12-12-2014, 05:56 PM | #1 |
Rep 105
Click/creak in suspension or steering rack?
For the past two days I've been noticing some odd noises coming from the front end of the car. It sounds like a sort of clicking or creaking sound. With the car stationary I'll hear it if I turn the steering wheel from lock to lock. Sometimes I'll also hear it if I stop turning the wheel around center and then start turning again. I heard a bit of it while driving in a straight line earlier today too.
Anyone have any ideas what may be causing this? I'm planning to get it to the dealership as soon as possible (maybe tomorrow morning) |
12-12-2014, 07:39 PM | #2 |
Rep 868
I have heard the same clicking noise. It is independent of the steering. It is most noticeable when the car is stationary. For an owner new to the M series, I have noticed many noises...such as the tin can noise, etc. Just monitor if the car is running well. I have heard all of the aforementioned noises in the F80 forum and have not had any issues with car performance.
2022 BSM G80 Comp X-drive |
12-13-2014, 02:30 PM | #3 |
Rep 105
I stopped by BMW this morning and the foreman took a quick listen to my car. He believes is it a bushing in the suspension making the noise. I have an appointment for Thursday to get it further investigated and fixed.
12-13-2014, 02:59 PM | #4 | |
Rep 868
12-13-2014, 03:20 PM | #5 | |
Rep 287
12-13-2014, 03:21 PM | #6 |
Rep 3,341
I hear this too on occasion, please keep us posted.
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
12-17-2014, 04:20 AM | #7 |
83
Rep 329
I've noticed the same sound only yesterday at lower creeping speeds from the front right area. Nothing at higher speeds. Performance is unaffected.
Garage:
2014 M6 2015 i3 |
12-31-2014, 12:35 PM | #8 |
Rep 105
Quick update...
The dealer believes the problem is in the strut on the driver's side of the car, and has the part on order from Germany. I'll be taking it back in a week or so to get this swapped out and see if it fixes the noise. In the mean time, the noise has become a bit less noticeable (perhaps temperature related?) |
01-03-2015, 07:55 PM | #9 | |
Mark 42
1019
Rep 708
05-13-2015, 07:54 PM | #10 | |
Rep 71
Did you get this issue resolved as I'm having a similar issue? |
06-30-2015, 12:15 PM | #12 |
Curiosity Killed the Cat
241
Rep 822
I just started to get this noise as well on the drivers side only. I am lowered on H&R springs
SOLD - 2015 /// F82 M4 / AY-SO
"AY-BRAVE" I'M BACK - 2016 M4 GTS I'M BACK AGAIN - 2021 M4 COMP FPB |
07-02-2015, 02:37 PM | #13 |
166
Rep 396
I started have the same issue as well, cracking/clicking sound as i turn the steering wheel when im stationary.
I have kw v3 and i thought it's something in the suspension so i called kw and right away they told me its the upper mount. They said its a very common problem most installers tend to over torque the upper mounts and end up cracking the bearing on it. Bolts on there should only be torqued 20-35 ft-lb. The part can be ordered throw the dealer for $200 and the dealer calls it "guide support". However if ur running stock suspension and never had any work done on the suspension, im not sure if what i stated above applies to you.
2015 AY M4, 6sp, KW V3, VFF 103, AWE non-Res, BMC filters, M-Performance Aero.
07-02-2015, 04:28 PM | #14 |
6577
Rep 5,304
07-10-2015, 05:57 PM | #16 | |
Supreme Allied Commander
3776
Rep 54,154
Drives: F80 M3
07-10-2015, 08:22 PM | #17 | ||
166
Rep 396
07-10-2015, 09:48 PM | #18 |
3776
Rep 54,154
Drives: F80 M3
By the torque value it looks like the bolts holding the tower brace to the mount. Those won't affect the bearing at all.
The Choosey begger71933.50 |
07-10-2015, 09:50 PM | #19 | |
166
Rep 396
07-10-2015, 10:10 PM | #20 |
3776
Rep 54,154
Drives: F80 M3
07-10-2015, 10:14 PM | #21 | |
166
Rep 396
07-10-2015, 10:25 PM | #22 |
3776
Rep 54,154
Drives: F80 M3
At least you know you have eliminated the top mounts. The shop could very well have cracked the bearing while doing the install, it's plastic so not very hard to do if they didn't seat the spring properly.
