First track run. Stock 335xi ok?
06-03-2015, 09:52 AM | #1 |
Rep 427
A buddy is inviting to a small get together at the track. I've never been on a track before but always wanted to check it out and see what its about.
my car is a stock 335xi e90, I've only done suspension and wheels/tires so far. KW V1s and michelin pss 19". Front brakes are brand new, rears are so so. No engine mods, no oil cooler, N55, 6MT. Am I ok going in like this? I am most worried about oil temps and going limp in a middle of a lap or something |
06-03-2015, 10:08 AM | #2 |
Rep 592
For a first timer, you should be fine. Depending on the track, high temp brake fluid might be a good idea. I'm sure others will disagree but I put fresh engine, tranny, and diff fluid for every track weekend. Short shifting can sometimes help temps. Fresh coolant could too. Bring a code reader. Remember you're there to learn, not smash track records. If the car is not paid off, I am of the opinion that track day insurance is a must.
06-03-2015, 11:17 PM | #3 |
Rep 3,251
Short shift at 6k rpm and go very easy on the stock brake pads, you should be ok. Also, watch out for any excessive shoulder wear on the front tires with your stock alignment. Overall, go easy, as you are not going to smash any record with stock brake pads and PSS tires. Be careful not to money shift as well, seen that more often than I expected on the tracks in my experience.
Try to follow the more experienced drivers in a similar car for a lap or two, to learn the line and braking/turn-in points.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
06-04-2015, 11:50 AM | #4 |
Rep 488
Bring an extra coil or two and tools to replace them. If it's a very hot day and the coils are on the older side its very possible to burn and fry them out. Ask me how I know lol.
You should also change your oil before and after especially if you have no oil cooler and your going to be running all day Also see you can have an instructor ride with you for the day. They can help with all the proper lines of the track l, braking, etc. It will help you tremendously |
06-04-2015, 10:01 PM | #5 |
Rep 295
This is going to sound very obvious but one thing I've noticed almost across the board when teaching people new things is to BREATHE.
Happens with virtually everyone getting their feet wet with higher risk sports (track days, motorcycles, ski racing, shooting, etc) People tend to tense up and inadvertently forget to breathe when doing something that requires quick decisions and high concentration. Definitely something to always keep in the back of your mind. Good luck. |
06-06-2015, 10:36 AM | #6 |
Rep 91
Drives: 2011 335I xDrive
No tune?
1. Try to take it easy on the brakes. You are not out to set any records. 2. 335's like to get hot fast. When your laps are over and you park open your hood. 3. Pay attention to your line and gradually increase your speed. 4. Goes with above.. Learn the track. Sometimes the perfect line isn't the fastest. 5. Have fun and get to know your car! Cheers, Burn. |
06-09-2015, 11:55 PM | #7 |
Rep 19
Brake fluid
I got racing brake fluid to help with the brake temp, might look into that. I used rbf600. Also keep an eye out for your engine temp. I had no oil cooler and my car went into limp mode after the third session. Have fun!
06-09-2015, 11:58 PM | #8 |
Rep 19
Forgot to mention: don't use your hand brake in between sessions - helps the brakes cool faster
06-11-2015, 10:04 PM | #9 |
Rep 910
You will be fine. I tracked my 335xi 6spd for a while and no problems. Especially for your first event. Do a brake fluid flush and use something like motul. Have fun!!
06-17-2015, 12:59 PM | #10 | |
Rep 427
this is not me but one of the sponsored pros. just so you get the idea |
04-05-2016, 03:42 PM | #11 |
Rep 61
same concern
my car is 2007 335i coupe, stock suspension, with 29 inche style 269 P zero run flats, running jb4 with intake and downpipes, should i be concerned? Im not going crazy or anything just learning the track for now.
04-05-2016, 05:08 PM | #12 |
Rep 670
best thing to do for your first time out is to make sure you have good brake fluid, good brakes (pads and rotors in good shape), good tires, and a good attitude.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
04-05-2016, 05:58 PM | #13 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
I'd be more concerned with how you fit 29" wheels under the car.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
04-08-2016, 03:04 PM | #14 |
Rep 10
Much great advice here! One thing I didn't see (and as an instructor, I notice quite often), is a reminder to keep your eyes up. It is very easy for a newbie to get tunnel vision and only be looking at the pavement 50-100 feet ahead. Not only will you end up missing braking/turn-in, apex, etc. but you won't be seeing corner workers, flag stations, or your mirrors.
Most important though -- HAVE FUN!! All of us were first timers at one point. I sure remember how nervous I was for my first ever track session. 14 years later I still can't get enough. Be prepared to have serious negotiations with your significant other about how much time and $$$ can be allotted to this addiction if you get bit
________________
2007 E92 335i Sparkling Graphite Metallic // Black // 6MT // Sport // Cold Weather // |
04-22-2016, 10:03 PM | #15 | |
Rep 295
Used to be more into the R/C scene (cars, gas planes and helis) but gradually stopped doing it. Recently had the bug to start flying again but the entire nonsense with now registering R/C planes with the FAA took all the fun out of it. |
