Has anyone upgraded their spark plugs?
01-05-2008, 06:31 AM | #1 |
123
Rep 2,097
Has anyone upgraded their Spark Plugs to handle the increased boost? instaed of replacing them with the same ones. I got this on my iDrive screen when the car said service due.I assume my plugs are going out due to the tune and mileage. I have 42k on the clock as of now.
See attachment |
01-05-2008, 09:58 AM | #2 | |
Rep 762
Spark plugs are covered under warranty so I would get the stock ones especially if your 335i is still under warranty. |
01-05-2008, 12:08 PM | #3 |
اوليسيس
196
Rep 4,678
NYCGarbagePrince has upgraded his with iridium, there is another thread VERY recently about this. He was asked about specifics but has not responded as I'd yet.
01-05-2008, 03:54 PM | #5 |
Rep 228
Iridium plugs SUCK. People do the darndest things lookin for power. You can cross reference any plug. Pull it out, measure it, measure the threads, and you can find one. AA used to use iridium plugs and had problems out the ass until I found the ngk dcpr9e. Not even made for bmws. So, I think its sparkplugs.com, or some site that tells you where to measure, and then you cross them with other plugs. We deff need 1-2 degrees colder with so much more boost...Among other adders! Ill see what I can do!
01-06-2008, 03:54 AM | #7 | |
Rep 87
Exactly what we talked about today at the shop. I know the car can benefit from colder plugs. You can get more aggressive with boost, a/f, and most importantly ignition timing. |
01-06-2008, 06:50 AM | #8 | |
Rep 1,283
01-06-2008, 09:29 AM | #9 | |
Moderator
270
Rep 4,481
01-06-2008, 01:14 PM | #10 |
Rep 812
Here's a quote from the 335 Engine Technical Manual (see the top of this forum):
"Due to the proximity of the spark plug to the fuel injector nozzle, any divergence in the fuel spray may cause possible spark plug damage. This makes spark plug diagnosis an important part of N54 service concerns. Information gained by the spark plug diagnosis may indicate possible fuel injector faults. Spark plug replacement interval has been reduced to 45,000 miles for the N54." |
01-06-2008, 02:39 PM | #13 |
Rep 3,303
Eugene was comparing the max psi that each tune achieves and the stock map can go as high as 11 to compensate for altitude. That is why Terry talks about how much power "stock" boost can make. The JBR basically makes the ECU apply the amount of boost it would at higher altitudes.
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
01-06-2008, 02:41 PM | #14 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Spark plug heat rating doesn't have too much effect on knock resistance. It has a bigger effect on fouling characteristics. What would be far more desirable is a plug with a smaller gap.
shiv |
