2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Dinan Spring Install - Issue?
      03-06-2015, 09:52 PM   #1
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
So, this week I finally got the Dinan spring set installed on my M235. The ride is great, very notably less bouncy but not overly firm - Just excellent.
One issue. After the install, the ride height lowered by about 1/16" from the stock height. Stated drop should be 1/2" front, 1" rear. Called Dinan, confirmed part numbers to be sure (matched) and they said I should wait 1000 miles for the springs to settle.
From my experience, I think I should have seen an immediate drop out the gate. The settle should sort out the last 1/4" or less I think.
Is it more likely they were installed poorly (local tuner shop did the install) or did I get a bad batch of springs? Anyone else ever have something like this happen with spring applications before?
Just a bit frustrated atm and I don't have a lift to double check all the work to eliminate that concern. Thoughts?
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      03-06-2015, 09:56 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
maybe this ?
http://www.dinancars.com/product/d10...f22-m235i-rwd/
NOTICE: Dinan Performance Spring sets should be purchased and installed with the corresponding Ride Quality and Handling Kit to achieve the advertised ride height, performance, and ride quality. While not explicitly required, if the matching component is not purchased and installed you will get less than favorable results in the form of poor ride quality and improper handling traits. While we will maintain a full warranty on product defects, any claims against the car’s improper handling/ride quality traits due to not purchasing the corresponding handling kit will not be warranted.
These are HR but I would expect similar results with the dinan set http://www.2addicts.com/forums/showthread.php?t=982778
      03-06-2015, 10:18 PM   #3
hoppy6698
hoppy6698's Avatar
Originally Posted by pikcachu View Post
maybe this ?
The "kit" from Dinan only comes with new bump stops - nothing that would affect the lowering in any way. HR is a good example - they sell theirs without a "handling kit" but still manage to lower 1" all around.
I knew they would not warranty the springs if they failed, but the quoted installs of over $1500 is not worth the warranty.
      03-06-2015, 11:34 PM   #4
pikcachu
pikcachu's Avatar
1399
Not sure then.... maybe it wasn't installed correctly... but isn't it just the springs? what can you screw up on the install ?
      03-06-2015, 11:37 PM   #5
hoppy6698
hoppy6698's Avatar
My thought exactly ... now I wonder if the new spring batch is off a bit. May have to get a different garage to take a look at it. If all I can expect out of the Dinan springs is a 1/16" drop, they will definitely be replaced by HRs.
      03-08-2015, 12:38 AM   #6
RDKing2
Drives: 2015 M235i, 2004 M3
TBH I have not looked at the F22 front end, if similar to the e46. The strut assembly may not be fully seated in the steering knuckle pinch bolt.
      03-08-2015, 12:48 AM   #7
MrBucket
Drives: '17 AW M2 6MT Exec Pack
Best shot I got of my car (stock suspension) showing the part you are talking about
      03-08-2015, 06:38 PM   #8
hoppy6698
hoppy6698's Avatar
Thanks, had not thought of that one either!
      03-09-2015, 12:25 AM   #9
configt
configt's Avatar
150
Drives: 2015 EB M235i
Could you get a shot of you measuring the front and rear gap? I have the same setup and am wondering the same thing now.
      03-09-2015, 09:12 AM   #10
hoppy6698
hoppy6698's Avatar
As Dinan recommends, measuring from the center of the wheel to the arch, here are my heights:
F: 13.25"
R: 13.5"
The Dinan rep I talked to said they should settle to 13" in both front and rear. While the rear has come down about 1/4", I somehow doubt I will see another 1/2" in the next 800 miles to meet their 1000 mile break in. So, overall, I am seeing about 1/4" drop all around from stock
I guess time will tell. But if they do not drop to the stated heights, Dinan will not find me a fan or supporter. HR springs will at least hit near their claimed drop height immediately after install, settling the last 1/4-1/16" over a few weeks. Oh, and they cost a good chunk less for nearly the same performance.
      03-09-2015, 11:26 AM   #11
configt
configt's Avatar
150
F: 13.25"
R: 13.5"
I just checked mine. It is exactly the same @ F: 13.25" and R: 13.5".
I have had mine on for 1400 miles now. I don't think they will be settling any more.
If I decide to get new wheels, I will also be going to H&R springs. Pretty sad. I paid too much for the Dinans.
      03-09-2015, 10:54 PM   #12
hoppy6698
hoppy6698's Avatar
Looks like I need to call Dinan and make an official complaint then. They claim drops to 13" all around and neither of us are close to that.
Extremely happy that I did not pay the $1200+ Dinan installation fee! I think that would have sent me over the edge.
      03-09-2015, 11:30 PM   #13
configt
configt's Avatar
150
Let me know what they say. The more I think about this the more it bugs me. I think I will go H&R with new wheels later this year.
      03-10-2015, 12:06 AM   #14
pikcachu
pikcachu's Avatar
1399
what's the reason you guys went with Dinan instead of the HR?
      03-10-2015, 12:34 PM   #15
configt
configt's Avatar
150
New to BMWs and thought Dinan was the premium company to go with. Basically I was an idiot lol.
      03-10-2015, 01:00 PM   #16
pikcachu
pikcachu's Avatar
1399
Ah I see.... Ya seems like Dinan is not what it used to be... and higher prices don't help either... like with their Stage 1 tune lol
Do they allow you to return the items if you don't like it?
      03-10-2015, 02:12 PM   #17
configt
configt's Avatar
150
It's probably way too late. I have had them on for 2 months now.
      03-10-2015, 07:01 PM   #18
Silvermike
Silvermike's Avatar
Trinidad_and_tobago
143
Drives: 2015 AW M220i 6MT
2015 M220  [9.50]
I just measured my H&R setup.
F - 13.25"
R - 13.4"
So not much difference in it.
      03-10-2015, 08:37 PM   #19
hoppy6698
hoppy6698's Avatar
I went with Dinan for a couple reasons. First, the rake is not as much as HR (only 1/2" drop up front on Dinan vs. the 1" on HR). Second, having had HRs in the past (albeit with a more aggressive drop) I was hoping the Dinans would be a bit softer for DD, while sufficient for track time as well. On the second bit, I bet the ride feel between the two is a wash honestly. Owners of both compliment them for the same ride improvements - less bounce/upset over bumps and less lean in corners.
F - 13.25"
R - 13.4"
That actually helps a lot! Thank you for the input. Anyone got the stock measurements? Middle of wheel to arch please
      03-10-2015, 08:52 PM   #20
pikcachu
pikcachu's Avatar
1399
Mine are F - 13.6" R - 13.5" ... weird that front is higher than the rear
      03-10-2015, 09:29 PM   #21
hoppy6698
hoppy6698's Avatar
That is odd - it always looked like it had at least some slight rake in stock form. But even more odd is that our rear is the same height. Something sounds fishy from the spring sellers. I swear that a few pics from guys like Abirmaher have a much more flush look. Think I may have to meet someone local and measure side by side?
      03-11-2015, 03:51 PM   #22
BLK235iNJ
BLK235iNJ's Avatar
182
Drives: m235i,13MustangGT,84C10,99A8
I have the dinan springs and handling kit and my car is definitely lowered to advertised specs.
2addicts
