PROcede V2 and boost question
01-08-2008, 12:17 PM | #1 |
Moderator
270
Rep 4,481
Why is the PROcede V2 boost curve different ( e.g. boost tapering down ) in different gears when I accelerate with the pedal floored ? Sometimes in high gears the PROcede V2 seems to not taper down boost at all. Could the engine be hurt from 13.5 - 14 psi boost @ 6000+ rpm ?
Thanks, Eugen |
01-08-2008, 12:38 PM | #6 |
Moderator
270
Rep 4,481
I found a good example with the latest map but not that high boost numbers, 12.9 psi. Isn't this a bit high for 6000 rpm ? And you can trust me, I have seen 14 psi @ 6000 rpm as well already.
In 3rd gear, boost is 11.2 psi @ 6075 rpm. In 4th gear, boost is 12.9 psi @ 6075 rpm. The boost in 3rd gear is lower than in 4th gear. Shiv advices his customers to fine-tune user torque in 3rd gear. |
01-08-2008, 12:49 PM | #7 |
654
Rep 10,587
I'm seeing lower boost in 3rd gear as well. Boost in 4th gear seems to be stable and not dropping.
As of right now though I wouldnt use my car as a data point for V2 boost levels.
01-08-2008, 12:59 PM | #8 |
Rep 4,726
The difference between gears is because turbos are more efficient in higher gears. More engine load, more exhaust longer pull ETC. It could also have to do with IATs climbing (again since the pulls are longer) and the ECU adjusting boost up to compensate.
01-08-2008, 01:04 PM | #9 | |
Moderator
270
Rep 4,481
Now, could it hurt the engine to run 14 psi @ 6000 rpm ? |
01-08-2008, 01:07 PM | #10 |
654
Rep 10,587
sounds reasonable to me
01-08-2008, 01:10 PM | #12 |
Moderator
270
Rep 4,481
01-08-2008, 01:17 PM | #13 |
Rep 4,726
Engines fine, you're not putting out anywhere near the amount of torque as you are down low, yes you can't really say if it makes the torque at lower engine speeds its ok to make the same at high speeds, but it gives you a good idea of what the engine can likely handle. You would need to worry about how much the turbos need to spin to put out that pressure or about detonation or excessive timing retard and again if anything.
01-08-2008, 01:21 PM | #14 | |
Moderator
270
Rep 4,481
If anything, the turbo's will be the price to pay it will be a good reason for exchanging / upgrading them . |
01-08-2008, 01:38 PM | #16 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
In higher gears, you are seeing higher intake charge temps. This increase in IAT is what raising boost pressure. This is one reason that cars with good intercooler upgrades will see less boost than cars with stock intercoolers. This is also the reason that you see less boost in cold ambient conditions than you do in warm conditions. Until you do a run up through the gears, of course. At which point, IAT is substantially higher than ambient temps.
Shiv |
