Procede user adjustable settings
12-29-2007, 08:12 PM | #1 |
Rep 142
Hi Guys,
What's the right procedure to update those values? Do you have to reload the map? or just update the values while connected click apply and then ok? can you do it while the engine is running or only with ignition on? thanks |
12-29-2007, 08:19 PM | #2 | |
Rep 4,484
Select the "user adjustable map" section. Enter values into the rpm ranges. Click "Apply" Click "OK" then close the window. Then ALWAYS double check yourself by reopening the "user torque settings" window and look at each rpm value to be sure it's correct. I once almost accidently set a value at 99.3xxx When I meant to enter 93.xxx, but accidentally hit the 9 button twice. If the values are what you wanted, then you are good to go. You can do it with the engine running, but I would turn the engine off and just do it with the ignition on, but engine not running. |
12-29-2007, 09:36 PM | #4 |
ocasionally in crisis
52
Rep 2,358
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
