let's talk about coilovers,wheels,tires for auto x, daily driver
04-30-2015, 11:49 AM | #1 |
Rep 185
Ok so I did another auto x and had a blast. Pretty fun way to spend an afternoon w some buddies.
I'm stock sport suspension and run flats. The car is a handful. I feel like I'm driving a Cadillac w all the body roll. Haha ok it's not that bad but it's not great either. So I'm thinking of running some 18x9.5 apex arc 8's. 9.5 front and rear so the concave match. They don't offer a profile 3 in a 9.0 like they do w the 17" options. I'm not sure about running 255/35 square??? I would like to run a wider tire out back to help w traction. Anything smaller than a 255 up front is going to look stretched on a 9.5. Not my thing. So coilovers. Where to begin? There are some BC racing coil overs on ebay that have camber plates included. I'm probably going to need to have the ability to dial in some negative camber w a 9.5 w a 255/35 up front. Are these coilovers just junk? I'm not looking to spend thousands and thousands on coilovers but I am mainly looking for a way to drop the car, keep it flat through hard cornering and just generally be a nice upgrade in handling from stock suspension. Im not trying to have the most bad ass auto x car or track car. I just would lIke it to be more competetive w some of the other cars. I have a buddy w a c6 w sticky rubber who routinely is 3 seconds a lap faster. Are there any other coilovers I should consider? KW's seem popular but is a big part of the cost the name? They are expensive when compared to other offerings. Anyway would be curious to hear your thoughts. Oh sway bars? Dif lockdown? LSD would be fun and it also might be on the horizon. |
04-30-2015, 04:07 PM | #2 |
Rep 969
If you want to avoid being frustrated, pick the class you want to build toward and stick to the allowances. Nothing is more frustrating that spending money and not improving relative to competition. With that said, I'd either build to FStreet (means 18x9F,18x10R if you are ZCP or 18x8.5F,18x9.5R) and no coilovers but certainly zoomy struts/shocks. If you want to roll in STU or ESP, then have at it. My feeling is you would be Vette fodder in STU and might be competitive in ESP but then would need to be willing to seriously compromise the street nature of the car and spend gobs on A7's.
Ooops -- thought this was posted on M3post. Much of it applies. Just don't get to use as wide of wheels. sorry
Sold 2011.5 E92 M3 ZCP.
04-30-2015, 05:01 PM | #3 |
Rep 3,251
I would imagine it would be very difficult to make a non-M e9x 335i competitive, mostly because you can't fit any tires wider than 255 or 265 up front.
For a 3500-3600 lbs, slightly front heavy car, you really want something like a super sticky 275 or 285 tires up front to make the front end bits in those rapid maneuver. It would be nearly impossible to beat a Vett, as those cars have lower CG, at least 500lb lighter, more power, better weight distribution, and wider tires. Road course is slightly different, as you have more room and time to load up the front with trail braking and eliminating some of the understeering characteristics of the chassis with your driving style. Try a stiffer front sway bar, and stiffer spring and shock combo (Bilstein, Koni yellow paired with BMW performance springs). Add in M3 control arms if you want better steering feel.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
04-30-2015, 06:07 PM | #4 | |
Rep 259
FYI... for street prepared we fall into ASP not ESP. On a related note, has anyone noticed that tires in street and street prepared classes must have a minimum tread wear rating of 200 this year? No more race tires!
2007 335xi 6AT | Cobb Stage1+ | BMS DCI | VRSF 7" IC | FA 500 400#F/600#R | ARC8 17x9 et30 | RE-11a 255/40/17
Parting out car. For sale thread here: http://www.e90post.com/forums/showthread.php?t=1167583 |
04-30-2015, 08:09 PM | #5 |
Rep 185
Guys thanks for the info. I agree its a fine line between having fun w your buddies and being competetive. Like I said im not looking to win in a 335i. You realize real quick that the car really isnt geared towards these types of events. Its still a very fun way to spend some time w/ my car buddies and I want to keep it that way. I have had years of competetive road and offroad racing motorcycles so its important for me to just keep it fun and keep it casual. Once it gets taken too seriously the fun can be drained away. For this reason I am mainly just interested in running w/ the local porsche club where I fall into the RWD group. Im still pulled in too many directions w the bikes to have another wallet draining hobby.
