"Free" maintenance question
01-06-2006, 04:48 PM | #1 |
Rep 122
Not sure does someone ask this before, but I can't seem to find the answer. So, I ask it here.
the so call "Free" maintenance, what does it include? I know oil and filter only. What about: Coolant? Brake Fruild Power Streeling Fruild? Brake pad and rotor? I own the car and i will keep it for long time , so I want to make sure I take a good care of it. Only thing is, no one seem to know how often should I change oil and filter. And the Life Fill ATF is still a big question mark. Confuse...confuse..confuse....
E90 - 330i Arctic Metallic -> X3 M40i (Soon)
01-06-2006, 06:25 PM | #2 |
Rep 2,232
Drives: 2016 M3
I think its pretty much everything that is scheulded,so its a yes
2016 M3
2016 Audi Q5 3.0T |
01-06-2006, 07:20 PM | #3 |
17963
Rep 9,377
Gas and Tires are not covered, pretty much everything else is. The catch is that the CAR had to think it needs a change or service, not you.
01-06-2006, 07:28 PM | #4 | |
Rep 426
Oil + Filter Inspection Services (30k, 60k, etc.) Brake Pads and Rotors Brake Fluid Flush Coolant Flush on applicable models... new models have "lifetime" coolant Tranny flush if called for on your car before 50k Spark Plugs at 100k if you buy the 100k upgrade Drive Belts Clutch (if worn from normal use and does not show signs of abuse) Not covered: Fluid top-offs when not part of a normal maintenance visit Alignment after 2000 miles Tires Gas
2020 X5 M50i Alpine White / Coffee Merino Leather
2020 M550i Carbon Black / Canberra Beige Leather |
01-06-2006, 08:31 PM | #5 |
Rep 433
'Youngtechman' I would suggest you double check woth your dealer or call any service dept in the Toronto area. I read somewhere in another thread that the free maintenance items listed above might only apply in the USA and not Canada. I'd be happy if 'Sarafil' is right but I'm not so sure.
2006 330i Sparkling Graphite/Sport pkg/Comfort Access/Aluminum Pedals/35% LLumar tint/Blacklines/OEM Shortshift knob |
01-06-2006, 08:34 PM | #6 | |
Rep 426
02-08-2006, 12:58 AM | #7 |
Rep 21
For Canada, the full maintenance warranty DOES NOT cover:
- brake pads and rotors - engine belts - wiper blades - clutch components - tires/rims pretty much everything else is as long as it is scheduled through the service reminder of your car. |
02-09-2006, 11:32 PM | #8 | |
Rep 62
----------------------- 2006 BMW 325i ----------------------- |
02-10-2006, 02:14 AM | #9 |
Rep 663
Wow, Canadians are getting gipped on their "full" maintenance!
E90 330i delivered 6/29/2005, ZSP/ZPP/ZCW/Step, Arctic/Gray/Walnut
02-16-2006, 01:34 PM | #10 | |
Porscheneer
Rep 196
Later
