JB4 G5ISO+USB, BNIB VRSF DP, 7in VRSF Intercooler, CP, Forge DV's +
01-12-2015, 08:03 PM | #1 |
Rep 9
Hello, (moved from non turbo) I know this is a first post, and have no issue meeting locally if concerned. Reason for sale is simple. Wife got cancer, lost job. 3 kids in school +med bills = bigger priorities. location is Marlton NJ I am selling a set of Brand New VRSF 3 in catless dowpipes, VRSF Dowpipe CEL fix and all included hardware. These have never been installed, and are new in box. retail for both $425. - Sold. Burger Tuning BMS JB4 G4 ISO rev. 28 piggy back. N54. - SOLD BMS Dual Cone intake, 3,000 miles. $50. BMS / CPE 3 in metal charge pipe with dual Meth/nitrous ports. Compatible with OEM DV valves. better throttle response, not going to blow off and crack under boost like the plastic snorkeled OEM pipe. N54 engine.-Sold VRSF 7 inch Bar and plate intercooler with upgraded lower charge pipe ($30). OEM intercooler sucks. When logging I saw nearly no IAT rise after hard 4th gear runs. OEM showed 20deg rise. 3,000 miles, no damage/bent fins. $400 _Pending Forge yellow spring DV valevs, made for the 335I - application specific. OEM diaphragms fail under high boost. Boost on the back side of the valve. -3000 miles. $250 All parts except for the DP's are on the car, will remove when sold. If you want it shipped, it's via paypal invoice only. Larger items will cost $10 to ship.(unless noted). None of these have seen the track, and I'm more than happy to answer questions. Link to photos is here - sadly NJ nuked the roads with salt right before I drove home so things are a bit dirty. https://www.dropbox.com/sc/nl79wwobw...beEG9hLrG1cnBa Jared Last edited by tuckntruck; 01-18-2015 at 10:29 AM.. |
01-12-2015, 08:07 PM | #2 |
Rep 1,086
Drives: '11 335i M-Sport [LeMans Blue]
Bump, sorry to hear about your situation.
If posted a few days ago I would have taken the FMIC, I couldn't find a used one for the longest time so I just ordered a new one Friday |
01-12-2015, 09:04 PM | #4 |
Rep 9
I should add, the pipes (as far as I know) will not fit the XI.
The intercooler will fit the 135/335i/XI N54 and N55. The charge pipe should fit 2006-2010 135/335, and 2011+ 1M and 335IS. |
01-13-2015, 11:05 AM | #7 |
Rep 9
01-13-2015, 10:31 PM | #8 |
Rep 9
BMS DCI, Charge pipe and DV valves are out...
Pictures in the link (dropbox)https://www.dropbox.com/sc/smmqpwta8..._g6bintOKF2d9a I'll try to pull the intercooler when it's not 20deg. out. I also have to get two replacement clamps for the oem connections. |
01-18-2015, 10:34 AM | #9 |
Rep 9
Updated the list.
DCI, Forge DV's JB4 G5 ISO board, no harness available Intercooler is still in the car, I am missing one of the spring clips from the OEM Intercooler. Should be getting the replacement monday. I also have a set of 15mm BMS spacers that I used on the rear wheels. $45 This Monday I'll be traveling to Dallas until the 26, so I won't be able to shop anything for a few days Thanks! |
03-04-2015, 08:14 PM | #13 |
Rep 141
Hey, do you still have the spacers, charge pipe+DVs??
2007 BMW 335i- stockish for now.. ZHP shifter, VRSF DPs, JB4..
2009 Chevy Cobalt SS- bolt-ons, 18/26psi tune: Easy M3 Killer [SOLD] |
03-06-2015, 09:09 AM | #16 |
Rep 9
Hi guys,
Sorry the car threw another check engine light on the way to work, so, I got rid of it. I don't have the VRsF intercooler, never got it off the car. I do have an OEM one. Leftovers at this point : Oil change kit from tischer, DCI Bavtech 1 vin cable ( used can still be used for the Bms back end flash) D-can obd II cable for coding VRSF downpipe fix. I'm in Columbus all week though, so won't be able to get to anything for a while |
03-07-2015, 10:09 AM | #17 |
Rep 2,283
Finally someone selling BMS Dual Cone Intake for a reasonable price.... GLWS OP!!
03-07-2015, 11:36 AM | #19 |
Rep 797
DCI Still Available?
| E92M IB |6MT| FULLY LOADED | EURO LCI'S | KW | RPI | AE PERF. | ROGUE ENG.| LUX AE | BMW PERF. | BMW GTS | MODE CARBON | FORCEWERKZ | M.S. HARDWARE| |SOLD |E90 BLUE WATER 6MT | BMW 219M | H&R | KW | BC-RACING | BMS | NGK | MOTORSPORT HARDWARE | WALBRO | UUC | VRSF | POWERFLEX | CX-RACING | OBX-RACING | 6-PUCK | STOP TECH | BMW PERF. | RPI | |
