e90 proper sized drain plug on the passenger side for an automatic??
03-02-2015, 04:48 PM | #1 |
Rep 41
Hey I was wondering if someone could verify for me the proper sized drain plug for a radiator that has two drain plugs, I am aware that some e90s have 1 plug others have 2. I have a 2006 e90 325i automatic. My OEM radiator had only one long drain plug on the driver side. However the replacement Nissens radiator has two drain plugs, one on the driver side and the other on the passenger side. I attached a pic of the directions for the Nissens radiator, my confusion is because the directions say that the radiator came with the proper plug already installed (the long plug on the driver side). However I had a leak from both plugs so I removed them, and saw that the passenger side plug is a short one. From the directions it looks like there should be a short plug in the passenger side for gasoline cars, you can see that in the picture. But when I checked realoem, they list the long plug as being used on both sides for the automatic. I called pelican parts but I think they just looked at realoem, and didn’t seem entirely confident about what they were telling me. I just don’t want to obstruct something and inadvertently cause an overheating situation, can someone with an automatic car and two drain plugs please clear up for me. Long or short plug for the passenger side Thanks! http://www.realoem.com/bmw/showparts...17&fg=05&hl=15 |
03-03-2015, 06:20 PM | #3 |
Rep 41
This is the longer drain plug/tube with the double orings, I did use this for the drivers side, but I still remain unclear if this longer tube is also what should be used on the passenger side.
this shorter tube was on the passenger side, as per directions I am led to believe I should be using this shorter tube, however realoem lists both drain plugs for automatic cars as the longer version pictured above. has anyone removed this thing from the passenger side on their car? |
05-08-2018, 04:37 PM | #4 |
Rep 6
same question
I think Nissens radiator for automatic already comes with both plugs pre-installed and the radiator is shipped with one of each drain plug in the package separately in a bag. The driver side has the long plug installed and the passenger side the short one. At least that's what the instruction says.
Driver side - I think for auto one should leave it as is (because package says long one is already installed) but for manual one should swap it with the shorter one. Passenger side - I think it comes with the shorter one pre-installed (I don't know why) but everyone should swap it with the longer one. Can anybody confirm this? Thanks. |
07-11-2018, 03:22 PM | #5 |
Rep 10
I'm replacing a factory radiator in a 2006 xi w/ Automatic transmission w/ after-market and have exactly the same question as has been raised here. I'm in agreement that the left (USA Driver) side should get a long plug.
But what about the right side? If I put a short plug in it seems to eliminate any coolant flow through the nearby fitting. That seems wrong, but the vendor (whom I don't really trust) says the short one is fine. |
07-13-2018, 10:30 AM | #7 |
Rep 10
07-28-2018, 10:24 AM | #8 |
Rep 10
Just to finish off this thread, the radiator I got was the p/n 2882 that is sold all over eBay for less than $100. It comes with NO plugs installed, just a short and long one in a bag. Problem is, consistent with what is indicated above, a 2006 xi with automatic transmission requires TWO LONG plugs - one in each of the fittings - same as the factory radiator.
After going back and fourth with the vendor, they finally relented and sent me another long plug. All is installed now and the car is back on the road. But I can't believe nobody else has even run into this issue, given how failure-prone the radiator is and the number of these cars sold. |
10-22-2018, 12:20 PM | #9 |
Rep 5
How to change the radiator plug
This is a helpful thread, but i am wondering how to actually change this drain assembly. It does not thread in/out, and i do not want to break it. Can someone inform as to how to change the drain assembly?
Thanks |
10-19-2020, 11:11 PM | #10 |
Rep 2,099
Not sure if this was definitive. So I have to tackle this job and got a Nissens.
