Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > JB "Hot Pill" update
      12-30-2007, 12:06 PM   #1
Terry335
Drives: 335i
Hi Gang,
We've been testing the 93+ octane hot pill now for a few weeks, and so far everything is going well. Not a single limp reported when coupled with the normal JB2. Reported boost gains have been .5-1psi over the normal JB2, and horsepower gains have been 8-13rwhp. Low end torque is also improved 10-20rwtq.
We have not been able to do what I consider sufficient hot weather testing, so for now I am going to suggest the hot pill be removed during the summer months. I also have not done sufficient high altitude testing, so for now I am going to suggest the hot pill not be used above 1500' altitude. I have reason to believe that high temps and/or high altitude could result in a limp, so just be aware of it. On the plus side the pill is pretty easy to install/remove in the JB harness (no need to unplug DME connector). And if it doesn't work out for you we will take them back.
Using the hot pill with the JB2R has been a mixed bag. Most have not had an issue when used with 96+ octane, but at least one user has been getting a limp code with it. When used with the R boost spikes to 15psi and holds around 14psi, so it really requires your ignition system, etc, to be in tip top shape. Some users have been getting away with the R on 93/94 pump gas, but when the hot pill added you will get a limp. Don't try it. I suggest you run as close to 100 octane as possible with the JB2HR.
Testing with downpipes on 91 octane is still underway.
      12-30-2007, 12:19 PM   #2
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
Terry I put the jb2 back in the car yesterday and also put on the H pill.I have to say I am very impressed.The pull is perfect! Plenty of power down low and up top.The car is a monster at any rpm.IMO its a perfect mod.thanks for letting me try it and for everything else.This install went as smooth as silk.It took me about 25-30 minutes. Now I dont feel the need to get the dinan flash.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      12-30-2007, 12:19 PM   #3
AU335
AU335's Avatar
Drives: 2007 e92 335i
2007 335i  [0.00]
Thanks for the Update Terry!
I just installed the R-switch yesterday, so ill be running JB2HR Havent had a chance to test it though, b/c the place with the race gas is closed on the weekends. So you suggest runnning as close to 100oct as possible?
Also, you said people on 93/94 are getting away running the JB2R without limp modes or any problems? Do you have any power differences/estimates of the R switch on with just 93/94 octane compared to 96+
      12-30-2007, 12:20 PM   #4
catdog
13
Drives: Porsche 997S
Terry thanks for setting this straight; i am having good luck with JB2R, this tank is at 95.5 octane and with no problems in winter weather. Had it on 93 as well with no problems. I will keep everyone posted...very happy with it so far, and can't wait to try h-pill.
      12-30-2007, 12:28 PM   #5
Terry335
Drives: 335i
I don't suggest it at all but guys have done it. Not sure on the power difference, never dynod it that way. For the JB2HR the higher the octane the better!
      12-30-2007, 01:03 PM   #6
letterkills155
letterkills155's Avatar
Drives: 08 e92 335i
08 335i  [0.00]
can i buy the h pill now
      12-30-2007, 01:48 PM   #7
Rugs
Rugs's Avatar
46
Drives: E93 335i
Thanks for the Update Terry.
I'm just north of Atlanta at around 1,100 ft above sea level with outside temps a few weeks ago in the high 70's and I've had no issues with the Hot Pill.
I do plan on a mountain run in the next week or so in elevations as high as 4,000 ft. I guess I could throw in some high octane gas & leave the Hot-Pill in. Temps will probably be in the 35-45 degree range. What do you think?
"WorldsQuickest 335i E93"
SMART-Top /One-Off Opaque Vinyl EYELIDS / 30% TINT / A.C.SCHNITZER Pedals / "M" Tri-Color Wheel w/Paddles / EIBACH Pro-Kit / AKEBONA F. & EBC RED-STUFF R.Dustless Pads / Drilled & Slotted ROTORS / MIRO M6 Reps / MICHELIN PS2's / U.R.Coated DP's / CYBA-QUAD Exhaust Tips / BMS-TUNED...
      12-30-2007, 01:56 PM   #8
Terry335
Drives: 335i
I do plan on a mountain run in the next week or so in elevations as high as 4,000 ft. I guess I could throw in some high octane gas & leave the Hot-Pill in. What do you think?
Not a bad idea! While you are up there stop and restart the car if possible, there is a startup condition check I am worried about too.
Thanks,
T
      12-30-2007, 01:57 PM   #9
Terry335
Drives: 335i
Yes they are now for sale on the website, price is $15 shipped.
      12-30-2007, 02:14 PM   #10
Rugs
Rugs's Avatar
46
Drives: E93 335i
Thanks,
T
Will do, I'll keep you posted...
      12-30-2007, 02:39 PM   #11
chromerl
chromerl's Avatar
10
Drives: B/S 335i
$15 dollars
Terry you rock!
      12-30-2007, 03:03 PM   #12
stillclaimndp
Dancing Machine
stillclaimndp's Avatar
Drives: 335i e90 ZSP
wow thats cheap power!!!
