Kicker 8" L7 and Kicker ZX3001 Amplifier for Sale
03-29-2015, 03:44 PM | #1 |
Rep 69
I am selling my Kicker 8" L& Subwoofer including the aluminum grill and a Kicker ZX3001 Mono Block amplifier.
I used them for about 4 months before selling my vehicle they are in perfect working condition. I paid $230 for the Subwoofer, $20 for the Grill and $130 for the Amp. Looking to get $270 for everything. I am Located in Astoria Queens. I will also throw in the Kicker 10ZXRC Remote Bass Control for Kicker ZX Amplifier ($20 value) (I DO NOT HAVE THE WIRE). Below are the Subwoofer and Amplifier Specs. Subwoofer 4 OHM 11S8L74 Product Highlights: 8" subwoofer with dual 4-ohm voice coils square SoloKon™ polypropylene cone with Santoprene rubber surround aluminum basket power range: 100-450 watts RMS (225 watts per voice coil) peak power: 900 watts frequency response: 28-100 Hz sensitivity: 82.37 dB mounting depth: 4-3/4" sealed box volume: 0.5-0.75 cubic feet ported box volume: 0.66-1.0 cu. ft. Kicker ZX3001 300W Monoblock Car Amplifier ZX Series Class AB Monoblock Car Amplifier RMS Power Rating: 4 ohms: 150 watts x 1 chan. 2 ohms: 300 watts x 1 chan. MOSFET power supply LED power and protection indicators Optional bass remote Kicker 10ZXRC sold separately Tuned Bass EQ (0-12 dB bass boost at 40 Hz) FIT (Fail-Safe Integration Technology) utilizes differential inputs to reject noise and electrical interference for the quietest operation possible and ultimate audio clarity Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios Optional vinyl skins for personalizing heat sinks available Eliminates unwanted noise in a system Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel Bridgeable operation Speaker-level inputs compatible (switchable) through RCA connection Preamp RCA outputs Automatic turn on modes: remote, DC offset, or signal sense Thermal, voltage, and short circuit protection circuitry Fixed low-pass filter (80 Hz, 24 dB/octave) Subsonic Filter (24 dB at 25 Hz) CEA-2006 compliant amplifier Frequency response: 25-20,000 Hz Dimensions: 13-1/2"L x 9-5/8"W x 2-1/8"H 8-gauge power and ground leads recommended |
