BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Rough Idle and harsh vibration
      12-03-2014, 08:32 AM   #1
Jamrockbwoy
Drives: 2015 550i xDrive
This past weekend I drove from NY to Maryland and the car ran great but I think I may have drove it too hard. Yesterday morning out of nowhere the service engine soon light came on and the car started to idle rough and vibrate harshly when accelerating.
I ran a fault code check on it and got code 0029D2 from BMWhat app
Car is a 2010 328i x Drive currently has 51k on it.
Rough Idle and harsh vibration (stuttering) when Accelerating
A friend of mine told me he had the same issue and it was his throttle body.
any ideas would be helpful
Instagram @_gr8dane
2015 550xi - current
2015 428xi - retired
2010 328xi LCI retired
      12-03-2014, 08:47 AM   #2
Dyeraudio
Dyeraudio's Avatar
Drives: 2018 330i M Sport
I had the same issue last month....Misfire in Cyl. 1 I replaced all 6 plugs and coils......
      12-03-2014, 08:47 AM   #3
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Looks you have a misfire my friend. Did this reset after the next startup or is the SES light still on?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      12-03-2014, 09:33 AM   #4
Jamrockbwoy
I cleared the code but it came back and so did the SES light.
Instagram @_gr8dane
      12-03-2014, 09:34 AM   #5
Jamrockbwoy
ok thanks for the input. I'm gonna try that.
Instagram @_gr8dane
      12-03-2014, 10:28 AM   #6
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Ok. Since your misfire is persistent then you can check to see if it's the coil that is causing the issue. Exchange the coil with another and if the code travels to that cylinder then it's a def that the coil is faulty. If that doesn't work then you move on to the plugs.
      12-03-2014, 10:49 AM   #7
Jamrockbwoy
thanks man i'm gonna try that
Instagram @_gr8dane
      12-18-2014, 06:35 AM   #8
Jamrockbwoy
issue was caused by 2 faulty coils. replaced by dealer thru warranty. thanks for he input guys.
Instagram @_gr8dane
      02-27-2016, 10:19 AM   #9
Mr_SDP
Mr_SDP's Avatar
Drives: 2012 335i F30 Sedan Manual
Had the same/similar issue and used the CarlyForBMW App (formerly BMW What App) to diagnose. I changed all 6 spark plugs and coils. Such an easy job and now my car runs perfectly. I have a 2006 e90 with 60k miles. A bit surprised this happened but was only a $200 fix, compared to triple that or more if I took it to the dealer.
