12-23-2014, 06:55 PM | #1 |
Rep 184
Don't need fancy coilovers. Don't want the back end any lower at all. Want to drop the front end just a little bit- like 1/2"-5/8". Want to close the wheel gap very subtly while minimizing any affect on the stock suspension ride quality and performance handling. Doesn't seem like there is a solution at this time- but do you guys think there will be? If Eibach designed the OEM springs, couldn't they just immediately offer a front-end solution with nearly identical spring rates to the stock setup? I know the sleeve kits are decent- but they are expensive for what I want and like I said, I don't want to touch the rear end. Long story short- I want OEM or equivalent springs for the front end only. Was anything like this offered on the e92?
12-24-2014, 05:21 AM | #2 | |
Moderating
416
Rep 2,047
Actually the best ride heights for balance on these cars appears that fronts are higher than the rears as far as wheel arch gap is concerned. Lowering the front only causes geometry changes that affect cornering under braking performance and traction on the rear end. Read the other KW threads for more details. |
12-24-2014, 12:15 PM | #3 |
Rep 3,996
OP doing what you're asking is completely throwing off the suspension and taking away from what makes these M cars so great, their handling, there are a lot of threads on suspension upgrades, balance, etc.
Not really sure where you got that Eibach makes the springs on our cars, I'm assuming that from the early pics showing the prototype M with eibach springs on, that was never confirmed though. BMW could've easily used different set ups at that time during testing.
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
12-24-2014, 12:39 PM | #4 |
Rep 984
$65k+ car, and the sleeve kit is expensive? Huh? Do it right or don't do it at all...
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
12-24-2014, 12:53 PM | #5 | |
Rep 184
12-24-2014, 01:18 PM | #6 | ||
Rep 184
12-24-2014, 01:25 PM | #7 |
Rep 184
I get that the geometry would change. I'm no engineer, but I'd be surprised tho if it, "totally threw it off"... Are you in the "don't touch the stock suspension" camp? Because I can't imagine other solutions guys are using wouldn't have an equal or greater impact on the stock setup. I'm talking equal spring rate, super small drop. The HR kits are way more aggressive, as are the coilovers (admittedly ignoring the ability to properly setup the KW systems).
12-24-2014, 01:41 PM | #8 |
Rep 5,396
12-24-2014, 02:33 PM | #9 | |
Rep 984
OP I think you should just buy a set of H&R or equivalent springs for what you are trying to accomplish.
12-24-2014, 02:46 PM | #12 |
Rep 984
Please, no one ever do this haha
12-24-2014, 06:36 PM | #13 | |
Rep 3,996
12-25-2014, 03:14 PM | #16 |
Rep 419
lol, nope. KW HAS just arrived yesterday, installing it this weekend.
Currently:
2022 M4 Comp xDrive 2022 M5 Comp Past: 2019 M5 Comp 2015 M4 |
12-26-2014, 10:03 AM | #17 |
4143
Rep 6,926
Someone is charging you $1000 for install/alignment? Ouch
12-30-2014, 09:57 AM | #18 | |
Rep 184
$960 sleeve kit after tax $250 alignment $1710. Guess I was a little high. Still pricey for what I want. Gonna leave it stock for now and wait for Eibach springs. |
12-30-2014, 01:30 PM | #19 |
Rep 3,039
Eibach's spring kit supposedly drops the rear .2" and the front .8"
If that's not sufficient wait for coilovers that are made specifically for the F80. |
12-31-2014, 08:05 AM | #21 |
Rep 1,495
Wow.
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
12-31-2014, 08:45 AM | #22 |
Rep 184
4 wheel alignment done by a guy that charges a premium because he can.... It's about $100 more than some other guys...
