10-15-2014, 01:03 PM | #1 |
Rep 252
KW V1 or V2
I used to have the ST Coilovers on my 335i and I really enjoyed them, but I have bought a new M235i and so my question is:
If I am just looking to lower my car and have a more stiff ride, is the KW V1 the way to go or should I go with the V2's? Also, will I get warning lights if I don't have the EDC option? Is the EDC option worth the money? What exactly does the EDC do? I have my assumptions, but I'm not 100% on it. Any info or links would be great. |
10-15-2014, 01:30 PM | #2 |
28
Rep 319
If you're looking to only lower and get a stiffer ride, V1 will be enough. Only thing v2 have is adjustable stiffness.
EDC is electric dampening control where you can switch between eco, comfortable, and sport mode. This control can change the dampening on your suspension. You can see my install thread here (http://www.2addicts.com/forums/showthread.php?t=1009346) but I've heard from F30 people that EDC will throw an error when replacing suspension if they do not have EDC delete. Basically what you purchase from KW with the EDC bundle is the EDC delete dongle. With this, it will nto cause an error but at same time, you can't adjust the stiffness of the suspension while in cabin. |
10-15-2014, 04:47 PM | #3 |
Rep 252
You can't set the stiffness in the V1's right?
Your set up looks fantastic man. Absolutely gorgeous car. Do you have the wheel specs? I want to do the wheels and coil overs at the same time. Was thinking about going with a red wheel though. You're saying I need the dongle to keep from getting codes, but did you have to splice wires? |
10-15-2014, 05:02 PM | #4 | |
im a car
736
Rep 1,117
Drives: 220i M Sport | 520i M Sport
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB |
10-16-2014, 04:02 PM | #5 |
Rep 171
Get the V3's or billsteins so you can still have a functioning edc.
ST and KW V1's are the same exact thing. I think the KW's are stainless and the ST's aren't, that's the only difference. V2's just add adjustable dampening. IMO you are taking a step backwards with KW's unless they are the V3's. Now if all you care about is dropping the car I guess they will be fine EDIT: I just checked the KW's that work with the edc are called the ddc plug and play coilovers, not the V3's Last edited by boost82; 10-16-2014 at 04:14 PM.. |
10-16-2014, 04:07 PM | #6 |
Rep 171
10-23-2014, 05:05 AM | #7 | |
Rep 93
If you want still ride with the EDC in your 2series take this: http://blog-int.kwautomotive.net/ada...lay-coilovers/ |
10-29-2014, 12:14 AM | #8 | |
Rep 171
11-03-2014, 05:33 PM | #9 | |
Rep 252
11-04-2014, 04:24 PM | #11 |
Rep 252
11-04-2014, 05:29 PM | #12 |
Rep 659
F97 X3M
F80 M3 (Sold) E90 M3 (Sold) EB M235i (Sold) E92 M3 (Sold) |
11-04-2014, 07:29 PM | #13 | |
Rep 252
11-05-2014, 02:35 AM | #15 |
Rep 32
11-05-2014, 06:12 AM | #16 |
Rep 252
Do they sell it separately on their website or is this something you have to order? How much did it cost for just the delete kit?
11-05-2014, 11:13 AM | #17 |
Rep 659
Interesting, does this mean that you are unable to adjust the throttle response?
F97 X3M
11-05-2014, 11:24 AM | #18 | |
Rep 32
Cost was around 300 euros. |
11-05-2014, 11:26 AM | #19 | |
Rep 32
If you have an adaptive car, and change to coilovers without the edc delete kit, you will get chassis error that locks your car in comfort mode. No sport, no sport plus, and no fully off mode. |
12-18-2014, 03:50 AM | #20 | |
Rep 93
and Hello the rest of the forum. http://blog-int.kwautomotive.net/ada...lay-coilovers/ Or here you get all details about the ddc plug&play http://www.kwsuspensions.com/kw/info/kw_ddc/ For Prices please get to our international website as well but use there the COUNTRY SELECTOR sometimes the ip addresses switch you to old kw websites. Merry christmas by the way |
12-18-2014, 03:55 AM | #21 | |
Rep 93
try this link http://www.st-suspensions.de/produkt...terGroupID=1-0 And no there is no EDC Cancellation Kit included. |
12-23-2014, 10:33 AM | #22 | |
Rep 252
