it mean something wrong the sensor. it could be the wire connector or it could be Faulty sensor itself.. or the could be you are running too high of a boost. the sensor telling you to set it back. You need to have someone with a DMM to test out how high the volt vs the oem spec.
      12-28-2007, 03:21 AM   #15
mattnagano
Drives: m2
huh?
      12-28-2007, 03:24 AM   #16
mattnagano
Drives: m2
sorry that "huh" it wasnt for you didnt mean to post that i understand what your saying..
      12-28-2007, 03:30 AM   #17
mattnagano
Drives: m2
i tried drving just now and still code po238 and no zero power and hickups and stalls man this sux u think trying to install procede caused this? or just bad fuel pump
      12-28-2007, 02:07 PM   #18
mattnagano
Drives: m2
i woke up this morning and drove my car and the car still has the same probs....can anything think of anything y this is still happening?
thanks
matt
      12-28-2007, 02:23 PM   #19
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
did you ever bypass the rear boost solenoid per the procede instructions? if so, you need to put that back...
      12-28-2007, 04:56 PM   #20
mattnagano
Drives: m2
yup aleady put that back to stock car runs now just in limp mode and cant get rid of it....
      12-28-2007, 05:40 PM   #21
mattnagano
Drives: m2
help car still has the same prob...i can get rid of codes with code reader but once i start driving they come back half engine service soon.... car has no power turbos not working at all....
      12-28-2007, 05:40 PM   #22
mattnagano
Drives: m2
matt
