04-26-2015, 08:05 PM | #1 |
Rep 16
Drives: 2015 M3
Excessive chipping on side skirts and quarters
I am having a problem with paint chipping from what appears to be rocks/debris coming off the tires and hitting the side skirts and rear quarter wheel flares. My car just went over 1000 miles and it is starting to look really bad. On the rear quarters the paint damage is really evident just above the factory protective film. It looks like it is slowly getting sand blasted. My car is black so it is just that much easier to see the damage. I can't imagine what this is going to look like after a few thousand miles.
I told my dealer about it at my first service and they said a BMW rep will need to look at it. What is the chance that BMW will do anything about this? It is not like it is a stray rock hitting the car. It clearly looks like a defect either with my paint or the design of the car. Is anyone else experiencing this problem? |
04-27-2015, 03:11 AM | #2 |
Rep 601
Drives: 2015 M4
I would be surprised if there was a paint defect and BMW did anything. If you're on the freeway a lot, particularly where there is are cement barriers on one side of the lane you are in. The small stones fly up and ricochet off the wall. Where do you mostly drive? Freeway? Side streets?
You could maybe see about getting a clear wrap over those panels, ASAP.
2015 AY M4
04-27-2015, 06:05 AM | #3 | |
Rep 16
Drives: 2015 M3
04-27-2015, 07:07 AM | #4 | |
19
Rep 47
04-27-2015, 09:58 AM | #5 |
Rep 16
Drives: 2015 M3
Most of the spots look to be clear coat damage. I think I am beyond putting protective film on. The factory film is already beat up. Both sides look the same.
This one is of the door edge behind the front tire. It is actually damaging the door more than the rocker panel. |
04-27-2015, 11:07 AM | #6 |
1941
Rep 1,552
sorry to see this. after only 200 miles I had a few similar chips, so I went ahead and touched them up and applied large spots of PPF around that area. Unfortunately I think the car is just prone to throwing stuff up right there.
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
04-27-2015, 03:06 PM | #8 | |
Rep 16
Drives: 2015 M3
The closer I look at the car the part of the rocker panel inside the front wheel well is all beat up and is missing the paint and the lip of the rear bumper inside the rear wheel well is the same. |
04-27-2015, 03:44 PM | #9 |
Rep 16
Drives: 2015 M3
Both the rocker panel and rear bumper have a lot of pitting in the plastic
Front Rocker Rear Bumper |
04-29-2015, 11:09 AM | #10 |
Rep 894
Drives: 2011 Toyota 4Runner Trail
It's a car....drive it!
Current: 2011 Toyota 4Runner Trail
Sold: 2013 BMW 335is Coupe |
04-29-2015, 07:32 PM | #11 |
Rep 496
Do you have any pictures of that show the damaged areas from further away? I'd like to see what areas are having problems so I can have film installed on those spots.
04-29-2015, 07:39 PM | #12 |
617
Rep 1,820
Lots of sympathy, been through this with my X5 and with Carbon Black paint it resulted in a look exactly like yours. I was praying this wouldn't be an issue with the M3 but it definately is.
2016 Individual Silverlake/Amaro M3 Conceived by ///M
04-29-2015, 09:37 PM | #13 |
Rep 16
Drives: 2015 M3
I don't. You would need to wrap the entire rocker and 8" up the door. You would also need to remove the factory film on the quarter panel flare and install an new piece the goes 6" higher and starts inside the door and wraps around to the rear tire well. The rear bumper would also need to be protected behind the rear wheel well.
04-30-2015, 12:37 AM | #14 |
Rep 732
http://www.xpel.com/products/paint_p...ake=4&model=69
I took a look on xpel website 2 weeks ago and looked at it again today. Seems like they have all the templetes for the M3 now. Anyways, I used the same PSS tires on my Interlagos Blue M5 and didn't have any paint chips from the tires at all. Could this be a problem with the black paint? |
04-30-2015, 02:41 AM | #15 |
Rep 601
Drives: 2015 M4
Boy that really sucks. I know in the winter time there are a lot more stones on the roads - that looks like it's getting sand blasted. Getting a clear bra on those areas might protect it from further damage but doesn't solve the issue. And, they'll get chewed up fast. If others aren't reporting that, there has to be something on the route you take?
2015 AY M4
04-30-2015, 03:30 AM | #16 |
Rep 982
Was planning to have the front of the car done along with part of the bonnet and roof
will now look into getting the rocker panels covered and the rear fender as I plan on going with more aggressive wheels |
04-30-2015, 10:04 AM | #17 | |
Christmas Poo
1003
Rep 1,166
04-30-2015, 10:48 AM | #18 | |
Rep 16
Drives: 2015 M3
I guess the cinder and sand that they drop around here for snow is causing this. There are big piles of it everywhere. |
04-30-2015, 10:58 AM | #19 | |
Rep 16
Drives: 2015 M3
04-30-2015, 11:01 AM | #20 |
Christmas Poo
1003
Rep 1,166
05-02-2015, 09:35 AM | #22 |
Rep 6
I have the same problem on my M 4 I spoke to the dealer and they say they have not seen the problem before. I purchase the appearance package that included the installation of 3M on the front and mirrors but did not include the area on the lower plastic panel just in front of the rear wheels where the paint is severely damages in just 2000km. If this was a problem they were aware of the 3M application should have included these vulnerable areas. I intend to continue to Persue this with the dealer and if necessary with BMW Canada.
