Sidewall cracks in Conti Extreme Contact DW
01-02-2015, 06:09 PM | #1 |
187
Rep 1,677
Had a slow leak (hard to believe it was slow after seeing THIS) in my driver's side rear tire (Conti Extreme Contact DW) so I took it to my local Trax Tires dealer and had it checked out, expecting a small nail or bad valve stem.
And, instead...found MAJOR fissures on the inside sidewall of BOTH rear tires. I was shocked! Called TireRack and they sent me an Email to respond to with mileage, DOT dates, tread depth and pictures, which I have just done. But...anyone else experience this with Conti/DWs? Turns out, there are numerous reports on the Internet. I've had about 4 sets of these between my E46 and E93 and never had a problem. https://www.google.com/webhp?sourcei...e%20dw%20tires Now trying to decide whether to replace these with more DWs (which I have liked as far as mileage, ride and quietness) or...bite the bullet ($$$) and go back to Michelins.
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11) Last edited by Isaiah5411; 01-02-2015 at 07:56 PM.. |
01-02-2015, 07:10 PM | #2 |
BimmerPost Supporting Vendor
2045
Rep 25,989
Whoa, never seen that before with the Conti DW. Drive safe!
VMR|Wheels | 714.442.7916 |
01-02-2015, 11:18 PM | #3 |
Rep 2,383
I only have 18" rims, but got around 40 to 50k out of my last Conti DWs with no cracks like that. Now running Conti DWS with no problem after around 15k.
How many miles do you have on these and where are you (wondering about the climate they have been exposed to). I wonder if this is the kind of thing that happens when you hit a bad pothole too. These non-RFTs dont seem to bubble like the RFTs. Maybe they just crack.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
01-02-2015, 11:47 PM | #4 |
BMW Enthusiast
64
Rep 282
Michelin Pilot Super Sports ftw.
2014 VW Golf TDI 2011 BMW 335i e90 - Sold 1990 BMW 535i e34 - Sold 2008 BMW 335i e92 - Sold |
01-03-2015, 01:20 AM | #5 |
Fast In, Slow Out
40
Rep 586
I've had a Conti DW 265/35R18 rear tire sidewall blow out a few months ago. I really didn't think I hit anything and was <3,000 miles before it let go. I ended up getting PS2s as replacements. I should look at the second Conti to check for sidewall cracks.
: Ken
01-03-2015, 08:28 AM | #6 | |
187
Rep 1,677
I have a set of DWs on the front made in '09 that have the same number of miles (were removed due to damage to the rims) that are still perfect. It looks like Conti may have had problems in mid to late 2012 according to the Google search I did (above).
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11) |
01-03-2015, 03:51 PM | #7 |
Guest
Rep n/a
Drives:
I've had my fair share of QC issues with Conti DWS tires, but nothing that crazy.
Since you go pretty easy on your car, it might just be worth going with all seasons IMO. You'll likely double the amount of miles you get out of the tires and probably won't notice a huge difference in grip compared to those summer tires; especially when compared to something like the Michelin Pilot Sport A/S 3, etc. Just a thought... |
01-03-2015, 04:55 PM | #8 | |
187
Rep 1,677
What problems have you had with Contis? Edit: Probably going to step up tpo 245/35-19s. (I'm now in a square setup with 19x8.5s...12mm spacers in rear. Tired of going through two sets of rears for every one set of fronts. ) Ain't many all season choices in that size. In fact...there's ONE: The Michelin Pilot Sport A/S 3.
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11) Last edited by Isaiah5411; 01-03-2015 at 05:14 PM.. |
01-03-2015, 06:02 PM | #9 |
Guest
Rep n/a
Drives:
Nice! I would go for it. The square setup will help a lot too.
My QC issues involved getting multiple tires that had too much road force. Although the tires would "balance fine" they would shimmy/hop/vibrate/etc. until I got Conti to keep sending me tires until I found a set that didn't have any problems. I've posted on here before about it. |
01-03-2015, 06:30 PM | #10 | |
Rep 1,076
01-03-2015, 07:07 PM | #11 | |
Rep 2,383
Edit: Yeah, I guess the first suspect would be running the tires with too low pressure. Presumably the torque on the drive wheels with too low pressure might cause this on the rears and not on the fronts if you just let all the tires get too low with their natural loss of pressure (that reminds me I should check my tire pressure). I guess another possibility would be putting in too much pressure, but who would do that on both sides unless you have a defective pressure gauge (I have seen these on bad gas station compressors -- very dangerous). But if other people are reporting the problem too it sounds more like a manufacturing defect. Probably showing up on the drive wheels because of their torque. Good thing we have RWD in case somthing like this results in a blowout at high speed.
01-06-2015, 07:26 AM | #12 | |
187
Rep 1,677
Got the message from Tirerack that this issue would be covered under warranty. They have to be sent back for that to happen. I told them I was considering going to the Michelin PSS and it sounds like they are going to offer a discount option on the Michelins vs the warranty claim, which is not clear yet as to whether that claim would be a full replacement or a prorated one.
01-07-2015, 10:51 AM | #13 | |
Rep 632
One more reason for me not move to Cali. LOL |
01-11-2015, 11:39 AM | #14 |
187
Rep 1,677
Final resolution...
Discussed the situation with TireRack (who were GREAT in this situation, BTW...talk to Jane Yuhasz ) and they ended up giving me a set of Michelin Pilot Super Sports (which I decided to swap to) for 20% off on 4 tires (a $200 savings) rather than roll the dice with Conti over these two year-old, 32K mi tires by removing and returning the defective tires. Ordered them at noon-thirty on Tuesday and got them via UPS at 1:00PM the next day.
I'm happy with the outcome and LOVE the Michelin PSS, which are smooth, quiet and a much meatier looking tire (steeper sidewalls). These PSS help fill the wheel well and make the car look a bit more lowered. Glad I didn't order them in 245/35-19, tho. Not sure they would have fit without rubbing judging by the way they look now, especially in the rear with the 12mm spacers.
