10-31-2014, 01:21 PM | #1 |
Rep 7,902
New AP Racing FORGED Radi-Cal Brake Systems for F8x | 390MM
AP Racing, the leading manufacturer of performance braking and clutch systems, for road and race use, has created a new range of Radi-CAL™ brake calipers, which incorporate race technology into high-performance road products. AP Racing's Radi-CAL racing calipers have taken the racing world by storm, dominating the highest level racing series on every continent. The pressure forging process results in a strong, stiff caliper that is 20% lighter than similar cast calipers. Each caliper has been tested with over 500,000 cycles of pressure and torque to meet AP's stringent quality standard. The non-symmetric design is the result of Finite Element Analysis testing to determine where weight saving can be achieved without compromising strength and stiffness. Radi-CAL calipers are double sealed for durability. Hard anodized aluminum pistons are differentially sized to maximize pad life. A removable forged Bridge allows for easy pad changes. Anti-rattle springs prevent pad movement and knock back. Available as six and four-pot front calipers, as well as a four-pot rear caliper, the new range of Radi-CAL™ products distil the company’s expertise in producing brake systems for race and OEM installations, into calipers suitable for the aftermarket. As a result Radi-CAL™ delivers an advanced brake upgrade for the owners of high performance and sportscars. Featuring a two-piece aluminium body and h-piece, the forged non-symmetrical calipers offer a significant reduction in mass compared to conventional designs, and improved efficiency when resisting the torque generated by braking. This not only lowers a vehicle’s un-sprung weight, but also ensures continued high performance in demanding applications. AP Racing’s advanced design process allows the concept to minimise structure and weight, while improving caliper cooling surface area, without sacrificing rigidity. This provides improved brake caliper cooling and reduces disc temperatures during high performance driving. The Radi-CAL(tm) calipers feature a highly durable paint finish featuring the distinctive new Radi-CAL(tm) logo, and available separately or with matching performance road-car discs and pads for specific customer requests. The Radi-CAL(tm) Factory Big Brake kits incorporate floating two-piece disc assemblies, and include bespoke mounting bracket and bolts, a braided hose kit and DOT 5.1 high temperature brake fluid. Includes D701 Ferodo DS2500 Brake Pads AP J Hook Rotors Custom Goodridge SS Line Optional AP Racing, Street, Semi Track, Track brake fluid. Application F8x M3 APR7140 Front 390x36mm 6P E9x M3 APR7130 Front 370x36mm 6P E9x M3 APR7170 Rear 380x28mm 4P Studie AG Shop Car– They ran AP Radi-CAL on their M4 at Suzuka Circuit: |
11-06-2014, 06:24 AM | #4 |
Rep 549
Nice! How much for the 390 front 380 rear set up? Will it be okay for the 18 stock rims?
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
11-10-2014, 10:44 AM | #7 |
Rep 3,450
any other info on the weight of the calipers and rotors vs. the stock steel units? also, what pads are available? any chance we could get more installed pictures?
thanks in advance. if you could also PM me pricing, I would appreciate it. |
11-10-2014, 01:07 PM | #8 |
Rep 7,902
The rotors and calipers will probably weigh a little more than OEM due to the size of the kit. However, the stopping power of the kit is incredible. I will see if I can get anymore pics.
11-10-2014, 01:21 PM | #9 |
Rep 1,089
11-28-2014, 10:15 AM | #14 |
Rep 7,902
Tags |
f80 f82 ap racing, m3 m4 radical bbk |
