Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > PROcede and Spark Plugs.
      12-31-2007, 03:56 PM   #1
NPDAN
NPDAN's Avatar
95
Drives: AW DCT M3
2008 E92 M3  [8.00]
07' E92 335i  [0.00]
Has anyone changed / upgraded their spark plugs out yet? I've got some freinds that have been messing with cars for a while and they all suggest that I do so. Is there any benefit to upgrading spark plugs? Is it needed with the PROcede?
      12-31-2007, 04:43 PM   #2
LACA335i
LACA335i's Avatar
Drives: E92 335i coupe Black AUTO
2007 335I SEDAN  [0.00]
typical conventional spark plug like Bosch Plantium will work well for Daily driver. I m not sure if BMW still using Plantium spark plug. When are you starting to mod thing and making more than oem spec. You need to have high melting point spark plug. you need to have Iridium Spark Plug because it have higher melting point and little more resistance to corrosion, and less denotation. This company http://www.nitroiridium.com/features.html make spark plug for racing application.
This company make spark plug for BMW http://www.autocarparts.com/part/368/46/
According to Denso company "Denso Iridium Spark Plugs keeps your engine in prime condition is an important factor in obtaining the highest possible performance. The Performance Tuning section helps you diagnose various problems that may affect the output of your engine. "
      12-31-2007, 04:45 PM   #3
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
Originally Posted by LACA335i View Post
typical conventional spark plug like Bosch Plantium will work well for Daily driver. When are you starting to mod thing and making more than oem spec. You need to have high melting point spark plug. you need to have Iridium Spark Plug because it have better melting point and little more resistance to corrosion.
is there an iridium plug that is released that is compatible with the n54?
      12-31-2007, 04:53 PM   #4
LACA335i
LACA335i's Avatar
i have not notice any new on n54. however, Denso " Denso Iridium Spark Plugs, BMW 3 Series 328i" part number IK20
Spec
2.8L
Set of 6
Gap: 0.032
i will do more research for the 335i
i also found out that in the past previous thread on e90post. someone already talked about this issue..
http://www.e90post.com/forums/showthread.php?p=808094
      12-31-2007, 04:56 PM   #5
HyperM3
Too many Alex's, from now on, call me Beaufort
Drives: See Sig
Ive thought about this too but the stock plugs seem to be holding their own very well. I run copper plugs on my S/C M3 because of the colder burn(also ran them in my A4 previously). Problem with that is you need to replace them every 5k. Dont know much about the iridium ones other than they are mighty pricey.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      12-31-2007, 04:58 PM   #6
NYCGarbagePrince
Drives: X6 50i
We just went with iridium's on my car, actually went a step colder as well. Car is running fantastic and I no longer have that strange hiccup that was happening all the time.
      12-31-2007, 04:59 PM   #7
HyperM3
Drives: See Sig
Can you link to which plugs you went with?
13 HD FatBob
07 335i(gone)
      12-31-2007, 05:06 PM   #8
jon@themshop
jon@themshop's Avatar
Drives: BMW
The spark plugs on the N54 engine (Bosch ZGR6STE2) are completely different than the ones used on the N52 engine.
Going to a one step colder plug is idea for modified N54 engines.
      12-31-2007, 05:09 PM   #9
LACA335i
LACA335i's Avatar
here is how it work ..
http://www.pulstarplug.com/howtheywork.html
http://www.pulstarplug.com/video.cfm
      12-31-2007, 05:09 PM   #10
deck
500whp or bust!
Drives: 2007 AW 335i coupe
2007 e92 335i  [0.00]
+1
      12-31-2007, 05:13 PM   #11
HyperM3
Drives: See Sig
Wow, those are pretty interesting(and expensive). I just wonder how hot they burn though. Plus for that price, I want them to last more than 50k.
