Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Changing Paddle Shift Operation
      12-08-2014, 07:33 PM   #1
Petrolhead3010
Petrolhead3010's Avatar
Drives: 2021 BMW X3 M40i
This may have been covered before, but I've been unsuccessful at finding a thread for my question.
I have the paddleshifters for my 6AT, & am wondering if it's possible to change how they shift. For those who don't know, the OEM function when pushed toward the dash, is to downshift. When pulled toward the driver, it upshifts. This happens for both LH & RH paddles.
So my question is, can I modify the paddles to where pulling the LH paddle will downshift, & pulling the RH paddle will upshift? From what I've heard, that is how the M3 is set up.
      12-08-2014, 07:37 PM   #2
Esveesh
Drives: 2007 335i coupe
+1 I expected it to be like that till I got my car and both sides was exactly the same -_- I'd love to have an upshifting and a downshifting separate paddle
      12-08-2014, 07:39 PM   #3
iturbo_bmw
iturbo_bmw's Avatar
Drives: 335i, 530i
i believe there is a diy out there for doing that if you want to keep those paddles. search the diy threads or google it. However, i would recommend just upgrading the paddles. I got the m3 dct ones and never looked back. feels much better but u can't drive with one hand lol
      12-08-2014, 07:43 PM   #4
Petrolhead3010
If I upgrade to the M3 DCT paddles, it reworks the original function to make the LH downshift & RH upshift? How does it do this by just changing the paddles?
      12-08-2014, 08:26 PM   #5
thestein1016
Drives: BMW 335
Left Paddle Connector
_______
3-------|<--downshift (press)
2-------|<--ground
1-------|<--upshift (squeeze)
_______|
____|
Right Paddle Connector
____
____|___
1-------|<--downshift (press)
2-------|<--ground
3-------|<--upshift (squeeze)
_______|
Left Connector
1) Remove the wire and pin that go to pin 3 and tape off the exposed pin (disables push function)
2) Remove the wire and pin that go to pin 1 and install it in the pin 3 location (converts pull function to downshift)
Right Connector
1) Remove the wire and pin that goes to pin 1 and tape off the exposed pin (disables push function)
      12-08-2014, 08:48 PM   #6
techmaster05
Drives: E90 335i
I havr always wanted to do thid
What's the difference between a stock FBO 335 and an upgraded Single Turbo 335?
Nothing! They both run 11's LMAO
      12-10-2014, 04:33 PM   #7
Tim603
Tim603's Avatar
Drives: 2007 335i E90
2007 335i  [0.00]
Should be direct plug and play, once you install the m3 dct paddles it will give you the desired result. It has to do with the way the wiring is setup on the DCT Paddles
      12-10-2014, 05:51 PM   #8
dkny008
Drives: E92 M3 Coupe
I did it.
I've changed to the paddle that what you said. Just get a pair of M3 DCT paddle shift, and change them yourselves. No need to do any coding, just plug & play.
      12-10-2014, 06:35 PM   #9
Petrolhead3010
Sounds good. Thanks for the info, everyone!
      12-10-2014, 06:39 PM   #10
ATTN
ATTN's Avatar
Australia
96
Drives: 335 E92 DCT
2009 BMW 335i  [10.00]
Simple answer: You will need the DCT M3 module.
That will give you what you're after
Left paddle = down shift
Right paddle = up shift
You can also change the paddles itself to after market paddles, instead of using the small OEM M3 ones. Thats personal preference, one of the first mods I did to my car.
Certified Australian
      12-10-2014, 07:44 PM   #11
LMT0286
Drive Fast Take Chances
LMT0286's Avatar
Drives: 2011 335i e92
Hey after you shift to DS and hit the paddle to put it into manual is it possible to take it out of gear and put it back into DS without sliding the stick to D then back to DS?
      12-10-2014, 08:07 PM   #12
Blaster400
Blaster400's Avatar
127
Drives: BMW X3 35i, Porsche Macan S
That's exactly what I did.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
      12-10-2014, 08:10 PM   #13
ATTN
ATTN's Avatar
Australia
96
Drives: 335 E92 DCT
I know what you mean and the short answer it no.
If you're in D and you hit the paddles up or down, you're in M mode and will stay there until you Shift to M to D on the Stick if I'm reading your post correctly.
      12-10-2014, 08:10 PM   #14
ATTN
ATTN's Avatar
Australia
96
Drives: 335 E92 DCT
My wheel looks exactly like yours M3/paddles except im RHD
      12-10-2014, 09:18 PM   #15
LMT0286
LMT0286's Avatar
Yeah that's what I figured. Thanks
      12-12-2014, 10:42 AM   #16
SlimE92
SlimE92's Avatar
186
Drives: E92 N54
Where did you get these paddles from?
      12-12-2014, 11:32 AM   #17
Blaster400
Blaster400's Avatar
127
https://www.bimmian.com/Aluminum-SMG...r-E93-3-Series
      12-12-2014, 11:40 AM   #18
ferocity02
Drives: 2013 135is
Do you know if these will fit my 07 E90 335i pre-lci? These are all over eBay too but for fitment they all say 2008+.
So you installed these and just switched the wires around to might right up and left down?
2013 135is DCT Carbon Black Metallic
      12-12-2014, 11:58 AM   #19
Blaster400
Blaster400's Avatar
127
I bought the M3 steering wheel along with the M3 paddle shifters. Then I replaced the M3 paddles with the Bimmian ones. I don't think the Bimmian paddles will work as replacements for the stock paddle shifters but I could be wrong. My car is a 2007 also.
      12-12-2014, 02:40 PM   #20
kentgbr
Member
kentgbr's Avatar
Drives: 2016 340i Sedan
These pieces are designed to replace only the OEM aluminum sections on 2008+ M3 DCT paddle shifters. They will not fit the push/pull type shifters on your 2007.
The M3 DCT shifters already have a decent sized aluminum paddle IMO. Install them first then decide if it's worth changing the paddle sections. When the DCT shifters are replacing the original push/pull type, no re-wiring is required, the connectors are the same but have two wires, instead of three, already in the correct locations for left-downshift, right-upshift operation. They don't quite fit flush against the back of the 335i sport wheel but unless your very picky it's a non-issue.
Present - 2016 340i, Alpine White, Black, M-sport, 6-spd, Track Handling, Tech pkgs
Past - 2011 E90 335i, Alpine White, Ivory, Sport, Premium, Steptronic
Past - 2008 E90 335i, Titanium Silver, Dakota Grey, ZSP, Steptronic, 6FL, Wagner FMIC, Bilstein B12 Pro-kit, M3 control arms, SS F/R brake lines
      12-14-2014, 12:18 PM   #21
Petrolhead3010
Great info, everyone! So I should be able to just pick up the M3 paddleshift assembly from BMW, & do a direct PnP....?
      12-14-2014, 12:35 PM   #22
Blaster400
Blaster400's Avatar
127
Yes plug & play. https://www.getbmwparts.com/partloca...catalogid=4462
