HD TV advice
12-29-2007, 03:50 AM | #1 |
Rep 9,218
HD TV advice
We've still got a Toshiba 32inch CRT telly that I bought about 8 years ago.
Got a bit exited about all the reduced prices on LCD's yesterday and ordered one of these: Samsung LE40M87BDX http://www.amazon.co.uk/exec/obidos/...ctiveda3017-21 Reviews seemed really good and I'm very pleased with the 22inch Samsung monitor I bought for the computer earlier this year. Questions though : 1. Is it worth getting Sky HD and if I get it do I also get channel 4 and BBC HD at the same time? 2. I have an upscaling DVD player (although only up to 1080i), which I'm going to connect via HDMI. Does it matter how much I spend on a cable? |
12-29-2007, 06:01 AM | #2 |
Rep 686
Drives: E93 320d M Sport, E81 116d SE
Garage List 2006 120d SE [0.00]
2007 335d A M Sport [0.00] 1998 M3 Evo [0.00] 2002 330d Sport [0.00] 2004 330d Sport [0.00] |
Simon
If you get Sky HD you do get Channel 4 HD but I've only seen a few programmes schelduled in HD format so far. I run my DVD player through the component input and I can't tell any difference between a disc and an HD broadcast (disc dependant of course). Regards Chris
Previously: 2007 335D MSport E90 Le Mans Blue, 2004 330D A Sport Silver Grey, 2002 330D A Sport Saphire Black, 2001 320D SE Touring Titanium Silver, 1998 M3 Evo Techno Violet, 1996 328i Sport Montreal Blue, 1994 325i Coupe Red, 1989 325i Sport 2 door Dolphin Grey,1986 325i SE 4 door Lachs
12-29-2007, 07:33 AM | #3 | |
Rep 741
1) Sky HD is yet not a source for true 1080p video, so it will not exploit the full potential of your new TV. Some Blu-ray discs are recorded in 1080p format and on a 40" panel you can fit all 1080 lines without any rescaling/omission. The PS3 also outputs 1080p with some games. Many other devices, including Sky HD, switch between 720i and 720p. 2) Yes. You can get 50Hz and 100Hz HDMI cables, and there is vast difference in signal deterioration and purity. If the transmission distance is 1m then you have nothing to worry about, but for a bleed free/interference free picture, a £50 cable should do nicely. I can point in the right direction if you want. The other way to connect is to use component video cables, but this interconnect is analogue and therefore inherently inferior to HDMI. It also does not carry an audio signal, leaving you to use phono jacks or coaxial to carry the sound. Sky HD does transmit HDCP (High Def Content Protection) signals to prevent some of their prime content from being recorded. HDCP packets can only be carried via HDMI compliant connections. Therefore, if you do use component video cable to connect a sky HD box to recording device, the HDCP anti piracy regime is effectively circumvented. |
12-29-2007, 09:03 AM | #4 |
Rep 468
Thats a top TV, I think you'll be very pleased with it.
As said elsewhere, cable is important. I have SkyHD and true HD programmes look amazing, normal progs tend to look better, but not as good. I would say HD is worth it. I use a cheap DVD upscaler and I do notice a nice difference watchng normal DVDs, it was worth every penny. Enjoy your new TV. |
12-29-2007, 09:46 AM | #5 |
Rep 2,426
Drives: E93 335i M-sport
...ok electronic geniusesss...
Why if it's a digital signal, (HDMI that is) does it need a dhielded or expensive cable ? seriously I'm interested to know... I spent over 200 quid on the 3 heavy duty hand made ones I use (PC to amp, DVD to amp, amp to LCD panel), so am just as much in the dark. |
12-29-2007, 10:01 AM | #6 | |
Rep 741
As far as the differences between cables are concerned, factors such as cable bandwidth, speed, shielding and length determine price. |
12-29-2007, 10:15 AM | #7 |
Rep 4,190
Drives: F30 335d M Sport, F15 X5 40d
NFS, I have Sky HD with a Samsung HDTV (32") LE74BDX. I am very impressed with HD, particularly the Sports. There seem to be a few more HD channels than there were a few months ago, and likely to be more and more added as the months/years go by. I am pretty sure that the Sky HD Box does not support the 1080i format, it is 780i (?), that is the question I asked the sky installer.