Im just mainly looking at some things to make my daily driver better at auto x than it is stock. Im just wondering about some of the lesser expensive coils paired w M3 control arms and if they would be better than what I have got currently and the rim fitment up front on a 9.5" wide wheel. Coils would give me some height adjustability that the Konis would not (I dont think) I really wish Apex made a 18x9.0 in a profile 3 in the Arc 8 but they dont so if I want to have the wheels look the same a 9.5 front will have to work. Im going to need some camber up front on a 9.5 most likely so that means camber plates but some of the coil setups have camber plates included keeping the cost down but I dont know if that stuff is total garbage?? I fully understand beating Vettes is going to be a tough one but at the rate my buddy in the c6 Grand Sport collects cones it would be fun to get a little closer to him time wise. Last edited by NW 335i; 04-30-2015 at 08:19 PM.. |
04-30-2015, 10:52 PM | #6 | ||
Rep 2,839
Drives: e92 335i, e34 525i & e60 530i
05-01-2015, 12:49 AM | #7 | |
Midlife Crises Racing Silent but Deadly Class
1817
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
There's a 335i driver that consistently places fastest time of day in their stock 335i that post in here. I'd pick his brains if I were you.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
05-01-2015, 06:35 AM | #8 |
Rep 969
I was mistaken on ESP but am not re: 200TW vs. r-comps as they have specifically excepted 13.3.A.1 which is the direct reference to 200TW. Otherwise, there are ongoing Nat'l events in SP classes where every competitor running illegal including Pro Solo events where classes are cross competed with Street and ST classes. Hooisers are alive and well in SP classes. As for ASP, good luck running there.
05-01-2015, 06:51 AM | #9 | |
Rep 259
Given my goals I am having great luck in ASP, the only guy that generally gives me much trouble is a Cayman with Hoosiers.
05-01-2015, 07:27 AM | #10 |
Rep 969
On a second glance, at least the E90/92 M3 is ESP per April Fast Track -- may not help the E90 335i though.
"Street Prepared #12572 E9X M3 move to BSP Remove the following line from ASP and add to ESP: BMW M3 (2007-13) Note: The SPAC feels that this car would not be an overdog in ESP." Seems that while the 335i could amp up boost, it would still be a PITA to really run a full SP allotment.
05-01-2015, 08:41 AM | #11 |
Rep 951
Didnt read the wall of text above but.
Im running an 18x9.5 up front with 255/35 Michelin PSS's -2.8* camber I am on Fortune Auto 500 Coilovers with Swift/Radial Bearing Upgrade. I dd this car and would highly recommend those coilovers, especially over BC.
05-04-2015, 05:13 PM | #12 |
Fast In, Slow Out
40
Rep 586
I just tried out my new tire and wheel setup, 17x9 +30 Apex Arc-8 with Yokohama AD08R, this weekend at autocross practice (~20 runs). I'm pretty happy with the fit and reduced under steer at turn in. The front camber is at 1.5° and could definitely use more next time. There is still quite a bit of body roll even with 394 lbs/in springs in the front.
: Ken
05-04-2015, 05:34 PM | #13 | |
Rep 3,251
05-05-2015, 02:21 PM | #14 |
Fast In, Slow Out
40
Rep 586
05-05-2015, 08:53 PM | #15 |
Rep 4,531
My motto is buy once, cry once.
With that being said, if you really want to get serious I'd invest into dual adjustable coilovers. I run TCK Dual Adjustables with #400 fronts and #700 rears. If you want any serious performance you're going to have to get a stupid alignment. For example I run -3.6* worth of camber up front, camber plates completely maxed out. And honestly the car needs more camber than that. However, with that being said when a car is setup correctly it'll be a hoot to drive. My car from this past weekend picking up the inside wheels |
05-06-2015, 11:19 AM | #16 | |
Rep 3,251
05-06-2015, 11:24 AM | #17 | |
Rep 4,531
Front: Rebound: 1.25 turns from soft Compression: 9 clicks from soft Rear: Rebound: 1.75 turns from soft Compression: 11 clicks from soft |
05-06-2015, 11:33 AM | #18 | |
Rep 2,659
Most likely you need coilovers and lsd. Maybe the best option is to buy pre-owned quality coilovers. I have JRZ with Swift springs and the car is a blast to drive. LSD and DSC/DTC off is the way to have fun! |
05-06-2015, 05:28 PM | #19 |
Rep 185
Holy sh$t I post get distracted then come back and realize I made a post. haha
Anyway some great info in here. Its appreciated. Its tough to sift through all the coilover spring info. Most people seem to pick a brand and spring rate and leave it and are convinced their setup is the best vs. finding people experimenting w various makes and rate and comparing their experiences on the same car. I agree that driver mod is going to be the biggest thing for improvement to start. Again thanks for the info all. Now if I could find some good used coilovers and put the savings from buying new towards the lsd and or wheels and tires I will be set. |
05-06-2015, 09:28 PM | #20 | |
Rep 185
05-07-2015, 10:18 AM | #21 |
Rep 4,531
05-10-2015, 07:15 PM | #22 |
2463
Rep 9,004
Ground Control, TCKline, BC, AST - All brands I've heard great things about, I woukd lean towards GC and TK because of price and performance. BC is good too, but I think it could be considered a 'cheaper' damper.
