Idle issue with 2011 n55 335i
04-01-2015, 04:53 PM | #1 |
29
Rep 360
Hello,
Car is at 41,8xx still under warranty. Started to notice this issue after my last visit to the dealer. When I slow down the rpms spikes/car shutters a few seconds. Also when I come to a complete stop traffic or parking. The car lurches forward or feels as the brakes were slipping. Maybe it's just the rpm spiking as well? Also get the same feelings bf shifting from R-D Any ideas thanks ! |
04-01-2015, 06:09 PM | #2 |
Rep 560
Sounds like spark plugs. I have a similar issues and plan to do them in the next couple of weeks. If you haven't had plugs done it sounds like it's time!
Competition Package | OEM Exhaust Mod | Test Pipes | BPM Stage II Tune |CF High Kick Spoiler | CF Splitters | Gloss Black Grilles
YouTube | INSTAGRAM | My New Website: Shifted-Perspective.com | DM for discounts on: LUX ANGEL EYES or BPM TUNES |
04-05-2015, 10:05 PM | #3 |
14
Rep 66
are you getting any misfire codes? it could need a walnut blasting, left un-modded these cars usually dont need plugs till around 75-80k and coils around 100k.
04-07-2015, 05:28 PM | #5 |
Rep 1,203
situation
Intermittently, the engine idle speed may fluctuate up and down or cut off under any of the following circumstances, without any relevant faults stored in the DME memory: •While driving off throttle (coasting) and braking at speeds below approx. 10 mph •While idling, low-speed maneuvering such as parking, or if the steering is turned to the full-lock position cause Unfavorable DME software Perform diagnostics using ISTA/D and work through the recommended test modules found using the path below: Activities / Function Structure / 01 Engine / Engine electronics / [!] Current fault patterns / Engine stops/problem starting engine Depending on the vehicle and engine variant, program the vehicle using the latest version of ISTA/P only if the current integration level is lower than what is listed below. Car needs programmed to latest I-level BTW N55 dont need walnut blasted |
04-08-2015, 03:14 AM | #6 |
Rep 2,015
04-08-2015, 06:29 PM | #7 |
Rep 560
+1 Id like to know too. Nice to know I won't need it!
04-09-2015, 01:07 PM | #9 |
14
Rep 66
Yea but it has the same intake manifold and cylinder head, as well as same direct injection system, so what would the valve cover have to do with the n55 not needing it. I have personally seen n55 engines that needed it done have it done and it fixed the issue.
I was a BMW technician for 2 years, and at no point did they tell us not to perform walnut blasting/carbon cleaning on the N55 motor. As a matter of fact, according to BMW, regardless of the software version running in the DME, ALL BMW models equipped with the twin turbo or twin power turbo system require or will require at some time to have the carbon cleaned. Just recently saw a 2013 X3 4 cylinder need it done. |
04-09-2015, 01:27 PM | #10 |
Rep 952
Regarding the N55 need for walnut blasting: This has been discussed on several other threads. The general opinion has been that most N55 motors have had fewer problems associated with carbon buildup in the intake. Note that this does not mean you will never see this problem in an N55.
Two reasons why the N55 seems to have less carbon build-up: 1) The N55 has not been in service as long as the N54. This means we may not be seeing N55's that have carbon issues simply because the engine have fewer miles. Time will tell. 2) The oil separator on the crankcase vent of the N55 is very different from the N54. The N55 does a better job of 'cleaning' oil out of the crankcase gases that are recycled into the intake air. This reduces the amount of carbon that builds up in the intake of the N55. I'll see if I can find one of the related threads and post it here. |
04-09-2015, 07:12 PM | #11 | |
Rep 1,203
N54,N63,N74 are all equipped with Piezo fuel injectors N20/6,N55,N63TU are all with Bosch solenoid fuel injectors |
04-09-2015, 07:19 PM | #12 | |
14
Rep 66
As far as the DI systems go, they may be different but a Mini R56/57 engine is completely different however they also require blasting, any direct injected car will over time accumulate carbon buildup, due to emissions standards, all of the cars are having their PCV systems geared towards less emissions more maintenance. If you know so much, why dont u tell the over 5,000 people with N55 that have had their engine blasted they wasted their money on an unnecessary service. |
04-09-2015, 07:30 PM | #13 | |
Rep 1,203
04-11-2015, 03:41 AM | #14 |
Rep 2,015
I am getting the feeling that a n55 still may require a walnut blast, but maybe not as frequent as a n54.
If 50~ for a n54. Then 80~ for n55.....total guess here. DN |