2007 e90 & 1981 Corvette Predecessors: 2007 BMW 335i E92, 2006 M5, 2008 Viper SRT10 Coupe, 2005 Viper Yellow, 2006 Corvette Z51, 2009 Challenger SRT8, 2006 S4, 2001.5 Nogaro Blue S4, 2006 GTI w/ DSG, 06 Evo IX, 04 S4, 04 911x51, 03 Evo VIII, 98 Eclipse GSX, 96 GST, 92 Galant Vr-4, '70 Grand Prix Model J, '70 Nova, '68 Firebird
      12-30-2007, 03:06 PM   #13
Trill335
انا خارج الكلبه
Trill335's Avatar
9
Drives: E92 335
Are you enroute back to Auburn soon? If so here are the directions to the Sunoco in East Alabama.
Note: Once you get to the circle track; you'll need to enter the fence on the right...your reference point will be a bunch of shop bays. If someone is there...a bay should be open. At times you may have to get out and knock on the door. Ensure that you tell the gentleman that you're looking for Sunoco 100 UNLEADED.
Beware...The Gas pumps are on site at the Circle track (dirt track). Your car is more than likely too low to clear the bank. Get yourself some 5 gallon containers and have the attendant go get the fuel for you. I have issues getting in and out of the area and my car is stock ride height.
You'll save 3 dollars per gallon getting your gas at East Alabama Speedway versus getting it from Speed South. VP 100 Streetblaze is $10.00 per gallon at Speed South
East Alabama Speedway: 334-297-2588
4256 US Highway 80 W, Phenix City, AL 36870, US
Directions Distance
Total Est. Time: 40 minutes Total Est. Distance: 27.66 miles
1: Start out going SOUTH on N COLLEGE ST / AL-147 toward BRAGG AVE. 0.2 miles
2: Turn LEFT onto E GLENN AVE. 3.4 miles
3: Turn SLIGHT RIGHT onto BENT CREEK RD. 0.4 miles
4: Merge onto I-85 N / US-29 N / AL-15 N via the ramp on the LEFT. 3.8 miles
5: Take the AL-51 exit- EXIT 60- toward AL-169 / OPELIKA / HURTSBORO. 0.2 miles
6: Turn LEFT onto AL-51 / MARVYN PKWY. 0.5 miles
7: Turn SLIGHT LEFT onto CRAWFORD RD / AL-169. Continue to follow AL-169. 16.1 miles
8: Turn LEFT onto US-80 / AL-169 / AL-8. Continue to follow US-80 / AL-8. 2.8 miles
9: End at East Alabama Speedway:
Total Est. Time: 40 minutesTotal Est. Distance: 27.66 miles
      12-30-2007, 03:10 PM   #14
AU335
AU335's Avatar
2007 335i  [0.00]
Naseem, what are their operating hours? Are they opened on weekends too?
      12-30-2007, 03:15 PM   #15
Trill335
انا خارج الكلبه
Trill335's Avatar
9
Drives: E92 335
Koy,
They're usually open all day Mon-Saturday. Give them a call before making the short trip. At times I'll stop in and the gentleman that runs the pumps will be out...usually he's back within fifteen minutes or so.
      12-31-2007, 02:34 PM   #16
darvo
Drives: Blazer
Hi Gang,
Bad News!!
Just had a call from the dyno...
H pill is a big no-no for summers temps, right now here the temp was at 89degrees.(I'm located in Puerto Rico)
And the owner of the car called me and told me that A/F climbed to 12.5 and then decreased to 10-ish and even 9-ish.
The car before had 318hp with JB2 and with H-pill installed it gave 299HP.
I believe that what decreased those A/F ratios where the stock Ecu.
The 318hp where at night like a month ago, i believe that temps where like mid 70's.
So with 85 and up degrees it will not work.
We will give it a shot later on the week at nighttime with 93 octane to see if the problem is the temperature. Which I highly believe it is.
And we'll bring 4 gallons of 100 octane, to make later runs of the HR.
I'll get to you later on the week, with night temp results.
Happy New Year to everyone!
      12-31-2007, 02:37 PM   #17
Terry335
Drives: 335i
Originally Posted by darvo View Post
Bad News!!
Interesting, I wouldn't expect the hot pill to have much of an effect on the air/fuel ratio. 10:1 would be a lot richer than its supposed to be. The symptom of it not working would be a limp mode. Is it possible its installed in the wrong spot? Did the monitor they boost level?
      12-31-2007, 02:44 PM   #18
darvo
Drives: Blazer
No they did not monitor boost..
They just went to check on A/F ratios on the day, to see the effect on 85-90+ temps.
Do you think it could be installed wrong?
      12-31-2007, 02:47 PM   #19
darvo
Drives: Blazer
After installing the hot pill you could feel it was pulling better!
But again we tested it at night
      12-31-2007, 03:31 PM   #20
Terry335
Drives: 335i
It would likely give a code, but just make sure you put it in the JB yellow loom. I'll be away from the PC but you can email or call if needed, give it a shot on good gas, as close to 97 octane (ron+mon)/2, and lets see what happens.
      12-31-2007, 03:36 PM   #21
E90 335i
Drives: 2007 E90 335i
I've been driving my car in South Florida for weeks on the H pill and 93 octane and the temps have consistently been in the 80's and I've never seen a code.
....driving really hard, too.
      12-31-2007, 05:06 PM   #22
JE92i
Drives: 2008 BMW 335i
is it pushing it to run the hot pill w/ 92 oct gas... seems to be the standard at the pumps around the seattle area.
