annoying sound of The compressor
05-28-2015, 10:47 AM | #1 |
Rep 17
Hi ;
My question is to all BMW (valid for all gasoline types (not diesel engine)) owners and no solution certainly. we haven't found a topic of concern. My air conditioning compressor from the compressor while it is in motion ( viyk viyk ,etc.) like of that sound. Increase and decrease of the sound does not change while driving. The compressor changed and the problem is improving. However, fix that and knows a solution ? There's definitely a problem in my vehicle air conditioning heating cooling. This sound is just annoying. Is there a solution that without changing the compressor completely? Best Regards Sefa arisoy |
06-02-2015, 07:42 PM | #2 |
Rep 91
Drives: 2011 335I xDrive
Can we get a video?
06-09-2015, 03:34 PM | #4 |
Rep 3,251
post this in the correct subforum...
but it sounds like it is your HVAC fan that is causing the noise, not your AC compressor, which I assume is just a typo due to the language barrier. Cheap way to fix it is just to lube up the bearing section on the fan assembly. If it is still making noise, you will have to replace the whole fan assembly, which isn't that hard.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
