04-11-2015, 05:40 PM | #1 |
Rep 116
F30 H&R Full Coilovers (used)
H&R Full Coilover set up $600 (Used 1 year) 9,000 miles Height adjustment range: F: -1.5-2.6" R: -1.3-2.3" This coilover kit fits the following BMWs: 2012+ F30 BMW 320i 328i 335i - Sedan 2013+ F32 BMW 428i 435i - Coupe The H&R Street Performance Coil Over kit takes the traditional shock/spring package one step further. H&R combines their progressive-rate springs with specially valved shocks and adds height adjusters that let you set the ride height to your own personal tastes. These coil overs are designed for street use with progressive rate springs that start out soft and stiffen as they are compressed. This helps to keep the ride compliant while still giving better handling and balance. H&R designs each suspension to work as a coil over. This means that the correct amount of travel has been built into each shock. And the shocks are valved specifically for the spring rates to give a tight and controlled ride without being harsh or ultra-stiff. Each H&R coil over is TUV tested and approved and meets ISO quality standards. These are used with the stock strut and shock mounts for a quick and easy install. Last edited by m3f80gold; 05-18-2015 at 12:08 PM.. |
04-15-2015, 03:14 AM | #3 | |
4488
Rep 10,473
04-22-2015, 02:49 PM | #4 |
Rep 116
