11-30-2014, 02:55 PM | #1 |
244
Rep 356
Why does the power stay on after I turn off the car
I press the engine stop button and my V1, which is connected to the cigarette lighter, stays on. On my E92 M3, it used to always turn off. Does it ever turn off?
11-30-2014, 03:13 PM | #2 | |
Rep 680
2sporty243.50 |
11-30-2014, 03:16 PM | #3 | |
244
Rep 356
11-30-2014, 03:46 PM | #4 | ||
Rep 680
11-30-2014, 04:08 PM | #5 | |
Rep 3,396
11-30-2014, 04:27 PM | #6 | ||
Rep 680
11-30-2014, 04:38 PM | #8 | |
Rep 1,275
http://f80.bimmerpost.com/forums/sho....php?t=1054818
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive |
11-30-2014, 04:40 PM | #9 |
Rep 1,075
I drive an F30 and I leave the radio on when I'm unloading the groceries etc. Once I lock it, the radio and everything shuts down. Hence I never specifically turn off the radio or any other system when I leave the car. It all will shut down when I lock it.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
11-30-2014, 04:41 PM | #10 |
Rep 680
Dang. That used to work on my e92. I've been doing the push once to turn off engine and push a second time to turn the radio off in the m4. It's a shame that the holding it down for a longer period doesn't work on the m4.
11-30-2014, 04:42 PM | #11 |
Rep 3,396
I had a radar detector for a bit in my f80, plugged into the socket, the power never seemed to go out. I ended up having to power down and up the unit with it's own power switch, till I returned the unit. I don't think these plugs have an on/off function.
11-30-2014, 04:44 PM | #13 |
Rep 2,171
11-30-2014, 04:53 PM | #14 | |
Rep 180
11-30-2014, 05:05 PM | #15 |
Rep 3,396
Interesting. The on/off button double tap should do it if it shuts down everything else, which the OP says it doesn't turn off the plug. Mine did stay on but I never sat there to see what happened after a couple of minutes. I guess the OP, if motivated, will just have to go back to the car after 10, 20, etc, minutes to see. Frankly, it is weird these cars don't just shut down fully when turned off on the initial button press.
12-03-2014, 04:13 PM | #16 |
Rep 18
If you push the start/stop button when the car is in "N"(neutral) the engine stops, but the ignition is still on. If you push the button when the car is in "D" or "R' the engine stops AND the ignition is switched off. The power outlets will go off after a couple of minutes both ways
M4 /SS/19Black/DCT/CCB/BlackLeather
First BMW ever |
12-03-2014, 04:15 PM | #17 | |
Rep 18
First BMW ever |
12-03-2014, 10:46 PM | #20 |
Sunburnt Member
158
Rep 525
Take your foot off the brake pedal and/or clutch...
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible |
12-05-2014, 02:32 PM | #22 |
Rep 7
I had mine coded so the electronics go off when I open the door. I don't lock the car in my garage so for me I prefer everything to go off once I open the door.
