N52 Rough Idle
03-17-2015, 07:42 AM | #1 |
Rep 14
N52 Rough Idle
Hi Guys,
I just got myself a 2006 325i and it drove great for the first few days. However, we had a big snow storm and it got covered in a drift. I dug it out and when I started it up it had a rough idle. The needle only bounces +-75ish rpms but there is a noticeable vibration that goes away when its driving. I got a CEL and will pick up a code scanner tomorrow but I am wondering if you guys just think its a bad coil or something else? Would a dirty map sensor or ICV cause this? I want to clean them out because the car has 203k km's on it anyways but I was just wondering if you guys have any thoughts. Also are there any other sensors I should clean while im at it? Thanks a bunch! |
03-17-2015, 07:49 AM | #3 |
Rep 14
Okay sounds good! I will let you guys know the code when I have it. But are there any other sensors that I should be cleaning while im working on the car? Or any other preventative maintenance steps I should take? The previous owner took good care of it and got it serviced regularly but from the looks of it, it needs a good cleaning haha. There's a decent layer of dirt coating the whole engine bay.
03-17-2015, 04:13 PM | #5 |
17317
Rep 18,740
It's past 100,000 miles, so it needs plugs if they weren't done at 166KM. Bets to scan first and diagnose later.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
03-17-2015, 06:51 PM | #6 |
Rep 14
The plugs were done at 170ish and I looked at them today and they seemed fine. I also cleaned my maf and looked for oil in my eccentric shaft sensor and everything looked good but I have the same idle. I am hoping I have a misfire code tomorrow because that would make this pretty easy and I wont have to deal with the horror stories a lot of people have. Also the vibrations stop at higher revs so I think its a misfire but ill let you guys know tomorrow! Thanks for all of your help!
03-18-2015, 10:15 PM | #7 |
Rep 14
Hey guys! So i pulled the code and it was a misfire in cylinder #5. I got a new coil and she runs great again! However, im still just wondering what sensors I should clean? I have read a lot of stuff on the vanos solenoids and it seems like they can get gummed up. Is it worth taking them out and cleaning them?
03-19-2015, 05:14 AM | #8 | |
17317
Rep 18,740
