05-18-2015, 10:38 AM | #1 |
Rep 2,997
I have no idea what this is/did this to my paint
Hi all,
So I wash my m3 a few days ago and notice what looks like water spots on my paint afterwards once I've dried it - like something spilled on my paint and dried clear, but looking like water spots - a bit gray but transparent/translucent. I'm in a rush, so I figure I'll wipe it with some quick detailer. I get around to wiping it with quick detailer and it doesn't react. When I spray it, the surface feels matte and a MF towel does not glide smoothly over this area. And it's a bit tacky. Now I think: Contaminant that feels tacky, let me bust out the clay bar. I spray some more detailer and wipe all over it with clay - the clay gets embedded in it and does not pull it up. The surface is tacky to clay. It doesn't change, except now it's got clay bar stuck to it. I wipe it with more quick detailer and it doesn't change, nor does the clay get picked up. So now I've got a yellow cast to this problem. I literally have no idea what this is now. MF + Quick detail does nothing, clay not only does not pick it up but is actually getting stuck to it. I'm afraid of busting out the DA polisher but that would be my next step. I'm also a little concerned that someone spilled something on my car (i.e. soda) and that it dried on and etched the paint. Here's a picture - note that the yellow is the clay bar residue. The actual problem did not have a yellow cast to it, but is grayish as shown here. [IMG][/IMG]
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
05-18-2015, 10:55 AM | #2 |
Rep 482
Try goo gone or mothers RRR. Either way, afterwards you should re-wax or seal or whatever your regiment is as both of those will eat the top layer of way/protectant/sealant.
05-18-2015, 11:51 AM | #4 |
Rep 2,997
Good call, let me try goo gone.
05-18-2015, 01:01 PM | #5 |
Rep 2,997
Goo gone tried....removed the stuck on clay and maybe a little bit of whatever is stuck on there, but after 2 minutes of rubbing with a MF towel it wasn't continuing to lessen so I stopped.
Now really concerned and unsure what to try next... |
05-18-2015, 01:29 PM | #6 |
Rep 5,316
Drives: G80 M3 6MT
Buff it out. If that doesn't do it try a light wetsand.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
05-18-2015, 02:16 PM | #8 |
Rep 2,997
Not funny.....
....ok, kind of funny - as it doesn't look far off of that.
05-18-2015, 02:42 PM | #9 |
Rep 6,912
Use a mild abrasive compound with a cutting pad. It should come right off...and if it doesn't, it means you need something more aggressive. Certainly not going to do damage in doing so...
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
05-18-2015, 07:57 PM | #10 |
Rep 601
Drives: 2015 M4
If you have tried to take it off the surface (washing, adhesive remover, etc..) and it isn't responding, it's probably in the paint. I agree with Chris s in that I would try hand waxing first, then hand polishing and then using a polisher - increasing in aggressiveness.
I bet a microfiber cutting pad with light polish will probably do it. My favorite is the Optimum Hyper Polish. I would be shocked if one of these steps won't get it out. Griots has great customer service. If you don't have easy access to a detail shop of some sort with the above tools, call them. They can probably coach you over the phone after looking at the picture. Let us know how you get it out.
2015 AY M4
05-18-2015, 08:03 PM | #11 |
Rep 2,997
I've got some total swirl remover 3.0 I'm going to apply with an orange pad on a Double action orbital.
I don't care if it takes 20 minutes to get it all out, as long as I see some progress. |
05-19-2015, 01:31 PM | #14 |
Rep 2,997
Update: The car had been washed thoroughly (including with some pressurized hosing), goo b gone, clay bar - nothing worked.
I polished it with a light polish (Wolfgang total swirl remover 3.0) and it removed ~50% of the discoloration/flaw but I see some distortion in the clearcoat. Please note: I spent about 7-8 minutes with a random orbital and a light polish in one area and it only removed 50%. It is working - which is very encouraging. I'm going to step up the polishing effort with a more serious cutting pad and polish (which I have to go buy, as I've never needed anything more than this before). Worst case scenario I'll ask a professional to do some light wet-sanding. |
05-19-2015, 01:40 PM | #15 | |
342
Rep 394
Drives: 2015 MW M4
05-19-2015, 02:00 PM | #16 | |
Rep 6,912
There's plenty of clear coat to work with. Get a more aggressive pad and polish. it will come out...
05-21-2015, 11:46 AM | #17 |
Rep 2,997
Just ordered a more aggressive lake country pad and Meg's M105 + Megs M205.
I'm looking for the 105 to be the more aggressive polish. If it needs more than that, I'll have a professional wet sand it. Hopefully will try this weekend. |
05-21-2015, 12:21 PM | #18 |
Rep 183
Please make sure to keep your machine moving otherwise you might burn the paint and create bigger problem for yourself.
05-21-2015, 04:07 PM | #19 |
Master of one
431
Rep 486
If you park your car in an underground garage, it's probably the pipes overhead that leaked on to your car. That happened to me but thank god it was just water. You would need polishing compound then wax and polish and it will fix the problem.
05-21-2015, 08:50 PM | #20 |
Rep 3,345
He should be okay with his DA polisher, but it isn't completely fool proof, so I agree with you in the keep it moving dept.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
05-23-2015, 06:59 AM | #22 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
Is it a lime scale deposit from hard water dripping on it? Before you do anything agressive, try a 1:1 mix of vinegar and water and see if it wipes off.
