First Drivers Ed .... Need advice
03-03-2015, 08:16 AM | #1 |
Rep 111
I am participating in my first drivers ed May 9th at Thompson Speedway in CT with the Porsche Club of America. I was hoping some members with tracking experience can chime in and give some advice.
Current Set Up : 2008 335i sedan sport package 6MT Cobb Stage 2 w/ catless DP / DCI / BMS Oil Cooler Vavle Brand New Micheline PSS Brand New Spark Plugs In preparation I want to put 4 new pads on the car and also switch to some high temp brake fluid. Any good recommendations for a good street / track brake pad? Any other recommendations from you guys that I do to prep? Thanks. |
03-03-2015, 05:47 PM | #2 |
Major nutz
86
Rep 1,488
Drives: '09 n54 e92xi, 6mt, kw v3
Cool Carbons, they are a hybrid pad. You can still fade them on track, but have more fade resistance than OEM. IMO, they have better modulation too. On the street, they don't have OEM brake torque (bite). Like I said, they are hybrid, so it's a compromise. Frankly I think you can just take the OEMs out... If you fade them (let your instructor know), good for you, you progressed and you can still improve. Also, I don't know how smooth Cobb is with throttle progression, but if it isn't, turn it off, otherwise your instructor may bug you about not being smooth with your right foot. Have fun.
03-03-2015, 09:05 PM | #4 |
Rep 3,778
Drives: '11 328i '19 M6
FWIW I've been running Carbotech XP10 on track and street since the summer. As good as OE cold bite even in below freezing weather after sitting outside for hours. Very predictable and low noise although they will squeal a bit at times. And they're rock solid on the track, no fade, great modulation. Get the pre-broken-in option and there's no need to bed them before going on track. Just offering another option.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
03-03-2015, 10:40 PM | #5 |
Major nutz
86
Rep 1,488
http://www.ctbrakes.com/brake-compounds2.asp
Those do look good, but their site mentions it's a track pad. I personally wouldn't recommend them for street since they don't, but I'll admit to driving track pads (a lot) on street when I retire them from track use (about 5 mm), then completely retire them at 3mm. But I'm just a dude on the internet, you should follow manufacturer's recommendations (noise and dust ha ha ha). BTW bm6w, happy reading. http://www.stoptech.com/technical-su...l-white-papers
03-03-2015, 11:24 PM | #6 | |
Rep 3,778
03-07-2015, 06:12 PM | #7 | |
Rep 2,669
Also bring spare pads, engine oil, spare tire, air pump and good pressure gage, tools. A 5 gal fuel can is not a bad idea also. I would recommend running stock tune. Have fun! |
03-07-2015, 06:43 PM | #8 |
Rep 175
It sounds like that you have never driven on a track before. If that's the case then it is way too early to worry about equipment. More likely it will be a struggle for you even to push a stock car to it's limit.
03-07-2015, 07:53 PM | #9 | |
260
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
A 335i has more power than just about any sports car from 25 years ago. Fresh brake fluid, brake pads that have 75% meat left- your car has 8 pads not 4 , and a good mechanical inspection from a mechanic that you trust (your chapter of the cca will give you a tech form that must be completed by a certified mechanic, rather than a shade tree mechanic). Other than that, leave any ego you may have at home, bring your active listening skills, learn the flags before you go and most of all have fun Also you may want to watch some youtube videos of fellow HPDEers at the track you are going too just to get familiar with the layout, and also to learn where the flag stations are before you go. Between that and knowing the flags before you go will put you ahead of the learning curve. Enjoy, post back!!
03-07-2015, 07:56 PM | #10 |
260
Rep 1,794
By the way, I just looked into the track you are going to- that's awesome! I remember reading about that place from a link on this forum (I think) a year or two ago. Glad to see it is all set. The place should be incredible.
03-07-2015, 08:43 PM | #11 |
Rep 3,778
Don't forget a good bright flashlight to look under the car for damage should you go off. Ask me how I know...
Why didn't I pull the wheels and look? Good question! The lugnuts were seized to the lugs, by rust I suspect. That's what I get for making it my daily during snow days I guess. Time for new lugs and lugnuts but they really ought to be replaced each season anyway.
03-07-2015, 09:54 PM | #12 |
Rep 1,004
ill be there too. just some advice, you really dont need stage 2. when i did njmp last year in my fbo 135i kept it on map 1 which was i think 14.5 psi, more than enough. i have some m3 bits and koni yellows and bmw performance springs. there is a lot to learn.
03-09-2015, 11:25 AM | #14 |
Rep 534
go back to a stock tune or Stage 1 to avoid heat issues. The oil temps spike pretty easily on the stock oil cooler
I don't think you''ll need track pads for your first time out but i use the Hawk HT-10's and love them! I would definitely get upgraded brake fluid peace of mind. I use Motul RBF 660, probably overkill but it gives me confidence. Good luck, Have Fun, and focus on your lines and smoothness speed will be a product of those two things. |
03-14-2015, 08:24 AM | #15 |
Rep 111
Thanks for the heads up. I'm actually getting a FMIC installed before the event. However I still plan on going back to stock or stage 1 to avoid heat issues.
I am running stock tire size of 225 up front and 255 in the rear...stock suspension. Been reading about spacers for improved handling. Anybody have experience with 15mm in the rear and 12mm in the front? |
03-15-2015, 06:33 PM | #16 |
2280
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.20] |
Either get real track pads or go stock. Any dual duty pad is going to be loud on street and have marginally better fade resistance than stock pads. OE pads usually do the job fine for your first DE. When you're ready for deeper braking then get track only pads. I do agree though you should get fresh high temp fluids, full flush not just bleed. Motul is great, Castrol even better but it's a bit pricey. And FYI don't bother running any map besides factory, you'll hit limp mode and lose half your expensive
track time. |
03-15-2015, 06:36 PM | #17 | |
2280
Rep 12,565
03-17-2015, 08:51 PM | #18 | |
Rep 111
04-07-2015, 05:18 PM | #19 |
Rep 111
1 month away from the event! I have installed a ER FMIC / Charge Pipe and BOV since my original post. I have purchased stoptech pads and having them installed this weekend.
What is idea tire pressure for the Micheline Pilot Super Sports? |
04-17-2015, 12:17 PM | #20 |
241
Rep 2,781
Drives: E90 335i Racecar
There really isn't a specific answer as it varies from driver to driver. For a beginner, I would start at around 38psi (front and rear) hot and lower it from there and gradually understand/feel the differences. Even after many track days, I can barely feel the difference between 34 and 35psi on my R888s (largely due to the fact I always have changing factors/conditions).
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
04-19-2015, 08:52 AM | #22 |
Automobilist
395
Rep 2,632
I drove that track last year with my 335i. I used stoptech street pads and ATE gold and it held up fine. There is one long straightaway where you have to brake down from 120 to about 40-45 to make turn 1 but it's a long straight so you get a lot of brake cooling there. The rest of the track is gas brake turn gas brake turn like autocross almost.
It's a very tight technical track so don't worry about power because you can't really use it. |
