BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - ///M Trunk Lip Spoiler for E92
      01-25-2008, 10:47 AM   #1
EHDEN
EHDEN's Avatar
Lebanon
393
Drives: 435i
2014 BMW 435i  [7.00]
Received it from the dealer:
Following items arrived with the purchase of the spoiler and are needed for the install.
Picture of it un-painted
First things, first...Get it PAINTED!
Now that that's done...follow these guidelines...
DISCLAIMER
Attempt this at your own risk. I am not responsible for faulty items nor mis-interpretation of my guidelines. This is simply what I did to get the result that I wanted to achieve.
STEP 1: Place the 2 corner double-sided tapes. (NOTE: Do NOT remove red strip until prompted.
STEP 2: Have a cutter handy as you will need it to cut the double-sided tape that will flow in the middle as they provide you with a bit much.
STEP 3: Once all the double-sided tape is in place on the bottom of the spoiler, it is time to do some testing.
STEP 4: TESTING.. When doing testing, do NOT be alarm if it looks as if it crooked as you will steer it (bend) as you mount it.
STEP 5: It's time to mount it! ****Be EXTRA careful as the glue on the double-sided tape will stick to your trunk very quickly.**** Remove the strip from the middle part ONLY! Leave the corner red strip on when mounting. It's a 2 step process. Do not worry, you will be able to remove the red strip once the middle part is mounted.
Picture of the spoiler mounted with the corner red strips still on.
STEP 6: Remove the corner red strips simultaneously as you angle the spoiler to fit your trunk perfectly!
Your Done! Now be proud of yourself!...
BEFORE & AFTER PHOTOS
I would like to thank my good old buddy Duck who kept me company!
      01-25-2008, 10:52 AM   #2
I335
I335's Avatar
122
Drives: '08 335i Coupe
Excellent write up, pics, & duck!
      01-25-2008, 11:12 AM   #3
bavarian19
bavarian19's Avatar
Drives: Car
Remember... the spoiler should sit between a 1/4 and a 1/2 of an inch back from the actual edge of the trunk line.
A DIY every E92 coupe should do
      01-25-2008, 11:15 AM   #4
MMAJNKE
MMA Changed My Life!
MMAJNKE's Avatar
Japan
316
Drives: e92 m3 & f30 328i
Awesome write up cool duck lol!!!
      01-25-2008, 01:39 PM   #5
Greeney
Greeney's Avatar
Drives: Jerez E90 M3
Love the duck!
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 |
      01-25-2008, 05:51 PM   #6
AJayE92
Drives: 2007 335i
2007 335i  [0.00]
Sickkk
[JBE92335i]www.youtube.com/italiombiano
[Black Dakota Leather] [ZSP] [ZPP] [AA Xede] [iconz 830Z] [9500i]
[CF Kidney Grilles] [CF Vorsteiner PD Hood] [M-tech Sides] [Custom AngelEyes]
[Aero Lip] [Painted Reflectors/lowergrilles] [AC/S Roof Spoiler]
      01-25-2008, 06:03 PM   #7
Soni
Soni's Avatar
218
Drives: Just a car
2007 335i Coupe  [9.00]
how do you line the spoiler up on the trunk??
      01-25-2008, 08:59 PM   #8
EHDEN
EHDEN's Avatar
Lebanon
393
Drives: 435i
with precision. I try it several times on how it will fit. When it was go time, i just aligned it from the left corner side of where I pictured it from all the testings and dropped it to perfection. That's the benefit of leaving the corner red strip last to remove.
      01-30-2008, 06:14 PM   #9
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
OK, now that sounds like an easy mod!! Did u get the spoiler from teh dealer? does it fit on a E90 335?? And Complments on the Wright up...BUT, I dont think you did that! I think the Duck did it abd you just took the Credit!!! j/k!!!
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      01-31-2008, 12:37 PM   #10
oldaccount
oldaccount's Avatar
Drives: Car
do you really have a pet duck, or was it just hanging around?
      01-31-2008, 10:59 PM   #11
EHDEN
EHDEN's Avatar
Lebanon
393
Drives: 435i
no, i really do have a pet duck. didnt' you see its duck name coller? lol
      01-31-2008, 11:02 PM   #12
oldaccount
oldaccount's Avatar
Drives: Car
a pet duck would be fuckin awesome. you could feed it bread all day.
      02-04-2008, 01:07 AM   #13
E90330iS
Germany
143
Drives: BMW M4
2006 330i  [0.00]
Great write-up EHDEN, I purchased a replica one from M Force, and I am not sure if it comes with the doublesided tape. In that case, what is recommended to use?
      02-23-2008, 10:02 PM   #14
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
Nicely done ehden!! I was lol'd at the duck. Btw, your spoiler looks god, but your tail pipes... eh not so much I wonder why they are so dirty....hmm....
Ian
      02-27-2008, 05:52 AM   #15
Audifan
Drives: 2014 BMW 335i Xi M Performance
Does anyone know the part number for the OEM M3 E90 & E92 trunk lip spoiler? I've got a 335i sedan on order and I've spoken to dealer re m3 lip spoiler - i keep getting different part numbers , want to make sure the right part is ordered.
Thanks!
      02-27-2008, 10:44 AM   #16
PAKMAN
PAKMAN's Avatar
North Korea
360
Drives: 2011 E92 M3
2011 BMW E92 M3  [9.50]
2006 e90 330i  [5.50]
how hard can installin a m3 spoiler be?
stock car
      02-27-2008, 06:10 PM   #17
markymarc1979
268
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
My only worry is aligning and centering it when your ready to drop it on the trunk. If you screw it up, you have to remove it and it might make a huge mess.
      03-10-2008, 08:52 PM   #18
EHDEN
EHDEN's Avatar
Lebanon
393
Drives: 435i
exactly! so don't! =)
      03-29-2008, 08:45 PM   #19
Luca335
Luca335's Avatar
55
Drives: AW 1M
Unhappy How to remove it???
Hi guys,
I had the bodyshop installed it for me but they screwed up! When they asked me if I would put it on myself I should have said yes. They placed it too close to the edge, should have been 1/4 inch from the edge. I can buy new double sided tape from the dealer to re-do it but who can tell me how to remove it without damaging the paint on the trunk. Would a fishline or dental floss work? I mean like some people removing the number badge.
Thanks in advance for all the help.
      03-29-2008, 09:29 PM   #20
cn555ic
cn555ic's Avatar
Drives: 335i
some have it flushed and some like it in alittle...Its more about preference...Its not wrong either way...Most people have it flushed...If you can live with it that way, which isn't wrong, I would leave it on because its a bitch to get the tape off...You have to get every inch of tape residue off before you apply the new tape on...I would leave it because like I said most member here have it flushed.
      03-29-2008, 10:25 PM   #21
Appropriate
Appropriate's Avatar
Drives: 2008 BMW E92 335xi
2008 E92 335xi  [0.00]
Lets see pics Luca.
      03-30-2008, 07:46 AM   #22
dwarner4
Teutonic Enthusiast
dwarner4's Avatar
Drives: '07 E91x
Turnermotorsports.com has a special going on for the M3 type spoiler for the E90 sedan and E92 coupe. The claim to be OEM and are selling for under $200...
