01-02-2015, 12:04 AM | #1 |
Rep 455
Xenon Headlights
Looking for Xenons to replace my halogens and came across Bi xenon AKL. Can someone please explain what the difference of these and the regular ones that are a couple hundred cheaper? Any help or advice would be very helpful.
01-03-2015, 09:16 AM | #2 |
Rep 455
Found these as possible replacements on ECM. Euro Spec Bi-Xenon - OEM
Can anyone verify if these will work? THis is thier description. From BMW Europe comes this bi-xenon kit that drastically improves your US spec F22 lighting performance. If you have Xenon headlights this kit will eliminate the amber corners for you. If you have Halogen headlights, this kit will both delete amber corners and add Bi-Xenon lighting to your vehicle. |
01-13-2015, 08:20 AM | #3 |
Rep 455
Bump-
Been doing some research and seems not many have tackled this model yet but will soon. Aftermarket look O.K. but I'd really like to retrofit OEM if possible. Can anyone help with all required parts and any knowhow? I understand it will be expensive but plan to do it over time. Im sure someone else is kicking themselves not getting the xenons. Anyway, thanks |
01-13-2015, 09:14 AM | #4 | |
Rep 2,361
This is going to be a somewhat of a big project and cost will be easily 3-4x the price of having xenons equipped in the first place. Remember that Euro is RHD, so the projector cut off could be reversed You're probably going to have to code the car for xenons |
01-13-2015, 10:47 AM | #5 |
Rep 4,512
Its easy to flip xenon beam from RHD to LHD - says so in the owners manual
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
01-13-2015, 04:46 PM | #6 |
Rep 455
Ya I may just end up upgrading halogens and just get xenons next time. Money to other places may be smarter. Any ideas of what to do to make the halogens look thier best?
01-20-2015, 03:15 PM | #7 |
20
Rep 43
I have halogens as well and I hate them so much to be honest. Most solutions are rather costly and my car is a lease, so I'm planning on just swapping the bulbs to white/blue so they aren't that ugly yellow anymore.
01-20-2015, 03:25 PM | #8 |
Rep 455
I've been in contact with some on the xenon retrofit companies about the idea of working with mine. Many will at the expense of me possibly being without a car for a few weeks. Can't really swing that. I'd like to go Oem but seems to be a complete hassle.
01-20-2015, 06:45 PM | #10 |
Rep 177
I really don't understand why they won't just make the xenon lights standard and add LED's as an upgrade. At the very least use halogen projectors as standard. Even Hyundai does that.
01-30-2015, 01:29 AM | #13 |
Rep 36
ehm! Don't mean to be a ricer here but I installed these H7 LED headlight bulbs about a month back:
http://www.amazon.com/dp/B00MOR4CDI/...ing=UTF8&psc=1 So far so good. You can't tell they're not HIDs. The lighting seems to be on par with the factory halogens but not nearly as good as HID projectors. More glare than stock halogens but not blinding thanks to the headlight design. The installation was somewhat involved as I had to remove both front tires so that I could get in there and apply enough force to "clip" the bulb in. Not possible to install w/o taking the tires off. Bulbs have been very reliable.....and they turn on full power instantly unlike HID xenons. No delay at all. No flickering and no CANBUS error messages at all. This should do until f22 xenon headlights are more common on ebay. Last edited by fkacct; 01-30-2015 at 01:38 AM.. |
01-30-2015, 01:05 PM | #14 |
Rep 455
Ya I may focus on other mods I want to complete before headlights. They just bug me and I wish I got them from the factory. When they are available on eBay what all will be needed to get this to work correctly. Taking wheels and bumpers off seems like a big job.
02-13-2015, 06:45 PM | #16 |
Rep 6,925
Drives: 2018 M2 AW DCT
On my 128i I used PIAA H7 replacement bulbs. They are quite a bit brighter than stock but not as good as Xenons. But PIAAs don't cost a fortune either.
http://www.piaa.com/store/p/52-H7-XT...gen-Bulbs.aspx |
02-14-2015, 09:08 AM | #18 |
Rep 6,925
02-07-2016, 02:43 AM | #20 |
Rep 455
OSS Designs retrofitted a set a while back. They look good I just haven't taken the plunge yet. Check out their intagram page. Their work is second to none.
05-06-2016, 11:49 PM | #21 |
Rep 103