I have the Sky Box and TV connected by an expensive HDMI cable (it cost £90 if memory serves), I have no idea if it makes a discernible difference to picture quality. I have no idea what a DVD 'upsacaler' is! I play DVDs through a Samsung HDMI DVD surround sound system. I saw a BluRay DVD picture today in Comet, coincidentally on a Samsung 32" LCD, it looked fantastic, the colours and picture quality were superb. |
12-29-2007, 10:17 AM | #8 |
Rep 2,475
...I've never understood this "need good quality HDMI" either. As it is just a bunch of 1s and 0s going down the cable, how will interference affect it? Only scenario is that it will degrade the way a freeview transmission deteriorates in bad weather - i.e. not at all until actual data starts to be lost, leading to missing blocks etc. on the screen and eventual loss of picture entirely. I'm not sure I understand how a cheap HDMI cable will actually loose any information, i.e. degrade the signal at all?
This assumes that HDMI is a real digital signal which is decoded in the reciever - is this not the case? |
12-29-2007, 02:30 PM | #9 |
Rep 9,218
I've jumped the gun and ordered a 1m cable for £19.99 from Amazon :
http://hdcable.co.uk/products/hd-cables/hdplathdmi/ |
12-29-2007, 05:08 PM | #10 |
Rep 7,519
Drives: 2009 E90 335i MT
Damn, whatever happened to good old fashioned 2-core flat antenna cable?
BTW, that's a rhetorical question.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
12-29-2007, 06:04 PM | #11 | |
Rep 2,046
Blueray DVD's really are fantastic, I'm slowly building up my collection. Sky HD is good too. Once the writers strike is fully over in the States we should see lots more HD programs coming over. Heroes/24/Lost are all broadcast in HD.
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport |
12-29-2007, 06:28 PM | #12 | |
Rep 2,426
ahh good explanation.. fair enough Glad i spend me pennies now... SJ |
12-30-2007, 04:03 AM | #13 |
Rep 9,218
Now .. talking about HD broadcasts .. I have another question.
I have a divx capable DVD player (toshiba SD_360). Which will happily play any movie I download from the net in DivX format. Except for the latest HD Divx stuff. I've got Heroes series 2 and 300 in full HD on my PC. Now How can I play those through my new display (short of physically connecting it to my PC). By the way, my PC monitor has a resolution of 1680x1050 and 300 looks stunning on it. |
12-30-2007, 04:18 AM | #14 |
Rep 896
I was going to say that I couldn't find "cheap" HDMI cables when I was looking. It cost me £50 for a DVI to HDMI cable...
Keene Electronics are good, Screwfix do a good range now. I have a Samsung LE40R87BDX. I'm well happy with it. I only have BBC HD through cable, and when there is something broadcast that is worth watching, it's very good. Certainly when I switch the XBox off and watch some telly, the picture looks crap :-) I would have a look on www.avforums.co.uk for a settings thread about your telly to get the best from it. has it got an SD card slot, or USB port on it?
Phil
12-30-2007, 05:36 AM | #15 | |
Rep 7,308
Drives: see above.
NFS - watch out for the free HD broadcasts coming soon (NOT SKY!)
12-30-2007, 05:58 AM | #16 | |
Rep 468
12-30-2007, 09:01 AM | #17 | |
Rep 9,218
Everything else is less than 720, so I think this is the issue. |
12-31-2007, 07:49 AM | #18 |
Rep 267
cant you set the sky box to 1080i via the services or set up section,ive tried this a couple of times as the sky fitter set it to 1080i when he installed it,but i have a sony kdlv40a12u which is 720 so i set back to this(im no whizz kid with this stuff though).
i also read an article in one of the magazines,who did an in depth test on various expensive cables,and the upshot was that there was not enough of a difference to justify the cost. |
12-31-2007, 08:16 AM | #19 | |
Rep 7,308
Drives: see above.
http://www.ebuyer.com/product/130513
12-31-2007, 08:22 AM | #20 |
Rep 468
Yes you can set Sky to 1080, but the source signal is 720p so it won't really make much of a difference.
12-31-2007, 08:40 AM | #21 | |
Rep 793
Drives: F30 328i
Behold! F30 328i M-Sport - Tanzanite Blue with Opal White Leather
12-31-2007, 08:50 AM | #22 |
Rep 2,353
Drives: 2009 Z4 sDrive 23i
Is Sky likely to go to 1080p at some point?
E89 Z4 sDrive 23i... for the more discerning driver
