Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > N55 - 192,000 Service
      04-06-2015, 08:13 AM   #1
D's Bimmer
235
Drives: 2016 340 Xi
Good Morning!
I am preparing to get my car in for a major service as I am rolling up to 192,000kms. I have always followed Mike's preferred service schedule which is found on the forum.
My questions are around which fluids specifically are people using for the following:
Brake Fluid
Manual Transmission Clutch Fluid
Manual Transmission Gearbox Fluid
Differential Oil
Do I stick with OEM fluid or are there better options that I should use?
Thanks,
D
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
      04-06-2015, 10:49 AM   #2
Saintor
Saintor's Avatar
79
Drives: E90
Did you have the carbon deposits issues in 120000 miles?
BTW, I'd rather have the dealer do the brake fluid change; they are so much more equipped and it is not expensive.
      04-06-2015, 05:38 PM   #3
123Britt
Drives: 15 M235i AT
Red Line Vs Oem
OK - so I boiled down the question to RL vs OEM.
IMO RL 75w-90 for diff is really good as well as other RL MT or ATF fluids.
I think the OEM fluids are more lifetime or 100k fluids ~ meaning OEM fluids need to be changed around 50k while the RL fluids would need to be replaced every 30k.
At least this is my schedule -- although I have used OEM MT fluid but RL in the DIFF.
RL 5W-30 oil with OCI of 5K in an N54 for me as well -- RL has been great.
      04-10-2015, 03:53 PM   #4
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
RL 75/90 NS for the diff unless you have a clutch type LSD
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