13 HD FatBob
07 335i(gone)
      12-31-2007, 05:16 PM   #12
lawdude
lawdude's Avatar
Drives: 335i ZPP ZSP TiAg MT
CAUTION: Pulstar™ model recommendations are for stock, unmodified engines. If you have added an aftermarket turbocharger, supercharger, nitrous or any other product that increases displacement or compression to your engine you will require a colder heat range pulse plug in order to avoid possible damage to your engine. For these applications please see our other great product DirectHits or call us at 888-800-6700 (1-505-842-5201 for International calls).
At $25 a pop you better get the right heat range.
      12-31-2007, 05:17 PM   #13
LACA335i
LACA335i's Avatar
I hope this educate you how the combustion inside the engine work. .
Just remember this .. Intake, squeeze (compress), bang (power), and release(exhaust)
      12-31-2007, 05:18 PM   #14
LACA335i
LACA335i's Avatar
here is Some NGK iRidium for e90 e92 and e93
http://www.myhotbmw.com/bmw/Iridium/...-_10_HP/533366 "they claimed 10hp increase"
or you can go directly to NGK website
http://ngk.com/results_app.asp?AAIA=1433813
Not all spark plugs are created equal.
Some spark plugs can improve performance, while others offer long life. Some can make your lawnmower easier to start, while others resist fouling. For most of the applications you look up at this site, whether its for a car, boat, lawnmower or generator, you will find the prices for a plug as low as $2 or as high as $12 (although we stock some hand made Japanese racing plugs which have a retail price of $100 per plug). So why spend $12 for a spark plug when a $2 plug will screw in and start your car? Well, to be honest, if you are just tuning up your car to pass smog so you can sell it, it isn’t cost effective to purchase the highest quality double platinum plug. But if you are planning on keeping that car or the outboard motor your tuning up, the plug you choose can improve ease of starting, acceleration, fuel economy, as well as how soon you have to change them again. In short, there are horsepower and mileage improvements available from different spark plugs.
To help you decide which plug is best for you we have categorized according to quality level and construction features. We have also explained and illustrated the differences in what may appear to be similar plugs.
Whether you are a racing engine builder or just tuning up your lawnmower, NGK.com will become your source for NGK spark plugs. After searching through the plugs available and selecting the best plug for your needs, we will have it in stock and ship it to you immediately, (usually the next business day).
I m not here to sell stuff or advertise. im here to help
      12-31-2007, 07:31 PM   #15
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
The NGK website has nothing for the 335i
      12-31-2007, 09:33 PM   #16
LACA335i
LACA335i's Avatar
if you select the year/manufactor/model/engine. you will see it
      12-31-2007, 09:42 PM   #17
335iheLLraiseR
اوليسيس
335iheLLraiseR's Avatar
Drives: e92 335
2007 e92 335  [10.00]
http://www.myhotbmw.com/bmw_products...ark_Plugs/2007
Originally Posted by lawdude View Post
Anyone who can transition seamlessly from defending one vendor and bashing another vendor to bashing the one he formally defended and defending the one he formally bashed has a instant credibility problem.
<---Sign up Now for Bonus Storage! Up to 10gb!
      12-31-2007, 10:02 PM   #18
LACA335i
LACA335i's Avatar
Originally Posted by 335iheLLraiseR View Post
      01-01-2008, 02:09 AM   #19
335iheLLraiseR
اوليسيس
Drives: e92 335
n/m thought he was talking about the hotbmw website, sorry, a little drunk right now.
      01-01-2008, 02:15 AM   #20
hl0m4n
hl0m4n's Avatar
Drives: BMW
ngk copper head plugs or denso iridium. step further would be ignition solution's coils .
bosch is stock for all bmws?
      01-01-2008, 02:23 AM   #21
LACA335i
LACA335i's Avatar
most like going to be bosch.. Bosch is like NGK for JDM.. Bosch for Euro car.. I could be wrong. i will accept any correction by anyone in here with knowledge
      01-01-2008, 02:23 AM   #22
jon@themshop
Drives: BMW
Some BMW engines use Bosch and some use NGK. NGK seems to work better than the Bosch ones but it really depends on the engine.
