03-30-2015, 07:26 PM | #1 |
Rep 4
CKS Coilovers for F10
I bought these from IE92 a few months ago, but I never got to installing them on my 535d and by now I decided to keep that car stock as I use it to travel a lot. I'm not sure how many miles are on them from him, but the coil overs seem to appear in good condition. i did not install or put any miles on them myself. I am asking $850 + shipping from 89142 - or best offer. You can PM me here or email me at dannylaosyvii@gmail.com Thanks for looking! For sale is a used set of CKS Coilovers for the F10. They are in very good condition. CKS coilovers are built using only the highest grade materials. The upper mounts, lower mounts and spring perch are made out of 6061 T6 aluminum, and rely on SAE 9254 (500,000 times of compression test) springs and SCM440 hardened piston rods. Giving you a smooth and solid feeling ride, it doesn't matter if you're driving through city pot holes, or racing on a track at 100+ mph. The bottom line is that after all those years of development, CKS gives you a one of a kind coilover and a guaranteed peace of mind knowing you're driving with the most reliable, safe and highest performing coilover on the market. -mono-tube shock design (inner polished seamless 55mm steel tube) -44mm linear characteristic internal piston -Italian IP F.A 5W shock oil: very high viscosity index guarantees efficient shock absorbing movement at any ambient temperature. -hard anodized forged aluminum upper mounts spring perch and lower mount -24 way dampening adjustability with a 12kg spring rate on the front and 10kg spring rate on the rear, making these CKS coilovers a true set of fully adjustable coil overs Retail price is $1,850 |
06-17-2017, 09:58 PM | #5 | |
Rep 81
Jayson Brown
