v2.0.2 latest maps and switched power "issue ?"
12-30-2007, 03:27 PM | #1 |
Moderator
270
Rep 4,481
Hi,
Shiv invested quite some time developing the latest maps to solve an issue ( multiple error messages thrown at engine startup ) by delaying the time when the PROcede starts to get active. Sure, more corrections have been done in the new maps ( 12-24 and 12-29 ). What I experienced today was exactly this error but it has nothing to do with the switched power source of the PROcede. Normally I disconnected the battery of my car every time after I loaded new firmware or maps. I also disconnected the battery after changing user torque settings. The last two times I did not disconnect the battery after changes, expecting the car will adapt within 1-2 days. My car behaved really strange today, same symptomes as others reported on the forum. I loaded v2.0.2 12-29 yesterday. I limped to the next restaurant, disconnected the battery, took one or two beer and reconnected the battery after 1 hour again. Problems disappeared, everything was fine again and I continued my drive back home. I highly recommend to disconnect the battery of the car after applying any changes to the PROcede so that the ECU is forced to learn the new PROcede behavior from scratch. Especially those customers, who have currently problems should give this a try. For me it solved my problem completely. Just want to share with you. - Eugen |
12-30-2007, 03:31 PM | #2 |
Rep 2,573
Drives: AW DCT M3
Thanks Eugen
12-30-2007, 03:36 PM | #3 |
441
Rep 18,331
So you think with this new firmware and maps, the car really needs to adapt everytime from scratch....I mean this could possibly be the problem, but have to see...I just raised my torque level yesterday to 95% and lowered my valet to 300 as before 1700 rpms...I think that the constant starting of the car and having to raise the rpms to 1700 to disable valet is causing the ecu to cause these problems during startup....Its fuel injected and when you start , i guess its not normal for the car to need any throttle like the old carburetor days!!! I am thinking that this might be the problem!!
12-30-2007, 03:36 PM | #4 |
Moderator
618
Rep 10,855
But good bier is very hard to find here.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
12-30-2007, 03:44 PM | #5 | |
Moderator
270
Rep 4,481
12-30-2007, 03:44 PM | #6 |
Rep 833
12-30-2007, 03:49 PM | #7 |
Moderator
270
Rep 4,481
12-30-2007, 03:56 PM | #8 |
441
Rep 18,331
Your not understanding what i am saying....I feel when u have the valet set at 1700 rpms...When you start the car to activate the Procede you need to press the throttle to 1700 rpms...The process of doing so, I think messes up the ecu upon startup...and causes iratic idling of car which induces reduce power limp mode!!!
12-30-2007, 03:57 PM | #9 |
Rep 4,764
Very interesting. Thanks for the info. I have never disconnected the battery during v1 or v2 work.
12-30-2007, 04:06 PM | #10 | |
Moderator
270
Rep 4,481
However, if you want a reply, get the things to work with valet settings at 300 rpm. If this works and it does not with 1700+ rpm, you got it. You don't have to guess, you can test it . |
12-30-2007, 05:21 PM | #11 |
441
Rep 18,331
Not trying to test it either, just wanted to know if other OP have experienced this too and use valet function like i do!!!!
12-30-2007, 05:28 PM | #12 | |
99
Rep 1,712
3rd day on 12-24 map and no problems, what does the 12-29 map do? |
12-30-2007, 06:15 PM | #13 |
441
Rep 18,331
Thank you, I just wanted to know if there was something to do with the VALET function upon startup...I think revving the engine to get out of valet triggers this galluping....Shivs can you see if you can address this, if indeed it is the problem...Are are other people like 335lvr and I that has these issues using valet set to 1700 or 1800 rpms...Please chime in...I kind of like the function but have turned it off because i feel and think that this is the inherent problem!!! But like i say i don't know for sure if it is indeed the problem!
12-31-2007, 01:29 PM | #14 |
Rear wheel drive fanatic
53
Rep 604
Drives: M3 E30-1M-M4
I think you change adaptation values when you use the stock map and then again you adapt when you choose back the tuning file.
01-01-2008, 12:13 PM | #15 | |
Rep 153
I've got my valet mode set at 300rpms but still get the gallops. |
01-01-2008, 12:35 PM | #16 |
441
Rep 18,331
01-01-2008, 12:44 PM | #17 | |
175
Rep 1,517
Drives: E92 335i coupe Black AUTO
i dont have any issue on the new map 12-29 map speed limit one. I did not disconnect my battery. I setted at 92 % torque curve. It does not feel torque or kick when i do WOT. Currently i used 91 octane gas (conoco Gas 76). I might need to change to MOBIL gas to see different. I Think MObil Gas run much cleaner than 76 conoco. I could be wrong on the assumption. ANyone in here pump MOBIL 91 octane? |
01-01-2008, 01:17 PM | #18 | |
Rep 1,310
I don't understand why people have such an aversion to disconnecting the battery. I have done it every time since you started suggesting it and have NEVER had an issue. The only thing that has to be reset is the clock. Such a simple step and solves so many issues. If someone is having an issue with a map, disconnect the battery for an hour and see if the problem is solved. If not, then post something on the forum. |
01-01-2008, 01:30 PM | #19 | |
441
Rep 18,331
01-01-2008, 02:58 PM | #20 | |
Rep 1,310
01-01-2008, 03:05 PM | #21 | |
Moderator
270
Rep 4,481