I have an automatic 2011 E90 328i. So drivers side: Long plug for automatic (check) Passenger side: On my sheet it mentions the long one is for "BMW with aftercooler." I also see that on the example above that it says "deisel with aftercooler." I'm thinking both of these cases means I should be installing the shorter one on the passenger side (since my 328i N/A). Am I thinking of this wrong? Or was it really just a deisel vs gas question? (Dont know anything about diesel so forgive the ignorance). Then the post above says long on both (but curiously it might be diesel). I'm sure this probably makes logical sense (Seeing the piping in and out) if I cut the side off to see the flow of everything, but I was hoping to avoid that. Greater knowledge welcome. Last edited by bluewater328; 10-19-2020 at 11:16 PM.. |
10-20-2020, 08:41 AM | #11 | |
Rep 10
It sounds like the Nissens directions are no less confusing than the ones written in Chinglish. I recall reading them and giving up; just went with best replicating what was in the car originally. The car has been running for over two years now and several thousand miles, so I assume I got it right. It's amazing to me that this still continues to be such a point of confusion on such a common vehicle in a common configuration. |
10-20-2020, 08:55 AM | #12 | ||
Rep 2,099
But if you took that advice and it's been going well, that's exactly the confirmation I've been looking for. So Drivers side = Long for Automatic and Passenger side = Long [for those that use that small port on the passenger (right) side] [EDITED AFTER CONFIRMING] Thanks! Last edited by bluewater328; 10-29-2020 at 03:43 AM.. |
10-29-2020, 03:41 AM | #13 |
Rep 2,099
And to close the loop for those that come again, since my car did not leak and throw codes, let's go ahead and confirm that it's two long plugs for 2011 E90 328i. The way that helped me sort things is by the full new instructions sheet (that still sucks but that you can download from the Nissens site) but refers to the second long plug on passenger (right) side as "BMW with aftercooler" and references the picture of the port. So interpret that to mean: "If you use this port pictured, you need to switch to a LONG plug."
There are a couple of different hose configurations listed in realoem based on model/spec. But if you use that lower smaller port on the passenger side, you'll want to use the long plug on that side. Other more evident one remains on the driver's side (left): long for automatic, short for stick. Here are some of the common scenarios for smaller port use on right (passenger) side: https://www.realoem.com/bmw/enUS/sho...diagId=17_0704 (#11) https://www.realoem.com/bmw/enUS/sho...51#17127540020 (#10/11) Last edited by bluewater328; 10-29-2020 at 03:50 AM.. |
03-30-2021, 10:25 AM | #14 | |
Rep 17
Which plug I have to fit in the passenger side ? Long one or short ? And the big question is : what is an aftercooler ? Because here I don’t understand if I need short or long? ! So , long plug ? In the driver side I fitted long because I have automatic transmission but in the passenger side I still don’t get it My radiator have 4 hose plugs , 2 big ones and 2 small in the bottom of the radiator , one is for automatic transmission and one I don’t know for what ! So , do I have aftercooler ? Do I need long bottom in the passenger side ? Thank you ! Last edited by BZ92EEE; 03-30-2021 at 10:48 AM.. |
03-30-2021, 12:07 PM | #15 | |
Rep 2,099
Drivers side, since you have auto, yes, it should have the long one in there. |
03-30-2021, 01:54 PM | #16 | |
Rep 17
Thank you ! |
10-17-2023, 11:37 PM | #17 |
16 years and counting...
101
Rep 471
Can someone help me out here…
06 325i. Manual. I put in a new Nissens radiator today. As instructed I replaced the long plug that came installed in the drivers side with the short one that came with the radiator. And it leaks. It seems pretty clear that the plug isn’t sealing properly. Any ideas? |
01-30-2024, 12:52 PM | #18 | |
Rep 1
Leaks with short plug
The long plug was preinstalled on the drivers side which is fine for automatic. The short plug was installed on the passenger side, which leaked after install and as soon as I started adding fluid. The radiator was exchanged and the same thing happened. I swapped it out for the long plug, which stopped the leak but now I have no heat in the car. I saw a video yesterday of a guy testing the thermostat finding it was good and stating that the long plug is allowing cold water to go directly to the block never warming up. To test it, he pinched the hose and released it once the water was warm. I'm about to swap radiators for a non Nissens radiator. Oh an just a note. The original BMW radiator only has a drain plug on the drivers side. |
