BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > 6FL retrofit - Is this correct?
      12-13-2014, 07:51 AM   #1
Scotty89
Buy a 335 they said... It'll be fun they said...
Scotty89's Avatar
Australia
117
Drives: 2007 E92 335i
2007 BMW 335i  [10.00]
I have a 01/2007 build 335i which already has:
  • S609A Professional Navigation System
  • S612A BMW Assist
  • S616A BMW Online
  • S620A Voice control
  • S633A Preparation, mobile phone, Business
  • S672A CD changer for 6 CDs
  • S676A HiFi speaker system
  • S601A TV function
I am trying to add USB function in the console to play music - at present it is only AUX-In.
From what I understand, due to my car built before 03/2007, I need MULF2 High unit + USB cable/hub.
Is this correct?
If I already have bluetooth phone calls, does this mean my car was equipped with MULF2 already?
Or is it that because my car is pre-03/2007 I do not have MULF2?
      12-13-2014, 04:27 PM   #2
BklynTico506
Pura Vida
BklynTico506's Avatar
Costa Rica
13
Drives: Monaco Blau '08 E90 Xi
I wanted to do this retrofit to my car as well. But I settled for a BT receiver and I just stream from my phone. I think I'd still do this at some time in the future though.
      12-13-2014, 06:13 PM   #3
Scotty89
Scotty89's Avatar
Australia
117
Okay, so I have discovered I only have MULF not MULF2.
From what I can gather, I need to buy a MULF2, a USB/AUX socket, and a cable (or make a cable).
The MULF2 unit is $477 from ECS... fark.
      12-13-2014, 06:40 PM   #4
ctuna
1917
Drives: 325xi 06 wagon MT
There going for about 200 bucks on ebay.
      12-14-2014, 01:37 PM   #5
makkan00
makkan00's Avatar
United Kingdom
886
Drives: F83 and F36
Bmw makes 6FL retrofit kit.
If you ask your dealer, it will make your life easier.
Also, you can buy used mulf2 high but you will have to flash it with icom to write the vin of your car and then it will connect to your car.
Not sure about BNIB but that will require VIN written to it before it communicate with CCC.
Done it on few cars except we did not bother to run aux-in wires.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      12-15-2014, 06:23 AM   #6
Scotty89
Scotty89's Avatar
Australia
117
Thanks! I've got INPA and NCS expert (NCS Dummy) so I might try coding a second hand unit.
I found another thread from 2013 with yourself in it where it was mentioned a way to use existing AUX-In cable, but program it to receive from head unit instead.
      12-15-2014, 06:25 AM   #7
makkan00
makkan00's Avatar
United Kingdom
886
Drives: F83 and F36
I have tried coding it directly to HU but that did not work.
Also, with apple stuff, you will require Y c able.
Which sends the commands digitally but transmits the sound over analogue.
So if you leave the aux-in to the front, Y cable will not work.
      12-17-2014, 01:22 PM   #8
Scrippy
Lord Scrip
Scrippy's Avatar
Drives: 2011 M3 Coupe
  [0.00]
2007 BMW 335i  [0.00]
Not true. WinKFP will allow you change VIN of any module.
      12-17-2014, 04:21 PM   #9
ctuna
1917
I thought that NCSexpert would work on the pre 09
I thought that NCSexpert with the OBD cable would work on the 09 and pre 09
cars without the ICOM Head for everything.
      12-17-2014, 06:38 PM   #10
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
MULF2 unit will only Bluetooth Connectivity for phone call and USB ONLY!.. For Bluetooth streaming you will need cic system and combox (a good upgrade if you'd like). You currently have the older gen CCC system with a TCU module. supports for basic voice controls and BMW Assist.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
